Master
- Posted on Oct 03, 2010
Re: I have a Copystar 4035 and the automatic feeder...
Here are two ways solution to solve the problem
Cleaning
a laser printer can solve minor problems, maintain print quality, and
prolong periods between professional cleanings. Clean your printer when
print quality deteriorates or when you change toner cartridges.
Collect the supplies you need: a soft cloth and cleaning fluid made for plastic. (Water is fine in most cases.)
Check the printer manual. If the manufacturer has provided specific instructions, follow them.
Turn off the printer.
Dampen a cloth with water or cleaning fluid.
5
Wipe the outside of the printer, making sure that no fluid gets inside.
You
need to know how to clean rollers to keep your printer in
good working order. Proper cleaning of the copystar and the rollers will
help the printer function correctly every time you use it. If the
printer is not picking up the paper or the paper gets stuck in the
rollers, it is time for a cleaning. Cleaning the rollers is simple when
you follow these easy-to-understand steps
INSTRUCTION 2 BELOW
Remove the power cord from the electrical outlet. Open the printer cover and expose the printer rollers.
Remove the paper from the "in" tray and any paper you may have in the "out" tray.
Hold the wet cloth against the first roller with one hand and use the other hand to manually turn the roller.
Replace
the paper in the in tray. Plug the printer in and print a test page.
The rollers should take the paper from the in tray. If not, repeat the
process in Step 3 to make sure you remove all of the dirt
please rate this solution after use
thank you and thanks for using fixya.
This does not address the automatic document feeder on top of the machine. How do I get to those rollers and what do I clean them with?
The automatic document feed on top of the machine does not continuously pick up the pages and then jams.
