Question about Maytag MER5775Q Electric Kitchen Range
The f9 message pops up. when i press the cancel button. it says oven lock.
    Genius:
  • 1,157 Answers
Hi dlahenry,
The F9 fault code is about the door latch, please check the door latch components.
Hope it helps.
Thank you for using FixYa.
Posted on Jun 14, 2011
F9 whirpool range
I had a power fail & when the power came back on I had the F9 error code on my range with a beep beeping that would not stop until I pressed cancel, beeping stop however F9 error code stayed on, I solved the problem by turning off the power, then turning power on again and then I pressed start button and it removed the F9 error code and all is working GREAT now...
whzurdaddy...
Feb 26, 2012 | Whirlpool Kitchen Ranges
I push the bake button for the lower oven and it begins to beep and displays a F9 on the digital display
Hi
F9 is a door lock error and to solve this issue you can hold the light switch for 15 seconds, this will reset the control. If it won't work then hold the light switch in and set the unit to clean and after a minute press cancel to cancel the clean cycle. If still it won't work then the door lock assembly should be replaced. Hope this helps...please post back for further assistance.
Daniel
Aug 01, 2011 | Amana ACB6260A Electric Double Oven
Oven wont turn on and gives F9 message
I UNPLUGGED THE OVEN FOR 10- MINUTES, THE PLUGGED IT IN AGAIN AND HELD THE CANCEL BUTTON ALONG WITH CLEAN FOR 10 SECONDS. THIS CLEARED THE PROBLEM.
Feb 08, 2010 | Ovens
Door lock lites keeps flashing but the door is not locked
The F9 code indicates there is a problem with the door lock.
Try disconnecting the power to the range for 10 seconds and reconnecting. Open the oven door and hold the door switch plunger in while you try these things. Put the control into clean for 5 minutes then cancel clean. You must hold the door switch plunger in for the 5 minutes.
Try canceling the clean cycle without putting the control into clean.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question^%$@#$%
Mar 02, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
How do I clear error beeping (F9) on my Amana gas range
try to hold in on the oven light switch plunger that the door would hit if it was closed properly. what you probably did was to pull the door open while it was trying to lock. once you hold the plunger in, then hit the clean cycle again and then push to cancel button to get the door latch to unlock the door. it may take a minute or two but that should clear up the error code and let you use the oven again.
next time if you push the clean by mistake, just let it go and then when it says "locked" just push the cancel button. it will unlock and be ready to use.
Jan 27, 2009 | Maytag MER6772 Gemini Electric Kitchen...
Maytag Oven Door is locked
Suggestion from => http://www.fixya.com/support/t135369-oven_door_unlock
The first step I would recommend you to do is to turn the circuitbreaker on, then set up the oven clock. Start the self clean for anyamount of time, wait about 30 seconds and push the cancel button. Mostof the time it helps to eliminate the problem.
I've read other places that turning the fan off will unlock the oven.
Dec 31, 2008 | Maytag MGR5751AD Gas Kitchen Range
Amana EvenAir Convection Plus Self Cleaning Oven will not unlock.
My oven was locked and would not open. No lock light was on but the oven was clearly locked. F9 error when I hit certain buttons.
Try this. I unplugged the oven for about 5 minutes. Plugged back in. A LOCK light came on. Held down "Oven Cancel" for a few seconds. Door opened and lock light went off. No more F9 error when I hit those buttons.
Dec 03, 2008 | Amana AEW3530DD Electric Single Oven
F9 Code after power outage - Model JGR8855ADS
Try unplugging the oven from the electrical power. May release the lock, which is held in place by a tiny micro switch. If not and while the electric is still off or the oven is unplugged, use a bright light flashlight to look through the slot where the lock is in the oven, not in the door.
You may be able to use a thin blade screwdriver to move the lock to the release position. Check the angle of the lever. A slightly bent lever handle also can cause this type of condition.
If all else fails, remove the access panel on the front of the oven to access the locking device and release it. May have to disconnect the wires to the lock which will allow door to function but not during any self cleaning modes.
Generic:
Fault Code Interpretation Components To Check
F-1 Communication error between touch pad and ERC (clock)
Replace the touch pad or clock.
F-2 Oven temperature sensed by electronic control Replace the clock/relay board
F-3 Open oven sensor or harness. Replace the oven sensor
F-4 Shorted oven sensor or harness Replace the oven sensor
F-5 Power to element relay disabled in cook mode Replace the clock/relay board
F-7 Shorted touch pad key sensed for 32 secs. Replace the touch pad/control panel
F-8 Shorted meat probe Replace the probe jack.
F-9 Door lock safety circuit on ERC sensed Replace the door latch assembly
F-C or F-0 Communication error between boards Replace the relay board
Maytag-Maycop-Magic Chef-Jennair-Admiral: Oven Fault Codes:
F0 Function key shorted or stuck button Clean and unstick button or replace Touch Pad or Clock
F1 Defective Touch Pad or Membrane Replace Touch Pad or Membrane
F2 Oven over heat defective Relay Board or (if present) or defective Sensor
F3 Oven Sensor Open Replace Sensor
F4 Shorted wire or Sensor locate short and correct it or replace Sensor
F5 Hardware, safety circuits disagree Replace Clock
F6 Missing AC (power) signal Check for proper voltage (plug, breaker, etc.)
F7 Function key shorted or stuck button Clean and unstick button or replace Touch Pad or Clock
F8 A/D Warning Replace Clock
F9 Door Lock Warning Check door lock circuit or Replace Clock
Mar 09, 2008 | Jenn-Air JGR8875QDS Gas Kitchen Range
F9 code
I hit the same F9 problem when trying to self-clean, except that the door was locked OPEN.
After much trial and error, I found the following fix: 1. Switch circuit breaker off. 2. Switch circuit breaker on. 3. Press Bake button. 4 Press the small/inside button which indicates that the oven door is closed.
The lock mechanism opened and the oven now works fine.
Nov 22, 2006 | Amana AOCS3040 Electric Single Oven
Function Problem
Paul, the F9-3 code has to do with the oven door lock motor assy.. Water must have gotten on to it and now the fault. There is a quick test mode on the model ending in aab, if yours ends in this try this. Unplug the oven for 30 seconds, plug it back in and press and hold the cancel and broil buttons together. It should enter test mode. When in the test mode press the clean button to see if the motor activates and resets. Press cancel to exit the test mode...Catriver...post back
Aug 15, 2006 | Jenn-Air JES9800A Electric Kitchen Range
Maytag MER5775Q Electric Kitchen Range Logo
89 people viewed this question
Top Maytag Kitchen Ranges Experts
Lawrence Oravetz
Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
