Question about Bowflex Treadclimber TC5300
Motor started smoking. Has been smelling jhot for several weeks.
Central air problem
Try spinning the blower motor. If it does not spin freely then the motor is bad. The capacitor being bad will cause this to happen. If the capacitor was not the right microfarad that will also cause the motor to go bad. Also you can just put you nose to the blower motor and try to smell if it smells burnt
Apr 27, 2013 | Heating & Cooling
Dell Dimension 4400 NEVER froze (8-9 years old) until a week ago - kept freezing at start-up - - had to interrupt power SEVERAL times to restart - - tried to power up yesterday - - make a slight sound,...
You need a power supply! Go to Amazon and search for one that is the same specs as yours. Fairly easy to replace, don't use your old one anymore, it could be dangerous.
May 05, 2011 | Dell Dimension 4400 Power Supply ** FREE...
I was sawing an d motor got to smelling and smoking now it won't run
I hate to be the one to tell you But you have lost your smoke!
Once you lose your smoke the motor is toast.
I have always blown out the motors on our shop tools as a matter of weekly maintenance, sure seems to make a difference in how long they last.
Try MSCDirect.com for a replacement
Mar 05, 2010 | Saws
I have a Honda accord 95 and it smells like something odd. When I bought it, the seller trashed some cigarette packages to make it seem like it smelled like it was a smoker's car (despite knowing he...
My car had odd smells like that also some funky looking stains on the seats, dash and headliner. I used a product called SimpleGreen in just the spray bottle and a damp washcloth and scrubbed the interior down make sure to keep the windows rolled down its pretty strong, it will get rid of the smoke smell but will replace it with the cleaner smell for a week or so, but after that I didn't have any of odors come back.
Feb 24, 2010 | 1995 Honda Accord
I have a Kenmore series 90 washing machine, Model 110.26902691. I changed the motor coupling last week and after being proud of my work, I was able to complete one cycle before I started to smell a burning...
Considering the info you`ve provided, specific to the history of replacing the drive coupling. You stated that right after replacing the coupling it started to smoke or as you said "I started to smell a burning smell". Can you identify if it was electrical, or was it rubber/plastic ?
I`ve seen these coupling`s when not put on correctly start to rub against the motor or the transmission, you might want to double check your work with installing the coupling.
Aside from that it could possibly be the motor, but if it agitates and manages to advance through the wash & rinse cycle up to the spin, I`d be skeptical of a motor problem. You should check to make sure the lid switch is being fully closed, in the event it isn`t closed properly the unit will do everything except spin.
Hope that help`s. Good luck.
macmarkus :)
Dec 08, 2009 | Kenmore 24902 Top Load Washer
Maytag electric dryer. LDE9314ACE Drum won't turn, but sometimes will. Had friend turn drum manually while I pressed start/door buttons. Drum turned fine but when I let go of buttons to shut door, dryer...
The motor capacitor is burned. You can replace it yourself. It's on the motor. Take it down to a motor shop and they will have a new one. (electric motor repair shop)
Sep 25, 2009 | Dryers
A/C smelled like smoke then blew 30A fuse - Silverado 1500 2004
You may want to change the blower motor as a precaution.
Do all the fan speeds work?
If not .....change the fan resistor board which is right beside the fan at the same time you change the blower fan motor.
Aug 26, 2009 | 2004 Chevrolet Silverado 1500 Crew Cab
Big puff of white smoke at start up after sitting for several hours.
white smoke is water
blue smoke is oil.
nest time try and smell the white smoke see if it smells sweet?
if it does its antifreeze.
and also black smoke is fuel (like a leaky injector )
hope this helps
paul
Sep 19, 2008 | 2007 Nissan Altima 3.5 Sedan
Burning Smell
no check wiring connector at the motor and the capasitor connectoions, lid switch connections
May 10, 2008 | Washing Machines
Bowflex Treadclimber TC5300 Logo
53 people viewed this question
Top Bowflex Sport & Outdoor - Others Experts
Jerry Greenberg
Jerry Greenberg
Tom Chichester
Are you a Bowflex Sport and Outdoor - Other Expert? Answer questions, earn points and help others
