Question about Honeywell Heating & Cooling
I fully extended the extender panels on my Honeywell HW628 Twindow Dual Window Fan and can't get them to shrink back to fit my window. Please help.
  • 1,420 Answers
Most likely they have popped out of their bottom channels. You will need to get them back in to be able to open the panels. Good Luck!
Posted on May 27, 2008
Tip
Fix 2005 tahoe rear wiper (other year GM SUVs may also apply)
My 2005 tahoe rear wiper was inop. The symptom was a pulsating buzz coming from the wiper motor, but no wiping action. I mistakenly bought a new wiper motor, which was not the cause. It was a bad ground, so instead of hunting the bad ground, I just added another grounding wire to the motor. Maybe my experience can help you. Make sure ignition is off and wiper is off. (As an added safety precaution disconnect the negative battery cable to prevent unexpected wiper action). To get access to wiper motor, open rear window glass to remove upper window trim surround. On either side of the window latch there are two black flat plastic "buttons". Release these by pushing from behind with a flat blade screw driver to pop out the center pin. With the pin extended the whole button can be pulled out. Open the tail gate and gently pry under the upper window trim to release clips from underneath. Remove upper window trim. Now to remove lower tailgate panel, remove bolt holding the pull strap. remove pull strap. As before gently pry lower panel to release clips from underneath. When all are loose, lift panel vertically to remove, by releasing the two "fingers" that fit into slots. Now that the motor is exposed, cut a short length of insulated stranded wire (like lamp wire) and crimp-on some terminal ends(just the stripped bare wire ends will also work). Attach from under a wiper motor frame mounting bolt (do not use either of the rubber insulated bolts) to under a mounting bolt on the window glass latch assy. Or you can also select any motor grounding point to any vehicle chassis grounding point as desired. Op test the wiper. Note: The window glass and tailgate will have to be closed to test. Hopefully it works properly. Put everything back in reverse order. Remember to slide fingers of lower panel into their slots before pushing clips secure. Also after remounting upper glass trim, fully insert the two plastic latch buttons with center pins extended, and then push in center pins.
on May 11, 2010 | Chevrolet Tahoe Cars & Trucks
Tip
WORD 2003 Shortcuts
All Caps Ctrl+Shift+A
Annotation Alt+Ctrl+M
App Maximize Alt+F10
App Restore Alt+F5
Apply Heading1 Alt+Ctrl+1
Apply Heading2 Alt+Ctrl+2
Apply Heading3 Alt+Ctrl+3
Apply List Bullet Ctrl+Shift+L
Auto Format Alt+Ctrl+K
Auto Text F3
Auto Text Alt+Ctrl+V
Bold Ctrl+B
Bold Ctrl+Shift+B
Bookmark Ctrl+Shift+F5
Browse Next Ctrl+Page Down
Browse Prev Ctrl+Page Up
Browse Sel Alt+Ctrl+Home
Cancel Esc
Center Para Ctrl+E
Change Case Shift+F3
Char Left Left
Char Left Extend Shift+Left
Char Right Right
Char Right Extend Shift+Right
Clear Del
Close or Exit Alt+F4
Close Pane Alt+Shift+C
Column Break Ctrl+Shift+Return
Column Select Ctrl+Shift+F8
Copy Ctrl+C
Copy Ctrl+Insert
Copy Format Ctrl+Shift+C
Copy Text Shift+F2
Create Auto Text Alt+F3
Customize Add Menu Shortcut Alt+Ctrl+=
Customize Keyboard Shortcut Alt+Ctrl+Num +
Customize Remove Menu Shortcut Alt+Ctrl+-
Cut Ctrl+X
Cut Shift+Del
Date Field Alt+Shift+D
Delete Back Word Ctrl+Backspace
Delete Word Ctrl+Del
Distribute Para Ctrl+Shift+J
Do Field Click Alt+Shift+F9
Doc Close Ctrl+W
Doc Close Ctrl+F4
Doc Maximize Ctrl+F10
Doc Move Ctrl+F7
Doc Restore Ctrl+F5
Doc Size Ctrl+F8
Doc Split Alt+Ctrl+S
Double Underline Ctrl+Shift+D
End of Column Alt+Page Down
End of Column Alt+Shift+Page Down
End of Doc Extend Ctrl+Shift+End
End of Document Ctrl+End
End of Line End
End of Line Extend Shift+End
End of Row Alt+End
End of Row Alt+Shift+End
End of Window Alt+Ctrl+Page Down
End of Window Extend Alt+Ctrl+Shift+Page Down
Endnote Now Alt+Ctrl+D
Extend Selection F8
Field Chars Ctrl+F9
Field Codes Alt+F9
Find Ctrl+F
Font Ctrl+D
Font Ctrl+Shift+F
Font Size Select Ctrl+Shift+P
Footnote Now Alt+Ctrl+F
Formatting Properties Shift+F1
Go Back Shift+F5
Go Back Alt+Ctrl+Z
Go To Ctrl+G
Go To F5
Grow Font Ctrl+Shift+.
