Question about Pentax Optio 60 Digital Camera
My pentax camera shutter is not closng and the light is switching off after some seconds. The shutter is also not closing automatically. Please help me. I had put new batteries even then it is not working/
    Brigadier General:
  • 3,006 Answers
When you mention "the shutter" I presume that you really mean the lens cover. If you really do mean the shutter then your camera is already a write off and beyond economic repair.
Assuming you did mean the lens cover then your camera most likely has a lens error, this is such a common fault that I hope you don't mind me pasting my stock generic answer below. No point in reinventing the wheel!
Stuck lenses are probably the most common reason that compact digital cameras get thrown away, but there's a fair chance of recovering use of your camera again
The fault is commonly caused by dirt or grit blocking the mechanism, or due to it having suffered a recent fall. Another common cause is that the camera was in a pocket or bag and the power button accidentally activated and tried to open the lens against resistance. The mechanism may have simply become dislodged or there may be parts which have broken.
If your camera is still under warranty (yours has long expired) and has definitely not been subject to misuse then contact the Pentax service department in your country to find out about a free repair. If the warranty has expired though a professional repair will far exceed the cost of replacing your camera. You will therefore have nothing to lose by trying to fix this yourself.
Please click here and you will be taken to an excellent article provided by the Camera Repair website, although it mentions Canon a few times the repair methods are fully valid for any camera with a lens error. For the most part, you'll be guided on how to physically manipulate your camera to try and clear the fault.
If the link doesn't work then cut and paste the following address into your browser:-
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Good luck, I hope you manage to use this information to fix your camera. Please take a moment to rate the free answer I have provided for you and any testimonial which you might wish to add is always welcome!
Posted on Oct 03, 2010
I have a trouble with my digital camera. When I put a lens on the camera I cannot get the shutter to open. I am using some older lens that I had for my manual pentax. Could this be the problem. When I have...
Hi Noodle
One of Pentax's strengths is that that you can use lenses from the late 1960s on them (via an adaptor). However, I'm assuming that you have a bayonet fitting lens - but as you say 'my manual pentax' could it be that they are not autofocus lenses?
If autofocus is switched on and you have a manual focus lens, you have to have something in focus in order for the shutter to fire. (with no lens fitted it doesn't seem to matter). Switch the camera to manual focus (where you can shoot out-of-focus stuff) and see if the problem is still there.
If it is then it spounds as though there is something amiss with the camera to lens coupling.
Jul 07, 2011 | Pentax *ist DL Digital Camera
When i take pictures on my pentax optio s10 the pictures are coming out black but the lcd screen is working, is there anything i can do to fix this?
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, sometimes with lines, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
Jul 04, 2011 | Pentax Optio S10 Digital Camera
My camera is a Pentax Optio m50, and there is no image on display. It's all dark and when I take a picture, it is also dark. Help me please. I've tried all settings.
Jun 24, 2011 | Cameras
My Pentax K100 DSLR is flashing "av" and will not take a photograph, though the shutter works fine and takes pictures without the lens.
"AV" means apeture priority. This means that you set the apeture that the camera will use, and it decides the shutter speed. The flashing "av" means that you've picked an apeture that the camera can't pick a suitable shutter speed for at this light level. I would suggest picking a different apeture, or switch the camera to full automatic mode via the dial on the top left of the camera.
Mar 03, 2011 | Pentax K100D Super Digital SLR Camera
My shutter keeps sticking. I dont understand the
I would suggest you take the camera in to a qualifed service tech for a CLA (clean-lube-adjust). Like any mechanical device, a camera shutter could use periodic service.
Jun 25, 2010 | Pentax ME Super 35mm SLR Camera
My Pentax SPII shoots blank images
You can check the shutter without film in the camera. Remove the lens and open the film door. You will see the cloth curtains of the shutter in the center. Advance the film lever to **** the shutter and set the speed dial to a slower speed like 1/15. Hold the camera so it is aimed a a light source, (a window will do) and fire the shutter. You should see the light through the shutter for the time duration is is set to. (1/15). If you see the light source, repeat the process going up one speed setting until you reach 1/1000. If you see the shutter open and close as described, then try another roll. After you load the film and close the back door, make note of what the rewind knob is doing as you advance the film. It should spin counter-clockwise each time. That is a easy test to know that the film is traveling in the camera properly. Vary your exposures with the new roll at different speeds and f-stops. You should get exposures, but if not let us know.
Jan 31, 2010 | Olympus Stylus 850SW Digital Camera
Film not exposing.
Ok, well are you using a lens that is compatible with the auto setting? Are the batteries new and fresh in the camera? If you are not sure about the lens, then what you can do is too look at the inside of the box of the film you are using (Kodak) has a setting and exposure guide printed on the box. Try using the required exposure for the light that you are in... say for bright sun try f 16 at 1/125th of a second. That setting is for Kodak Royal Gold 100. That is right off the Kodak exposure guide, which you can find on the web here
http://www.kodak.com/global/en/consumer/products/techInfo/e41/index.shtml#exposure
I'd stick to Kodak film if possible. Try that out, and if no dice, then take the camera to a repair shop and have it looked over. good luck!
Dec 19, 2008 | Pentax ME Super 35mm SLR Camera
Pentax optio 60
Your shutter is driven by a small motor attached to the lens assmbly. It could be that which has died or more likely you have a sticky shutter. A small knock or a drop of soda can stop them from opening. Try switching on and very gently with a cotton bud see if you can help open the shutters. Whatever you do don't force them and force them out of shape. You may have to do this a few times to get in sync with the power up sequence but if you can get both shutters to open fully you should be in business. If they keep sticking I've seen one guy glue them open. Personally I'd rather fix them so they do their job.
Jun 19, 2006 | Pentax Optio 60 Digital Camera
Pentax Optio 60 Digital Camera Logo
78 people viewed this question
Top Pentax Cameras Experts
Greg Cann
Greg Cann
Are you a Pentax Camera Expert? Answer questions, earn points and help others
