Question about Maximatic EDF-4080 Deep Fryer
Where can i find the plug for this unit? - Maximatic EDF-4080 Deep Fryer
What is the spark plug gap for 18cc weed eater?
search
What is the correct spark plug gap?
The spark plug gap on all products is .025-inch.
What type of spark plug does the unit take?
The size of the plug varies from unit to unit. On trimmers, blowers and hedge trimmers is RCJ-8Y or RCJ-6Y. Follow the spark plug recommendation and replacement procedures in the operator's manual if you are doing the work yourself.
Jun 07, 2015 | Weed Eater Featherlite 18cc 2 Speed Gas...
No spark,"Gardentech" (Netto/Aldi) how can I test ignition unit?
no meter needed just take the spark plug out then hook the coil wire back to it, try to find a dark area then hold the spark plug to the head anywhere that's metal and have a friend try to start it or do so yourself with the switch on of course. If it sparks at the end of the plug then the coil is good. If not install new plug , repeat procedure. Also, check all wire connections and ohlm out the switch why your at it.
May 30, 2014 | Garden
Will a 1995 Buick Skylark leak oil if the Oil Sending Unit is burnt or bad?
Yes the sending unit will leak oil if it's bad. It will leak where the electrical plug clicks into the unit. If you disconnect the plug and remove the unit, you can see on the plug end where the oil leaks thru.
Jul 28, 2012 | 1995 Buick Skylark
I get an error code e1 and have cleaned and replaced the filter. Runs for a couple minutes then shuts of with same message. Any ideas?
THIS SHOULD RESET IT
1 DISCONECT THE POWER PLUG FROM POWER SUPPLY 2 CLEAN FILTER 3 HOLD DOWN THE POWER ON/OF BUTON ON THE UNIT AND PLUG THE UNIT KEEP PRESSING UNTILL IT EMITS A BEEP SOUND FOR APROX 5 SECONDS 4 DISCONECT POWER AND PLUG AGAIN
IF THAT DOES NOT WORK 1 DISCONECT UNIT 2 HOLD DOWN THE MODE KEY ON THE PAD OF THE UNIT AND PLUG THE UNIT KEEP PRESSING UNTIL IT EMITS A BEEP SOUND APROX 3 SECONDS THE UNIT WILL START. 3 STOP THE UNITS OPERATION BY PRESING ON/OF 4 RESTART UNIT.
BEST OF LUCK
May 31, 2011 | Sharp AF-R120FX 12,000 BTU Comfort Touch...
Refilling the transaxle on MTX75 Ford Focus
Hi there, this unit is normally a sealed unit, any reason for changing or re-filling the unit. draining plug on the back en of unit, lower drain plug, filler plug the top one and need to be filled untill it reaches the level of filler plug, fit new seal and torque to spec. just use the right oil from your dealer.
Sep 20, 2010 | 2005 Ford Focus
My unit displays P2 mode flashes red wont turn.....
P2 error indicates that the spill reservoir in the base of the unit is full.
Solution:
Move the unit to a location that is suitable for draining water from the unit. Remove the plug in the lower center of the back of the unit and allow the water to completely drain (Remember to replace plug.)
Remember...this is not the water tank on the side. This is the water than can collect in the bottom of the unit. Take it outside and drain it
Aug 20, 2009 | Heating & Cooling
The fax log will not load when prompted
Please perform the resets given below and check if you are able to print the fax log. Please perform all the resets.
*** Partial Reset ***
* Turn on the unit
* Disconnect the power cord from the back of the unit
* Press # and 3 buttons simultaneously while plugging the power cord to the unit.
*** Semifull Reset ***
* Turn on the unit
* Press # and 6 buttons simultaneously while plugging the power cord to the unit.
*** NVM Reset ***
* Turn on the unit
* Press OK and Cancel buttons simultaneously while plugging the power cord to the unit.
Wish
Jul 31, 2009 | HP Officejet Pro L7780 All-In-One InkJet...
Audio buzz
Check to see if reversing the plug takes away the buzz. Some times turning the plug over in the wall socket i.e. reversing polarity, will remove the buzz.
Dec 09, 2008 | Philips HTS3400/37B System
Wireless phone extension not working on receiver. Red light and horrible sound hen connection is attempted
You need to register the unit it will work:
1.
Make sure the Base Unit is switched on and has a Green light showing.
2. Unplug everything connected to the Base Unit sockets (you will reconnect them later).
3. Plug the Extension Unit into a power point near the Base Unit, switch on the power and watch the light on the Extension Unit.
4. If the light on the Extension Unit is not glowing a steady Red then the Extension Unit must first be deregistered. Follow Step A and Step B in
the Deregistering an Extension Unit box below then try to register the Extension Unit again.
5. Plug one end of a supplied line cord into to either socket on the Base Unit and plug the other end into the extra Extension Unit
(This cord is used to do the actual registering).
6. The light on the Extension Unit will glow Red for up to a minute and then change to Green or Yellow.
7. Once you have the Green or Yellow light on the Extension Unit, unplug the line cord between the Base Unit and the Extension Unit
(You can unplug the Extension Unit – it will remember being registered).
8. Plug in everything that used to be connected to the Base Unit sockets.
9. Install the extra Extension Unit as per the Extension Unit Installation steps on the other side of this page.
Apr 27, 2008 | Lands Phones
Maximatic EDF-4080 Deep Fryer Logo
22 people viewed this question
Top Maximatic Kitchen Appliances - Others Experts
raysaw
Irene Tulloch
ELECTRICKS
ELECTRICKS
Are you a Maximatic Kitchen Appliances - Other Expert? Answer questions, earn points and help others
