Question about Woods 201 cu. ft. Upright Freezer V2003RW3
I dont know if this is the right freezer but can it turn into a refridgerator too...mine has a nob that goes from 0 to 7 on the inside but i do not know what that is
  • 98 Answers
That is the thermostat switch. You should be able to control the inside temperature by rotating the nob.
Posted on Oct 04, 2010
We have Frigidaire Upright Freezer. After 6-7 days its stops cooling as its condenser gets ice around it whereas the fan is working good. We clean the ice and it again starts working/cooling.
There are a few possibilities. Freeze-ups are a result of the unit either not having sufficient airflow or the compressor running too long and too often. As you note the fan is good, chances are airflow is not the issue. There are a few quick items that you can check on:
1. Check door seals. Leaks will cause the interior to lose cooling faster and result in compressor overloading.
2. Do not overload the freezer. Too much inside the freezer will cause loss of airflow INSIDE the unit and can cause issues.
3. Avoid putting too much unfrozen material into the freezer at once. It takes a lot of work to remove all the heat from a large amount of material.
4. Avoid multiple opening and closing of the door. Upright freezers are inefficient as they lose all their cold air as soon as you open the door. Chest freezers do better if you must go into the unit often.
Lastly, undercharged refrigerant system can cause the same issue. If you don't have any of the other problems noted, have a serviceman check the refrigerant and fill the system as needed.
Feb 29, 2016 | Frigidaire Freezers
Is the Kenmore Freezer model 23971 supposed to run continuously or should it be alternating on and off? Mine is running all the time and I am not sure if this is broken or working correctly.
If it is in a warm garage or the sun is shining on it through the window its going to run a lot. Try putting a thermometer inside and see what temperature is. Leave it in for an hour or so. It shouldn't be below 0 degrees F unless you have some high quality ice cream in there that needs a colder temperature. Slowly turn the temperature up one number increment every couple of days until you reach 0. Hope this helps and good luck.
Oct 05, 2014 | Freezers
Jenn aire refrigerator not completely freezing ice cubes
Increase the inside coldness by rotating the termostat switch nob to a higher number position.
Oct 03, 2010 | Jenn-Air Freezer Jenn Air Clear Cube Ice...
How to make my freezer colder
Hi, some thermostat control knobs and directions to make it colder are different. Here is the best way to find out which way to turn it to make it colder. Make sure you hear it running. Take the control knob and listen carefully while you start to turn it in one direction first. Turn it until you hear the unit shut off. If you turn it all the way to the left and it keeps running, turn it all the way to the right until it stops running. Once you know which way it stops running when you turn it, this will tell you that you need to turn it until it comes back on again and runs. This will be the way it turns to get the temperature to get to a colder setting. When you are doing this, do it very slow and give it about 3 minutes in between each time you start to turn it the other way. On mine it has numbers on it. The higher the number lets say from 1 to 8, the colder it gets, but some are the lower the number the colder it gets. So, you want it to shut off, so wait until you hear it running before you turn the knob. You can open the doors and it will make it come on faster. So when it goes off when you turn the control knob, you will no to turn it the other way for it to come on and it will get colder the more you turn it in that direction. Very easy. PS If it doesn't get colder when you find out which way it goes, you may have a bad thermostat. Please let me know. You can put a thermometer inside to watch the temperature
Good Luck,
Shastalaker7
Jun 30, 2010 | Hoover 9.9 cu. ft. / 280 liter Upright...
The Fridge Freezer has stopped working the supply is healthy and the internal light is working but no refridgeration
See if the compressor is running, if so see what the frost pattern looks like on the evaperator coil inside of the freezer after removing the panel covering it inside of the freezer, this will tell us if you have a sealed system problem or not perhaps...
Jun 24, 2009 | Freezers
Freezer outside walls are very hot. Not maintaining temp
Hi, The walls are getting hot because that is where the condesor coils are. The condensor coils are where the heat is disperst that is trap as the coolant pumps through the evaporator coils inside. The fact that it is holding 0 degrees is a good sign. Is this freezer in a garage?
Check the door seals to make sure no heat is getting into the freezer other then when the door is opened.
I hope this helps you. Please let me know if I can assist you further.
Vic
Jun 24, 2009 | Kenmore 20.3 cu. ft. / 575 liter Upright...
Proper temp. range in freezer
Hi dgh1,
The freezer should stay within 5 degrees of 0 while in operation. While in defrost the freezer may reach as high as 20 to 25 degrees. If any higher temperatures are reached your food will spoil as they are defrosted and refroze everyday. If you find that the temperature is allowing your food to defrost you may want to replace your defrost thermostat. This device is located on top of the evaperator coil inside the back of the freezer. It is made to turn the heater off when a temperature of 55 degrees is reached. One other possible problem could be your defrost timer is taking to long to restart the cooling cycle after defrosting. I hope this will help you and please send any other questions you may have, I am happy to help. and dont forget to rate me.
Mike Anderson
Anderson Appliance
(865)945-3808
Oct 28, 2008 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Woods 201 cu. ft. Upright Freezer V2003RW3 Logo
124 people viewed this question
Top Woods Freezers Experts
Dan Webster
Dan Webster
Sal De
Are you a Woods Freezer Expert? Answer questions, earn points and help others
