I have code E12 on my Bosch front loader. When I reset washer starts over from beginning of cycle.
  • 3 Answers
SOURCE: Ge Adora Front Loader
If you have not already done so, clean the filter behind the panel in the front bottom of the washer. Remove the three philips head screws to get the panel off. Unscrew the plastic filter on the right hand side (use a shallow cake pan to catch any water). Remove the filter and clean out the pens, pencils, change, lint, etc... and put back in. All should work well after this. Thanks, Greg
Posted on Jan 03, 2008
  • 1462 Answers
SOURCE: Bosch Axxis front loader will not drain
check filter. check no foreign objects fouling pump impellor - bra wires are the favourite
Posted on Apr 25, 2007
SOURCE: New Bosch Front loader washer Maxx Classic WAE18060AU
if machine new have transit bolts been removed from rear of drum it amazes me how many of these get left in after delivery machine will go crazy if these left in drum should move backwards and forwards easily when door opened and drum pushes if solid remove bolts.
Posted on Jan 18, 2008
SOURCE: e13 error code with my
As with some of the other solutions to this error after unplugging from the wall and popping the cover off and unlatching the door with the "emergency" latch release I was able to drain the tub wuth my shop vac then removing the cover to the pump cleanout was able to vacuum the remaining water from the pump . I discovered several buttons and other debris in the fins of the pump, removed those and reassembled. Good as new!
Posted on Aug 10, 2009
SOURCE: I have a 6 year old Bosch Exxcel 1100 front loader
it will more than likely be a bra wire caught in the filter it has happened to me twice. you may be able to get to it from the front opening (bottom right) but probably will have to manualy drain it then tip it back as far as it will go safely against something then underneath attached to the rear of the filter and onto the drum is a fat black rubber tube. remove this it is held in place vie a clip and a small star spangled screw once off you should be able to delve in and find your problem good luck
Posted on Feb 04, 2010
Pump keeps running ...does not advance
You need to check that the pressure/vaccum switch tube is not clogged up..
Mar 03, 2014 | Bosch Washing Machines
Error e 12 frigadaire front end loader washer
Hello paversa971 - Are you certain the error code is E12? This manufacturer does not have any E12 error code for washers. Could it possibly be E10 or E11? If so, washer may be experiencing a water fill issue.
Dec 14, 2012 | Frigidaire ATF6000ES Front Load Washer
My front loader washer does not agitate during
It is possibly the motor brushes. worst case scenario is the motor complete.
Jul 05, 2010 | Bosch Nexxt Premium WFMC6400UC Front Load...
Grey spots on our white clothes after wash
do you use affresh to clean your front loader? deposits of soap and other such things can be stuck around the inside tub of your washer. try this porduct out it works great on all front loaders use hot water with the affresh pellet with no clothes and run the machine through a cycle this also helps with any stagnant water smells also have you cleaned out your pump lately. * note remeber to put the pellet on the inside of the machine not in the soap dispenser
Apr 28, 2010 | Bosch Axxis WFL 2060 Front Load Washer
My washer has E:13 on the display. I called Bosch
According to the service manual, you should clean water drainage pipe and/or drain hose. Turn selector to off and restart 'drain, program or, on 500 plus machines, the 'refresh' program. It also says this is caused by using too much detergent. Bosch recommends using half of what the manufacturer recommends when using HE detergents. They don't recommend regular detergents. I would run the short wash or refresh cycle without detergent and hopefully your lines will clear. I have also read that if this persists, powder HE detergent is better to use instead of the liquid because of certain chemicals contained in the liquids that cause it to congeal in some front loader drainage pipes. I hope this helps.
Jul 03, 2009 | Bosch 3.81 cu ft WFMC530 1UC Nexxt 500...
Banging noise on spin cycle
most front loaders are balanced by a large: ready for this: cement block inside at the top of your machine and because spin is so fast it can sometimes hit inside your machine or it has brokin a peice off ,sorry but yours going to have to get the repair person out.adrian
Feb 15, 2009 | Bosch Classixx WFL 2066 Front Load Washer
Bosch WFMC2100UC Washer stops in mid-cycle
Hi, it seems its about time to replace the motor carbon brushes.
Thanks
Aug 31, 2008 | Bosch WFMC2100UC Nexxt Essence Washer
Beeping on spin cycle
It is most likely out of balance, could be for many reasons.
1 could be too many heavy items such as jeans, towels, etc in one load.
2 could be the machine or floor is unlevel.
3 Could be a balance sensor needs replacing.
Mar 09, 2008 | Bosch Nexxt 100 Series WFMC1001UC Front...
Apr 25, 2007 | Bosch Axxis WFL 2060 Front Load Washer
Washing Machines Logo
859 people viewed this question
Top Washing Machines Experts
