Question about Cameras
When i press something i can't get to my songs it just stays there does not doing anything
  • 3,083 Answers
There are a couple things to suspect right off- you could have a bad button switch (which is sealed and can't be fixed but has to be replaced), a ribbon connector from the button inputs to the main board could be slightly loose and have to be reconnected (which requires opening up the camera). The other possibilites are corrupt software, which is on the main board. You might try taking the batteries out of the camera for a few minutes, and reconnecting it, and see if the camera resets the software. This problem is listed under digital cameras, so I'm not really sure if you're problem is with a camera or ipod, etc.
I'll check back to see if you supply the make and model of the device, that would help.
Posted on Oct 03, 2010
Song List Help
Alex, I'm going to attempt to help here.
After you select "All Songs" you're saying that it simply shows the previous song that was played and starts that one right?
A couple of things, normally the unit doesn't play anything by default when turned on. Usually it will allow you to select from the menu and if you don't make a selection at this point and attempt to back up, sometimes it will start playing the last song used.
Here's a couple of work arounds, first, you can try to use the smaller silver button (above left of large dial), press it and move the menu back to your options or choices such as Artists, Playlists, etc. and select something different that way (this is while the current song is playing).
Another possible solution is to select from the menu either "Artists" or "Browser" and choose another file.
This unit can demonstrate weird behavior at times and like anything else, the more you mess around with it, the more you'll figure out its quirks.
Hope this helps Alex.
May 24, 2010 | Coby MP-610 MP3 Player
I GUESS MY I POD FROZE IT WON'T DO ANYTHING.....
hold down menu and center buttons until the screen goes blank then wait for your ipod to reboot. it should work fine then
Jun 19, 2009 | Bose SoundDock digital music system...
Stuck on one song
try fiddling with the repeat option. you might have changed it and it just didn't register.
Jun 03, 2008 | Samsung YP-U3 MP3 Player
Graig MP3 problem
will not connect to PC
Feb 08, 2008 | Audio Players & Recorders
Erase all songs on my sansa e250R mp3
Ok
the easiest way is:
Open My Computer and go to your sansa folder named something like this "SansaE250"
Open it and go into music and delete all the songs
simply, press CTRL+ A - selecting everything, then press Delete.
Dec 27, 2007 | SanDisk Sansa e250 MP3 Player
Sansa c140 screen frozen
Try a "hard reset". Press and hold the power button for 15 seconds to shut off. With the device off, press and hold the vol + and the center select button. Power it back on, see if that works. You can add to the question if you have more questions. Best of Luck.
Sep 27, 2007 | SanDisk Sansa c140 MP3 Player
Mp3 player wont play songs or anything
Only 2 suggestions here: 1) Make sure your HOLD switch is not enabled. 2) Try to update the firmware If neither of these work, time to send the unit back to Sandisk
Aug 09, 2007 | SanDisk Sansa e250 MP3 Player
Frozen
Press the reset button once with a pin/paper clip by the usb connection. If that does not work press the reset button again but this time hold the play button until a different screen comes up....then I selected clean up. crzmiggie@hotmail.com
Jun 16, 2007 | Creative Labs ZEN SLEEK MP3 Player
Cameras Logo
20 people viewed this question
Top Cameras Experts
Steve
Are you a Camera Expert? Answer questions, earn points and help others
