Question about Health & Beauty
My husband is short temper and take drink what can ido for him 22-05-1976
  • 490 Answers
Call the national domestic violence hotline at 1−800−799−SAFE(7233) They have free, good help for you.
Posted on Oct 07, 2010
My Amazon order was short will they ever get to me to answer my question?
Notify them and don't pay the bill and watch how quickly they respond to your issue.
Oct 11, 2016 | Nestl? BOOST VHC VANILLA 8OZ CT
Tip
Fun Facts About Chocolate Tempering
Temperature:
Chocolate is best stored in a dark, dry, cool place, about 13-15 degrees Celsius.
It should not be stored in the fridge nor near strong smelling foods as it will absorb the smell very easily.
If chocolate is wrapped and stored properly it can be kept even for a year.
Regarding the tempering, it is always best to temper chocolate at room temperature (around 20-22 degrees C) .
Water:
Tempering does not go well with water. If you need to temper your chocolate, do not mix it with water. The slightest amount of moisture will cause it to seize.
For this reason you should always make sure that all utensils and the machine are completely dry and that the chocolate isn't more than 10 degrees colder than room temperature. Otherwise condensation will form on the chocolate's surface as soon as it's exposed to the warmer conditions.
Quantities:
If you need to temper large quantities of chocolate (over 700gm) it is best to temper a portion of it, and then substitute some of the tempered chocolate that you use, with melted untempered chocolate.
For example if you use 100cc of tempered chocolate you can then add to the temperer exactly 100cc of melted untempered chocolate and let it blend. In a few seconds the mixture should be fully tempered again. If it does not temper properly, you can press the "melt" button, wait for the cursor to show 43 degrees, and then push "temper", adding more "seed" chocolate.
Viscosity and Texture:
Tempered chocolate should be viscous. The more viscous the better it will cling to a dipped piece, the thicker the coat will be. The more runny the chocolate, the thinner the coating.
In order to adjust viscosity, if the chocolate is too thick you can add small amounts of cocoa butter either by using the method of tempering large quantities of chocolate, or by adding the cocoa butter behind the baffle and go through the cycle again, pressing "melt" and then "temper" and adding "seed" chocolate.
If the normal tempering method doesn't work, try using the Temper 2 option, which includes a slower cooling.
If the chocolate is over-tempered and thick, it could be caused by pieces of cool or solid chocolate in the bowl.
If this happens press "reset", then "melt", wait until the cursor returns to 43 degrees and then press "temper", adding 85gm of solid chocolate behind the baffle, continuing the tempering as usual.
Dipping:
- make sure the piece is completely dry. Dust it with cornflour if you want to be sure of the absence of mousture on its surface.
- make sure the chocolate has the right amount of fat, as too much fat would make the coating too thin and too little fat would make it too thick.
- For a complete coverage of the piece, choose a suitable dipping tool
- make sure you have a ready sheet of unwaxed paper or parchment to set the dipped pieces on.
- allow pieces to set for 24 hours.
- if the dipped piece cracks it means it was probably too cold.
on Jan 01, 2014 | Kitchen Appliances - Others
How do you short short wash cycle
i would not advise to temper the switch or you will invalidate your warranty. depend on how your dial controller set you timing. use the shortest time cycle on your machine and soak your clothing overnight, then use cold water on short wash cycle.my wife does it all the time and separate the white and dark material will help a lot.
Mar 02, 2015 | Washing Machines
How do ya cut plate glass and what tools are recommended?
Hi,If you want to cut glass left over form old project or somebody gave it to you for what ever reason the first thing you need to do is make sure that the glass is plate glass becouse if you try cutting tempered glass its going to blow in your face.
Usually tempered glass has a stamp somewhere in the corner which proves that is tempered and the company that tempered it. After you know for sure that your glass is plate glass you need:
1.Safety glasses
2.Glass gloves
3.Glass cutter
4.Straight edge
5.Cutting table or flat surface covered with felt or short hair carpet
6.Measuring tape
7.Clamps (to hold your straight edge while you score the surface)
The thing is you dont cut glass,you score it with the cutter and then brake it.Please let me know what kind of glass are you going to cut so I can be more specific.
Nov 19, 2014 | Building Materials
Consumer complaints
Ever hear of a lawyer?
Jan 01, 2014 | Health & Beauty
What is a drinking fountain?
A drinking fountain, also called a water fountain or a bubbler, is a fountain designed to provide drinking water. It consists of a basin with either continuously running water or a tap. The drinker bends down to the stream of water and swallows water directly from the stream. Modern indoor drinking fountains may incorporate filters to remove impurities from the water and chillers to lower its temperature. Drinking fountains are usually found in public places, like schools, rest areas, libraries, and grocery stores. Many jurisdictions require drinking fountains to be wheelchair accessible (by sticking out horizontally from the wall), and to include an additional unit of a lower height for children and short adults.
Jul 03, 2013 | Water Dispensing & Filtration
My husband has flu and my friend told me that he has to drink a lot. Does that really help?
Yes, your husband should stay well hydrated and drink at least 8 cups of water a day. The water helps to thin down mucus which has the potential to hang around and turn into a respiratory infection. Hot drinks also have the added benefit of being soothing for sore throats etc.
Avoid caffeine filled drinks as they can cause dehydration.
Feb 18, 2013 | Health & Beauty
Why does drinking alcohol make you snore more? Whenever my husband has too many glasses of wine or beer, he snores like crazy.
Drinking alcohol relaxes the throat muscles. If you drink too much before bedtime, your throat muscles relax which adds to the obstruction of the airways, which leads to snoring as the tissue vibrates while trying to let the air through.
Feb 13, 2013 | Health & Beauty
What are the most common ingredients used in energy drinks?
The most common ingredients found are caffeine, taurine, guarana, ginseng and B vitamins.
Jan 10, 2013 | Wine & Spirits
Need a Starbucks aroma grande coffee caraffe,
I have one to sell you -- make me an offer! The coffee maker stopped working... email me at lesleykish@gmail.com
Jan 13, 2009 | Starbucks Barista Quattro Coffee Maker
Health & Beauty Logo
47 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
