Question about Magic Chef CMV1000B Microwave Oven
Microwave is not heating1
Same problem happened to me , after cleaning th emicrowave , it is functioning but it is not heating what to do
Ours is a sharp digital microwave oven. The 1st time we used it for popcorn, it works. But the 2nd time I used it, a week later, I was supposed to cook a toasted peanut. I forgot which or what pad I touched just found out that the microwave oven is not heating.
What should I do?
Posted on Sep 15, 2008
  • Magic Chef Master
  • 9,098 Answers
Did someone spray cleaner directly on it, especially around the keypad area??
The first thing to try is a "hard reset". Unplug it from the power line for a few minutes, plug it back in, set the clock, then try again.
If not, then you might leave the door open overnight and see if that helps it dry out, then try the rest again and try cooking again.
Otherwise, please write back with your brand and model number if you need further help.
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on May 30, 2008
My microwave doesn't heat up everything else seems to work
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101 ;';
Sep 14, 2011 | Samsung SMH8165STE Microwave Oven
The microwave will not heat food. It will turn on the turntable will go around and the time will count down but the food is not heated when done. tried different heat setting with no results.
This seems to be a common problem, there are three parts that will cause this, the magnetron "heats food" a common failure, the high voltage diode and capacitor are the other two culprits. The cost to repair will approach the price of a new oven.
Feb 01, 2011 | Samsung SMH9151 Microwave Oven
Microwave works except not heating food
heatman101
djh
May 08, 2010 | Bosch HMV9305 Microwave Oven
Microwave not heating , rest of functions fine
Hello :
This could happen because of a bad door switch or a loos door switch mount . This could the switches not be activated . This is the main reason that microwaves not heat even if the other functions work fine . The reason of bad door switches is slamming doors and not closing them gently .
Warning : A microwave oven is capable of giving you a serious electrical shock, even when it is unplugged. I strongly recommend you seek the assistance of an appliance repair technician when conducting any microwave oven repair .
good luck .
please rate !
Mar 31, 2010 | Sharp R-90GCK 900 Watts Convection /...
OK, if everything, including the fan, is working, this will confirm Magnetron failuer. you cannot reset the function of a failed Magnetron heating unit. replace this failed device asap if possible.
Jun 05, 2009 | GE Microwave Ovens
Samsung Microwave runs won't heat
Test the high voltage capacitor,the rectifier diode.or the magnetron.
If it additionally does not spin and no light, then check also the door switch.
The diode and capacitors can br tested. The capacitor must be alloweddischarge before testing, or you risk to get electrocuted, even ifpower is off. Capacitors can get discharged by shorting their twocontacts.
Replace the magnetron if the checks and all of the high voltage component tests are good, but the unit still does not heat.
All locations, and description of this parts can be located using the diagram here: Counter top.
Parts must be tested to find out what is wrong.
Remember that microwaves are potentially dangerous devices if not repaired properly, the job must be done by a competent person.
A microwave energy leakage test must always be performed when the oven is serviced for any reason.
Regarding parts, contact the seller here to purchase parts. (here in UK).
Apr 07, 2009 | Samsung SMH7174BC Microwave Oven
Microwave oven not heating thoroughly
u need to clean the cavity inside the microwave .. step to clean that .. put a cup of water nearly half filled( 30 ml ) and start microwave for five minutes .. after that just open microwave and clean from inside with clean cotton cloth .. this will surely help ..
Mar 23, 2009 | Kenmore 63683 Stainless Steel 1200 Watts...
GE Over range microwave, JVM1660
This just happened to ours as well. Apparently the magnetron (device that creates radio waves that heat the food) is broken. I'm trying to pry the darn thing out of our kitchen now so I can replace the magnetron. Look for this part WB27X10489 on Google. I found it on ebay for $65. If it fixes the problem I'll post again.
Aug 18, 2007 | GE JVM1660 Microwave Oven
Display is extremely dim to where you almost can't read it anymore
take down the display and clean the contacts if that does not work replace it.good luck.
Apr 27, 2007 | Sharp R-360E Microwave Oven
Magic Chef CMV1000B Microwave Oven Logo
80 people viewed this question
Top Magic Chef Microwave Ovens Experts
William Miller
William Miller
Oloyede Monsuru
Are you a Magic Chef Microwave Oven Expert? Answer questions, earn points and help others