Grow Font One Point Ctrl+]
Hanging Indent Ctrl+T
Header Footer Link Alt+Shift+R
Help F1
HHC Alt+Ctrl+F7
Hidden Ctrl+Shift+H
Hyperlink Ctrl+K
Indent Ctrl+M
Italic Ctrl+I
Italic Ctrl+Shift+I
Justify Para Ctrl+J
Left Para Ctrl+L
Line Down Down
Line Down Extend Shift+Down
Line Up Up
Line Up Extend Shift+Up
List Num Field Alt+Ctrl+L
Lock Fields Ctrl+3
Lock Fields Ctrl+F11
Macro Alt+F8
Mail Merge Check Alt+Shift+K
Mail Merge Edit Data Source Alt+Shift+E
Mail Merge to Doc Alt+Shift+N
Mail Merge to Printer Alt+Shift+M
Mark Citation Alt+Shift+I
Mark Index Entry Alt+Shift+X
Mark Table of Contents Entry Alt+Shift+O
Menu Mode F10
Merge Field Alt+Shift+F
Microsoft Script Editor Alt+Shift+F11
Microsoft System Info Alt+Ctrl+F1
Move Text F2
New Default Ctrl+N
Next Field F11
Next Field Alt+F1
Next Misspelling Alt+F7
Next Object Alt+Down
Next Window Ctrl+F6
Next Window Alt+F6
Normal Alt+Ctrl+N
Normal Style Ctrl+Shift+N
Normal Style Alt+Shift+Clear (Num 5)
Open Ctrl+O
Open Ctrl+F12
Open Alt+Ctrl+F2
Open or Close Up Para Ctrl+0
Other Pane F6
Other Pane Shift+F6
Outline Alt+Ctrl+O
Outline Collapse Alt+Shift+-
Outline Collapse Alt+Shift+Num -
Outline Demote Alt+Shift+Right
Outline Expand Alt+Shift+=
Outline Expand Alt+Shift+Num +
Outline Move Down Alt+Shift+Down
Outline Move Up Alt+Shift+Up
Outline Promote Alt+Shift+Left
Outline Show First Line Alt+Shift+L
Page Alt+Ctrl+P
Page Break Ctrl+Return
Page Down Page Down
Page Down Extend Shift+Page Down
Page Field Alt+Shift+P
Page Up Page Up
Page Up Extend Shift+Page Up
Para Down Ctrl+Down
Para Down Extend Ctrl+Shift+Down
Para Up Ctrl+Up
Para Up Extend Ctrl+Shift+Up
Paste Ctrl+V
Paste Insert
Paste Format Ctrl+Shift+V
Prev Field Shift+F11
Prev Field Alt+Shift+F1
Prev Object Alt+Up
Prev Window Ctrl+Shift+F6
Prev Window Alt+Shift+F6
Print Ctrl+P
Print Ctrl+Shift+F12
Print Preview Ctrl+F2
Print Preview Alt+Ctrl+I
Proofing F7
Redo Alt+Shift+Backspace
Redo or Repeat Ctrl+Y
Redo or Repeat F4
Redo or Repeat Alt+Return
Repeat Find Shift+F4
Repeat Find Alt+Ctrl+Y
Replace Ctrl+H
Research Lookup Ctrl+Shift+O
Reset Char Ctrl+Space
Reset Char Ctrl+Shift+Z
Reset Para Ctrl+Q
Revision Marks Toggle Ctrl+Shift+E
Right Para Ctrl+R
Save Ctrl+S
Save Shift+F12
Save Alt+Shift+F2
Save As F12
Select All Ctrl+A
Select All Ctrl+Clear (Num 5)
Select All Ctrl+Num 5
Select Table Alt+Clear (Num 5)
Show All Ctrl+Shift+8
Show All Headings Alt+Shift+A
Show Heading1 Alt+Shift+1
Show Heading2 Alt+Shift+2
Show Heading3 Alt+Shift+3
