Question about Toshiba Computers & Internet
Just bought Toshiba Laptop want more info on what the F-key symbols mean and what some of the other symbols mean.
    President:
  • 1,851 Answers
In general, keep in mind that the Fn key works in combination with the some of the keys; usually the Fn key and the relative keys have the same color. Clarify me your model to get you more details.
In case of a problem or clarification, don't hesitate to post me a reply before rejecting my answer.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Thanks and regards
Please kindly rate this solution
Stelios
direct fixya link: http://www.fixya.com/users/technical114
Posted on Oct 03, 2010
How to turn the brightness down on a toshiba laptop
There are function keys for this on the keyboard, look for the Sun symbol on the keys.
Aug 28, 2014 | Toshiba Computers & Internet
Wireless communication switch is disabled. I am not able turn on wireless communication switch. I was wondering if Toshiba a135-s4527 has a built wireless hardware????Vista SP2
When you say oyu cant turn on the wireless switch does that mean after flicking the switch usually located on the front or side of the laptop it sitll doesnt work. or have you tried holding the function key (fn) and hit the wireless symbol key on your keyboard it looks like the letter i with circles around itusually on the f8 key. by holding fn then f8 key it should turn it back on
May 07, 2011 | Toshiba Satellite A135-S4527 Notebook
On key 2 the symbol is not working
hi, I have a toshiba laptop keyboard too and after almost 4 years a few keys stopped working, and I did a little research about it and it seems that the most common problem is dust, try to remove the key and clean the area behind the key, if you can't get it working then it means that the circuits for that key are damaged and there is no way to fix it... you need to replace the keyboard
May 06, 2011 | Compaq Keyboard
No wifi
Hi its very small switch with the WiFi symbol on it check at the front of your laptop and some laptops have it at the side you can find it easily check carefully
thank you
if this information is useful kindly vote for me
hbristol173
Mar 31, 2010 | Computers & Internet
Cat sat on laptop changed screen brightness. its to dark how do i brighten monitor
There is a master function key that you hold down while tapping another function located on the keyboard. This all depends on the model of laptop. Next time try to giva a little more info like make and model, which is located on the bottom. The function key or Fn key is usually located on the keyboard near the Alt and Control key lower left. while holding this key down, you tap the corresponding brightness key on the number of the keyboard, some times the brightness is on the 4 arrows on the right side of the keyboard...sometimes they are the numbers 6 or 7 look for what appears to be a symbol that looks like the sun or a light. Hold down Fn and tap the key that brightens the display.
Sep 05, 2009 | Computers & Internet
I just bought an Acer laptop andkeys are all different from desktop keyboard so wondering how I can find out what the keys are for without just hittin all of them. Are there specs available? Thankyou. Dee...
The symbols on the keys represent what will appear on screen
If the symbol is in blue that means you have to press the FN key over on the left side bottom row
Other symbols from the keyboard are typed by using the shift key
You can always buy a keyboard and plug it into the laptop if it proves to difficult
Aug 19, 2009 | Acer 91.63X07.001 Keyboard
MY A100 LCD SCREEN IS VERY DIMM WHEN VIEWING DVD howto brighten
You can brighten or dim the LCD screen by pressing the Fn key plus another key with the a sun symbol eg the UP & DOWN arrow keys or one of the F3 to F12 keys - it varies depends upon the model of the laptop.
If you cannot vary the brightness of the LCD screen the you have a faulty backlight.
Connect an external monitor to the laptop and power it up, if you see a clear image on an external monitor, this means your video card is OK.
If you see a dim image or flicking image on the LCD screen it means you have a backlight problem.
Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out www.lcdparts.net for parts, repair service and DIY info.
Mar 14, 2009 | Toshiba Satellite A100-S8111TD Notebook
The @ key will not work
Ok ya Keyboard probably has a bad contact behind the key.. new keyboard sorry but in mean time ya can "Type" the @ symbol by holding down the "ALT" key and typing 64 (on the NUMBER keypad) some info about this code ASCII below.
http://chexed.com/ComputerTips/asciicodes.php
Jun 22, 2008 | Acer Aspire 3000 Notebook
External Monitor connection issue
There is only one way to connect an external monitor to a laptop.Most laptops have an "FN" key. by simultaniously pessing the "FN"key and F7 key it toggles from laptop to external to both each time you press the keys.
Mar 13, 2008 | Computers & Internet
Computers & Internet Logo
79 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
