Question about Canon Cameras
Card is locked - Canon Cameras
  • Canon Master
  • 4,738 Answers
There are several possible causes for "memory card locked", "memory card error", or "no memory card". Some include trying to use of a 4GB SDHC card with an older camera made before SDHC format came out. Others include problems with the tiny slide switch on the side of the card, or the electrical contact switch internal to the camera. The problem may also arise from simple formatting problems if the card has never been formatted in the camera (note that this will also erase the card). Troubleshooting tips for this problem may be found at this link.
Posted on Oct 03, 2010
My camera says the my memory card is locked.?? i dont no how to unlock it My Ixus 70 says my card is locked, but the card is NOT locked (button on the side of the card is in unlock position). The came
Oops. The little latch on the side in the unlock position, should engage a switch in the camera, indicating the memory card is not writ protected. It is not an electrical switch doing something in the memory card. But is the switch in the camera is defect, you get the same result. If someone once tried to press in a memory card, the wrong way around, this could have been the cause of a damaged switch. Just check the memory card slot, of nothing is in the cardholder, blocking the little switch from working correct. Sure the switch is in the up position, like in the picture? 25288825-qj532vtjsqner5bmetfl14fj-5-0.png
Nov 18, 2014 | Sony Cyber-Shot DSC-W530 Digital Camera
Tip
Memory Card Locked / write protected error.
Hi due to so many questions asked about this here it is. How to deal with memory card locked/write protected error.
SOLUTION 1 - Unlock the memory card.
There is a Lock switch on the left side of the SD card. Make sure the Lock switch is slid up (unlock position). You will not be able to modify or delete the contents on the memory card if it is locked.
SOLUTION 2 - Toggle the lock switch.
If the lock switch is not on lock:
1. Slide the switch up and down. Repeat this 3 times.
2. Let it stay on the Lock position for 30 seconds.
3. Slide the switch up to unlock the card.
4. Try to transfer files into the device.
For non-SD cards: Format the card
The data on the memory card may be corrupted.
WARNING: Formatting will delete all the files in the device. Backup all your data before formatting.
Memory card write protected, memory card locked, memory card will not read, can't use memory card.
on Jan 10, 2011 | Sony Cyber-shot DSC-W50 Digital Camera
Card locked I HAVE A SANYO VPC-S885 TRYING TO THE PICTURES THE CARD SAYS CARD LOCKED. HOW DO I UNLOCK THE CARD.
SD cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Oct 16, 2014 | Cameras
The memory was lock. but i want to unlock it
id1102_e3sdhc.gifSOLUTION 1 - Unlock the memory card.
NOTE: If you are using a microSD/microSDHC card or a miniSD/miniSDHC card, insert the card into the standard SD adapter.
Dec 30, 2010 | SanDisk 4GB microSD High Capacity Memory...
How do you unlock camera card it says card locked
Hi. Remove the card. On the side of the card is a small sliding lock. That's it. J.
Jul 12, 2010 | HP Cameras
The card is locked. error
Move the slide switch on the side of the card.
Nov 22, 2009 | Casio Exilim EX-S500 Digital Camera
Memory card locked
I had the same problem - just put the lock button of the card to the lock position and than again to the unlock position
Jul 06, 2008 | Canon PowerShot A450 Digital Camera
Memory card locked
Take the card out. On the left side of the card is a tiny white switch. Reverse the position.
Jul 04, 2008 | Canon PowerShot SD500 / IXUS 700 Digital...
CARD LOCKED
try puting the lock thing onto Lock. it worked for me
Apr 16, 2008 | Canon PowerShot SD500 / IXUS 700 Digital...
Memory card locked
I noticed that this camera does not work well with cheaper memory cards. The only brand that works without fail is the SanDisk brand.
Jan 04, 2008 | Casio EXILIM Card EX-S770 Digital Camera
Cameras Logo
227 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