Show Heading4 Alt+Shift+4
Show Heading5 Alt+Shift+5
Show Heading6 Alt+Shift+6
Show Heading7 Alt+Shift+7
Show Heading8 Alt+Shift+8
Show Heading9 Alt+Shift+9
Shrink Font Ctrl+Shift+,
Shrink Font One Point Ctrl+[
Shrink Selection Shift+F8
Small Caps Ctrl+Shift+K
Space Para1 (single spacing) Ctrl+1
Space Para15 (one-and-a-half line spacing) Ctrl+5
Space Para2 (double spacing) Ctrl+2
Spike Ctrl+Shift+F3
Spike Ctrl+F3
Start of Column Alt+Page Up
Start of Column Alt+Shift+Page Up
Start of Doc Extend Ctrl+Shift+Home
Start of Document Ctrl+Home
Start of Line Home
Start of Line Extend Shift+Home
Start of Row Alt+Home
Start of Row Alt+Shift+Home
Start of Window Alt+Ctrl+Page Up
Start of Window Extend Alt+Ctrl+Shift+Page Up
Style Ctrl+Shift+S
Style Separator Alt+Ctrl+Return
Subscript Ctrl+=
Superscript Ctrl+Shift+=
Symbol Font Ctrl+Shift+Q
Task Pane Ctrl+F1
Thesaurus RR Shift+F7
Time Field Alt+Shift+T
Toggle Character Code Alt+X
Toggle Field Display Shift+F9
Toggle Master Subdocs Ctrl+\
Toggle XMLTag View Ctrl+Shift+X
Translate Pane Alt+Shift+F7
Un Hang Ctrl+Shift+T
Un Indent Ctrl+Shift+M
Underline Ctrl+U
Underline Ctrl+Shift+U
Undo Ctrl+Z
Undo Alt+Backspace
Unlink Fields Ctrl+6
Unlink Fields Ctrl+Shift+F9
Unlock Fields Ctrl+4
Unlock Fields Ctrl+Shift+F11
Update Auto Format Alt+Ctrl+U
Update Fields F9
Update Fields Alt+Shift+U
Update Source Ctrl+Shift+F7
VBCode Alt+F11
Web Go Back Alt+Left
Web Go Forward Alt+Right
Word Count List Ctrl+Shift+G
Word Count Recount Ctrl+Shift+R
Word Left Ctrl+Left
Word Left Extend Ctrl+Shift+Left
Word Right Ctrl+Right
Word Right Extend Ctrl+Shift+Right
Word Underline Ctrl+Shift+W
on Dec 03, 2009 | Computers & Internet
Partician a hard drive
Hard drive volumes are can be partitioned to adjust s. The hard drive space that's available after device installation depends on two factors; the actual manufactured of the hard drive, and the number and of the partitions created on the hard drive. Partitioning a hard drive splits the total manufactured space into sections, each listed as a separate device by your computer's operating system. It's used primarily as a method of turning larger hard drives into more manageable sections of storage. There are times when the chosen partition is no longer adequate to your needs. You can quickly change the partition of the drive using the administrative tools of your operating system when this occurs. The data will remain intact and the newly d partitions are instantly available for use.
