Question about Jet 708100 Jwts 10 1 1/2HP Workshop Table Saw
Saw worked fine until today. Kicks breaker withing seconds of starting. both 15 and 20 gfci's kicking within seconds.
  • 2,176 Answers
What I would check for and follow closely, is UNPLUG tool turn blade by hand to make sure it turns freely, there could be a piece of offcut wood jamming the blade. then turn it on its back or however you can to see about cleaning with compressed air, check the cord condition for breaks if all the above checks out and sounds like you have tried different power sources you have an electrical short and troubleshooting this is involved.
Posted on Oct 03, 2010
I was using my o17 saw today it was runing Just fine I shut it off when I went to start it again it fired on choke seting after that I could not get it to do anything what is wrong with it
All 2-strokes love to run rich when cold thus full choke till it kicks, half choke to start and leave on for 5 seconds high rev's to warm & lubricate, then no choke to run. Restart when hot is 1 pull full choke (you are now flooded) & then no choke til it starts. Try it. Works every time on all of my 2-stroke engines.
Apr 22, 2015 | Garden
GFCI keeps tripping when I turn on the pump
shorted heater element try with it disconnected if ok then replace heater
Jun 13, 2014 | Hayward Super Pump 1 1/2 - Hp for In...
Hoover Refrigerator Model B38tf. Causes earth leakage circuit breaker to trip. Has just started to occur in last week. What is likely cause and what rectification can be applied?
If you're referring to a GFCI (Ground Fault Circuit Interrupter) breaker tripping, a refrigerator should not be plugged into a GFCI circuit because of the sudden load it requires to start the compressor, etc when it kicks on. The GFCI breakers are meant to be very sensitive, and over time the sudden energy demands caused by a refrigerator can weaken the breaker's threshold, causing them to trip often. Try connecting the refrigerator to another circuit that isn't on a GFCI breaker. If there are no other circuits nearby, you may wish to replace the GFCI breaker with a standard breaker, and replace the receptacles with GFCI receptacles, except of course, the one the refrigerator is plugged into. Be sure and consult and use a qualified electrician for this. Hope this helps..
Oct 29, 2013 | Refrigerators
HI, I have a whirlpool refridgerator model # ed22gw, It worked fine then 3 days ago it triped the gfci I unplugged and tried different outlets with no other load on them and it would still trip the...
Refrigerators should not be run on gfci plugs .As they age , they will pull slightly more amps . Also , gfci plugs will weaken even though no previous problem with them . If you have a gfci plug behind the refrig , replace it with a normal type plug .
Mar 31, 2011 | Refrigerators
I have a Powermatic 66 that trips breaker
Either it has a problem with a blade brake or the motor is siezing. Or the is a wiring problem. With the unit unplugged check and see if you can turn the blade by hand, if not the motor is the problem. If it does you could still have a motor problem by it drawing to much amperage or the is a wiring problem.
Aug 31, 2009 | Powermatic 66 10" 3 HP 1 Phase 230V Table...
Jet 708100 Jwts 10 1 1/2HP Workshop Table Saw Logo
146 people viewed this question
Top Jet Saws Experts
woodzowl307
Are you a Jet Saw Expert? Answer questions, earn points and help others
