Question about Sony Grand WEGA KF50XBR800 50" Rear Projection HDTV-Ready Television
MY sony kf50xbr800 tv will shut itself off for about 20 seconds and then come back on.While it is off the standby light will blink.What do you think?
  • 52 Answers
If your tv set shuts off by itself at any time, sometimes earlier or sometimes longer, there mus be lost contact on the pins of the parts of your unit. Usually it occurs when the audio is loud. The vibrations will cause some of the pins to lost contact from the circuit causing the automatic voltage regulator to shut off, detecting the abnormal flow of currents and voltages in the circuit. Ask for a qualified serviceman to have it check and solder the pin or pins having a lost contact.
Posted on Oct 03, 2010
Sony kdf-E42A10 red light blinking
see other solution and remove and inspect lamp.
The set will shut down if lamp fails to come on.
Mar 12, 2012 | Sony KDF-42WE655 Television
KF50XBR800 Rear projection LCD TV on and then standby
from how long you have this problem? and what made it start?
do u remember the cause?
Dec 28, 2007 | Sony Grand WEGA KF50XBR800 50" Rear...
Kf-50xbr800 turns off for about 30 seconds, standby lights blinks 34 times before coming back on. stays on for 2 minutes then repeats cycle...
The tv LED light "LAMP" indication it is flashing too or lite up?The tv projection lamp has it been in the tv like 1 1/2 or 2 years already and tv in uses it like 4 or 5 hrs everydays?Yes?The tv projection lamp life has ended.Tv require a new projetion lamp.Dose this whole blinking lights 34 times cycles have like clicking noises to it too.Yes,than the board that call the Ballast board it is also dead.Tv must it Ballast board replace too.This Ballast board only job are to ignite the tv projecion lamp only.
Aug 22, 2011 | Sony Grand WEGA KF50XBR800 50" Rear...
40'' Sony Bravia goes into standby with the light blinking 9 times
I finally managed to solve this problem by unplugging everything - scarts - HDD cables - power etc and left it for an hour. When I turned it back on again the problem had sorted itself out.
Sep 30, 2009 | Sony Televison & Video
Sony lcd projection tv kf50xbr800 shuts down and
Hey there, from what you are telling me I think the problem is coming from your Power Supply board it sounds like it could be two things
one: the board might have gone bad and its not sending the corresponding voltage to your components and that is why it keeps turning off
example: works ok for a while then gets weak truns off and then gathers enough turn back on
two: the power supply could be over heating and it has a sencor when it gets to hot to turn off this is very rear though
please rate this solution !!!
Jun 19, 2009 | Sony Grand WEGA KF50XBR800 50" Rear...
Continuous blinking standby light
according to the manual try unplugging the cord and waiting 5 minutes then replugging and trying again. If that doesnt help you may want to check the bulb as they have been known to shatter
May 13, 2008 | Sony Grand WEGA KF50XBR800 50" Rear...
Sony grand wega started turning on and off continuously
codes consist of N blinks, a pause and N blinks again,valid error codes are 3, 4, 5, 6 & 9 blinks.
Jan 23, 2008 | Sony Grand WEGA KF50XBR800 50" Rear...
Sony KF50XBR800 Turn off and on issue
You will need to replace your bulb.
It costs around $ 300.00 for a new bulb.
After you have installed it, your TV will look new once again.
Dec 30, 2007 | Sony Grand WEGA KF50XBR800 50" Rear...
Grand Wega picture going on and off; standby light flashing, sound remains on
Is the cooling fan running properly?  I'm just guessing, but it sounds like it could be overheating and shutting off, which allows it to cool off enough to turn on and overheat all over again.
Dec 09, 2007 | Sony Grand WEGA KF50XBR800 50" Rear...
Sony Grand WEGA KF50XBR800 50" Rear Projection HDTV-Ready Television Logo
107 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
