Question about Vacuums
1975 Taurus RV trailer manual - Vacuums
Boat trailer parts - Item # 5002
Fixya does not sell parts.
Jun 27, 2016 | Vacuums
Head bolt torque for 1976 ford f-250 390 engine
Hello William, My specs. show 80-90#. I like to torque them in three steps, 70, 80, & 90# with oiled threads and oil under the heads of the bolts. Let the gasket do it's job... DON'T OVER TORQUE
Feb 26, 2014 | Holley 1975-1987 Ford F-250 Carburetor,...
WATER LEAKING IN MY CYCLONE RV
Maybe you shouldn't have moved your girlfriend up to North Dakota with you. I'm sure that it is her fault that your water is leaking in your RV.
Nov 04, 2011 | Vacuums
The circuit breaker on my 2006 fleetwood pioneer (31 ft.) travel trailer keeps kicking off on my A.C. What could cause this problem?
I believe you have a problem with the start capacitor on your air conditioner compressor motor.
Sep 11, 2011 | Vacuums
Replace a fuse on an rv microwave
if the fuse blew, somthing is wrong and it will fail again. Cheeper to just replace the unit.
Oct 10, 2010 | Vacuums
I recently purchased this vacuum after reading consumer reports article on it and from recommendations from family. However, since I've had this vacuum it's been nothing but problems! I have a frieze...
is that a shag carpet? the power head is raised up all the way can you lower the suction on it is the carpet old the vacuum may not be able to handle the carpet,go to a vacuum store and see if you can try somthing else out some stores well let you rent them out kirby is a good vaccum i think my grandmother had the first models when they came out and it still works to this day my mom has a kirby she bought in 1975 and basic tune ups it works great and the use to have the long string shag carpet.and yes it had to be on its highest seting.well i hope this helps thanks
Nov 29, 2009 | Hoover Tempo Widepath Upright Vacuum -...
I have a hoover celebrity QS wuith the power head. I have only used the powerhead for years purchased in 75) I removed the powerhead to use the brush and the power does not come on but if I put the...
You have done very well keeping this appliance working since 1975!!!
Lucky you!
I'm not certain you would be able to get replacement parts for this model any longer,
Maybe you will just have to continue with the powerhead only.
Nov 17, 2009 | Hoover Vacuums
Need instruction manual
a few steps down in Google, I found the whole manual in adobe format! I only need the filter for vacuuming, so I'm in the clear---except that it won't spurt soapy water out...I just squirt it on with a spray-bottle and use the brush and suction from the cleaner. Sorta fixed the problem but I'm desperate to get on with cleaning this very small area (an RV)
Nov 13, 2008 | Bissell 1697-7 Powersteamer Pro Deluxe...
Engine troubles
I haven't fixed it yet but I think I might have a solution for it. From the factory this thing had a 4 barrel carb and they put an equivalent size atomizer in it for the propane and over the years someone omitted the EGR system in it and propane is already a hot burning fuel so without that system in it it picks up idol speed when under normal operating conditions and when I put the system back in it should fix the problem...... I hope. thanks for quick response. Grant
Mar 18, 2008 | Vacuums
Vacuums Logo
76 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
