Question about Mongoose Maneuver Mountain Bike
How do u raise handle bars on trail bikes with zoom components
bikeservice
  • 34 Answers
SOURCE: Iw ould like to raise the handle bars on my wifes
Most likely you have a threaded headset on your wifes bikes. Many times you will have to replace some of the cables and housing because they will be too short once the handlesbars are raised.
If you have a treadless headset than raising your handlebars is very simple. First check to see what type of headset you have. A threadless system with have a allen head on the very top of the stem and one or two more allen head bolts on the side of the stem. The threaded system will usually have only one bolt on the very top of the stem. It is sometimes covered by some type of cap. Also on threaded headsets, there will be a large nut under the stem, which is what most people mistakenly loosen to adjust the stem. Do not touch this nut, it will adjust the headset. Same goes for the allen head on the treadless headset, it will also adjust the headset so don't touch it.
So if you have a threaded stem, simply loosen the allen head or nut on the top of the stem and raise the stem up. Make sure you do not go above the max line and that you are still able to turn the handlebars freely.
Hope this helps!
Posted on Jul 22, 2009
  • 1138 Answers
SOURCE: handle bars adjustment
You will have to go to a bicycle repair shop and ask for a handle bar stem extender. They come in various lengths.
Posted on Nov 30, 2009
Testimonial: "Thanks! I thought it had to be something like that. It would have been nice if they had made the handlebar adjustment as easy as the seat adjustment."
  • 10 Answers
SOURCE: Schwinn Impact MOS.....can the handle bars be raised...
In order to raise the handle bars, you will need a hex key. Put it into the hex indentation at the top. Turn it left to loosen it. Then raise the handle bars to the desired height.
Posted on May 22, 2010
Testimonial: "Very Helpful because it is not an ordinary handle-bar and I didn't know which one to loosen. "
  • 71 Answers
SOURCE: How do you raise the
there should be an allen wrench bolt on top of the handle bar shaft. loosen that but not to much because you dont want the tightening nut to fall off. now put the front tire between your legs and try to wiggle the handle bars back and forth while pulling up if it does not move try loosening it a little more and take off the first bolt on the shaft and that should work. i hope this helped you
SabiousOne
Posted on Nov 09, 2010
  • 1788 Answers
SOURCE: How do I raise the
Your handle bar stem has a metric screw in the the neck of the bicycle. But, a word of caution, do not raise your handle bars more than the safety mark on the stem, it has to be inserted that much or it and it can snap in two and result in serious injury. Take it to a bike shop and they can either show you how or advise you on replacing the stem with a longer one. This is a very important part on your bike, do not take chances.
Posted on Apr 06, 2011
Testimonial: "Thank you very much That is what I will do , Thanks for your time"
How do you raise the handle bars on the bike?
If it is an older bike, you loosen the bolt at the top of the handle bar shaft until it is about 1/2 inch raised. Take a hammer and give it a swift bump and it should drop into the shaft. Hold the front tire between your legs and the handle bar should raise up. Re tighten once every thing is lined up. If the bike has front hand breakes these may need to be adjusted.
Aug 05, 2014 | Generic 16" Raskullz T-Rad Rex Boys Bike
you cant raise the handle bar but you can add spacers to increase the height.Wish we could be able to raise the handbar
Jul 06, 2014 | Genesis 26 Inch V2100 Dual-Suspension...
I need to raise the handle bar on diamondblack Odyssey DB78 mountain bike. It has a "cartridge system inside" stamped on the top post around the allen key. I loosened the alley key but...
Simply web search for "raise the handle bar" and you get lots of resources.
A major limitation is the steerer tube length. No matter how many times you cut a steerer tube it won't get longer.
Getting Riser Bars or simply flipping the stem over or getting one with a different rise and reach might give you the added height you need. If you LIKE the handlebars, the stem is the best and least-invasive option as most new ones come with front loaders (detachable front caps) that allow replacement without stripping components off one side of the handlebar. In minutes a Bicycle Shop could swap any number of them onto your bike for you to try.
If you had purchased the bike at a reputable Bicycle Shop they would have fit the bike to you before you took it home.
Aug 07, 2011 | Diamondback Cycling
I have a 24 inch ladies bike Ranger Schwinn trail that needs to have the handle bars raised. Can this be done at home? How much will they come up and what tools will I need? Thank you
Read:
http://www.sheldonbrown.com/handsup.html
Jul 09, 2011 | Schwinn Cycling
Can not raise the handle bars on the Huffy Mojava Gulch?
You need to loosen the front bolt that holds the handle bars to the front wheel raise it to your desired position and then tighten it again, making sure that the handle bars are at the position you desire them. This will lock them in place so you can ride your bike and not let them fall back down deeper into the front wheel shaft.
May 11, 2011 | Huffy 26 In Ladies Mojave Gulch Bike
How do I raise the handle bars on my mongoose xr 200 21 speed bike
Apr 05, 2011 | Cycling
Can I raise up the handle bars on my 26" Ladies'
No, but a bike shop can assist you in selecting and fitting a stem with a higher rise.
Feb 24, 2011 | Columbia Sportswear Columbia 26" Ladies...
How do i raise the handlebars?
There are two bolts in the center of the handle-bars. One bolt (on some bikes this is actually 4 bolts) is used to clamp the handle-bars to the handle-bar-stem. You can see both ends of this bolt. If you loosen it, you can tip the handle-bars up and down, but not raise them. The other bolt you can only see the head of. Loosen this a couple of turns (don't unscrew it all the way) then give it a tap with a hammer. You will then be able to pull the handle-bar-stem completely out. Do this so that you can see the wedge-shaped nut at the other end of the bolt. You should also see a mark on the stem that indicates how high you can safely raise the stem. Put the stem back in to the desired height and tighten it back up. Good luck.
Jun 11, 2010 | Huffy 26 in. Cranbrook Cruiser Bike
Bike gears
usually there are 2 levers on each handle bar, one lever lowers the gear while the other one raises the gear. usually the right handle bar has the shift for the gears on the rear wheel, while the left handle bar has the shift for the pedal gears
Oct 08, 2009 | Cycling
Mongoose Maneuver Mountain Bike Logo
29 people viewed this question
Top Mongoose Cycling Experts
Michial Gueffroy
Jim Goldsmith
Jim Goldsmith
Rommel Balcita
Are you a Mongoose Cycling Expert? Answer questions, earn points and help others