Press the "Start" button located on the taskbar on the bottom of the Windows desktop. Select the "Control Panel" from the Start menu to open the Control Panel window. Type "administrative tools" into the search box of the Control Panel window. Click on the Administrative Tools link revealed in the Control Panel window to open the Administrative Tools window. Double-click on the "Computer Management" option listed among the Administrative Tools in the rightmost panel of the Administrative Tools window. Select "Disk Management" in the Storage subcategory listed in the left panel of the window. A display will appear listing all of the hard drives contained in your system and hard drive information, including the s of the current partitions contained on the drives as well as the available space of the drives. Right-click on the drive partition you wish to change in the lower panel of the window. ''Choose a option, either "Extend Volume" or "Shrink Volume." Use "Extend Volume" to enlarge the of the partition. There is a limit to the maximum of the partition, based on the amount of free space contained on the drive. Select "Shrink Volume" to shrink the of a partition. Select the new partition and then select the "Enlarge" or "Shrink" button to complete the resizing process. If you've already allocated all of your hard drive space to multiple partitions, you will have to shrink one partition on the drive in order to create free space for enlarging another partition. The newly d volume is immediately ready for use. Rather doing all of this although it could be a useful learning exercise you could use a third party software program
http://www.filehoo.com/download/Partition-Magic-8,0.aspx
freeware b> http://download.cnet.com/minitool-partition-wizard-home/3000-2094_4-10962200.html Freeware Hope this helps.
Dec 28, 2012 | Smartdisk - Peripherals - HARD DRIVE,...
How to partition hard drive
Dec 18, 2012 | Western Digital Computers & Internet
Cannot change volume
Hard drive volumes are can be partitioned to adjust sizes.
the actual manufactured size of the hard drive, and the number and size of the partitions created on the hard drive.
There are times when the chosen partition size is no longer adequate to your needs.
You can quickly change the partition size of the drive using the administrative tools of your operating system when this occurs.
The data will remain intact and the newly sized partitions are instantly available for use.
Press the "Start" button located on the taskbar on the bottom of the Windows 7 desktop. Select the "Control Panel" from the Start menu to open the Control Panel window.
A display will appear listing all of the hard drives contained in your system and hard drive information, including the sizes of the current partitions contained on the drives as well as the available space of the drives.
Right-click on the drive partition you wish to change in the lower panel of the window. ''Choose a size option, either "Extend Volume" or "Shrink Volume."
Use "Extend Volume" to enlarge the size of the partition.
There is a limit to the maximum size of the partition, based on the amount of free space contained on the drive. Select "Shrink Volume" to shrink the size of a partition.
Select the new partition size and then select the "Enlarge" or "Shrink" button to complete the resizing process.
The newly sized volume is immediately ready for use.
or you could use a third party software program
freeware
Freeware
Hope this helps
Nov 06, 2012 | Computers & Internet
My computer system dell dimension xsp-t700r i want to install another new window operating system but it will run to some extend and stop, though i have run several window operating disk yet it could not...
dear mary,
it may be the case that the harddisk you want to install the new windows version to
is either full or has bad sectors in it,
in both cases it is necessary to fully erase all data and format it, before installing the new Operation System!
you perhaps can try to install win2000,
let it remove any existing installations and partitions(blank the disk) from the harddisk, then run a chkdsk scan from the recovery console, format the disk afterwards and quit without installing fully.
Now you can choose your desired windows version.
It could make sense not to install a later win than win xp home, for this machine is more than a decade old and therefore remarkably slow. Use Win2000 Professional edition if you can get a hold of a copy.
To receive extended help in setting up the system, please come back via fixya.com
Aug 04, 2009 | Computers & Internet
We want the fan to run continously.
if you download the installation manual, (it sonds like you have the user manual) it will explain how to go into the installer set-up so you can make the desired changes, (wise choice to go to continuous fan, helps keep your air cleaner, just remember to keep an eye on your filters.)
Jul 07, 2009 | Honeywell Programmable Thermostat Heater
Loud screeching sound from window fan.
There are two bearings in most motors.  One is at the base of the fan blade where the shaft goes into the motor.  Try lubricating this with a small amount of household oil.  If your lucky, this will stop the problem.  If not, the bearings have worn and the unit will need replacing.
Nov 15, 2008 | Honeywell HW628 Window Mount Fan
Is there any way to take back off to clean???
I had the same problem. I called Honeywell and they told me that it was designed so it could not be removed and I would have to send it in for repairs. When I told them it only needed cleaning, the woman told me they won't do that and I should by a new one. Right. So, I took it to Home Hardware and they were very helpful. Apparently, the screws at the back require a special screwdriver that is not sold to the public. But, they did it for me and replaced them with common screws. Now I can open it and clean to my hearts content.
Jul 08, 2008 | Honeywell HW628 Window Mount Fan
Heating & Cooling Logo
23 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
