Question about iRiver X20 MP3 Player
X20 IRIVER My screen has like malfunctioned or something ! :S its internal, and for no reason, it just turned black/white/not visible within 2-3 months. It still turns on, charges, and even plays music but the whole screen is black/white. Is this repariable? a friend of mine has the same player and part of the screen has done this too...If it is repairable, where and how much? Very very graetly appreciated if you have a solution . THANNNKYOU! x
    Sergeant:
    Champion:
  • 271 Answers
You screen is gone ( burned ) <due to high impact falling down, too much of use heats up the screen>
don't cost much but it's a bit difficult to find.....try amazon.com
PLEASE RATE ME AS ( FIXYA ) <blue boxes>............
Posted on May 27, 2008
Iriver X20
can you connect it to your computer?
if so then format it then run iriver plus 3
plug it into the computer
then go to tools>Portable Device>Disk Initialization
if you cannot connect your x20 to your computer
there is a tutorial on the iriver support page saying you can format it by,
holding down menu butting and turning it on
but that didnt work for me..
otherwise, its stuffed..
if its stuffed, dont throw it away, ill buy it off you..
contact me if your interested, deano_90@hotmail.com
Apr 26, 2009 | iRiver PMP-120 Digital Media Player
IRiver X20 movie problem
yea the iriver x20 isn't very reliable when it comes to video files. there could be like 10 things wrong with the codec and even if u fix all of them it doesn't help. your best bet is to convert to wmv using the iriver program or another program like winavi converter. its really fustrating i know but its just how the iriver works.
Dec 18, 2008 | iRiver X20 MP3 Player
IRiver X20 not reading SD card
yes this is correct, you can only have the same size memory card as what your iriver was originally. eg when I bought mine it was a 2GB so there for I could only add a 2GB memory card in it giving me a total of 4GB. if you buy a SD card of the same GB you wont have a problem
Nov 15, 2008 | iRiver X20 MP3 Player
Accidentally formatted my x20, now OS Vista does not see x20 when plugged in. Is there any way to reinstall the firmware?
firstly reformat the x20 using the device itself...
after that install the iriver plus 3...
there should be something on the program to reinstall it...
i also think that on the disc that comes with the iriver, there is an install that might help...
otherwise try and reformat the comp
Good Luck...
Aug 07, 2008 | iRiver X20 MP3 Player
Not a good sound
could simply just be the earphones... sometimes it just means ur heaphones are stuffed.
if its not the headphones either the player is stuffed or the audio format is something the X20 can't read
if its the player i'll be frank, you have no hope, there are no specialised stores that can fix it besides iriver international (they'll only take it if its still in warranty). you cant fix it yourself unless you have thorough knowledge of the circuit.
If its the sound format try changing it to mp3 or wma...
hope this helps!
Jul 25, 2008 | iRiver X20 MP3 Player
INTERNALLY VISUALLY BROKEN ! : [
May 27, 2008 | iRiver X20 MP3 Player
Iriver mp3 player
Same problem on a 2GB x20 I just bought. Easy to get things into the device, but nothing recognized as playlist either using iriver plus3 or Media Player.
Feb 05, 2008 | iRiver X20 MP3 Player
Downloading movie length DVD to iriver x20
Yes, you need to convert all your movies to a format iRiver and understand and play.
Here's a link:
Movie Converter for iRiver and instructions
I'm not sure whether Movie Converter supports original DVD files. If that is not the case, then you'll have to convert DVD video into a format that iRiver X20 can use, and then feed that new video to Movie Converter.
However, that would be a bit redundant: to save on time and quality, you could use other video Conversion tools, such as SUPER:
http://www.erightsoft.com/SUPER.html
After loading your DVD, you set the parameters to mirror those accepted by your iRiver model. In case of iRiver X20, those parameters are:
Extension: AVI [[also known as container]]
Video Codec: WMV9 SP, MPEG-4 SP [[MPEG-4 = XVID, DIVX]]
Video Resolution: max 320 × 240
Video Framerate: max 30 fps
Video Bit Rate: max 512 kbps
After successful conversion, upload your new video file to your iRiver X20 and play it back. If it plays [and plays correctly] - then congratulations - it works! If it does not play, then you might have made a mistake while setting the output parameters in SUPER.
Hope it helps. Rate me. Thanks.
.:: Cyberneticus ::.
Jan 05, 2008 | iRiver X20 MP3 Player
Iriver X20- playlists and videos
yeah, basically all i did was change my settings to MTP.
then i went into internal hardrive (just in normal usb mode)
i selected the songs i wanted and right-clicked (make sure to do this one one of the songs you selected) in the options that come up it should say "create playlist" (in bold) i clicked that, it wouldn't let me rename the playlist... but it worked fine... and now they come up in the right place, i didn't even use Iriver plus 3.
Nov 22, 2007 | iRiver X20 MP3 Player
Frozen iriver x20
If your player freezes on "Building Library" (usually a result of putting certain type of .m3u playlists or too big images in id3 tag):
1. Turn the player off - you may need to take the battery out to do this.
2. Hold the menu button in.
3. Still holding the menu button in, press the power button.
4. Keep holding both buttons in until you get a dialogue asking if you want to format internal memory ... say yes.
5. Your internal memory will be formatted and you will now be able to start your X20.
Try to figure out what file is causing X20 to freeze - i've found that pretty much any .m3u file will make it freeze on building library ... only about 2-3 out of about 100 i've tried have worked.
Oct 20, 2007 | iRiver X20 MP3 Player
iRiver X20 MP3 Player Logo
64 people viewed this question
Top iRiver Audio Players & Recorders Experts
Steven Wander
Steven Wander
Are you an iRiver Audio Player and Recorder Expert? Answer questions, earn points and help others
