Question about Canon Rebel XT / EOS 350D Digital Camera
Compact flash card will not go into slot fully
    Brigadier General:
  • 11,967 Answers
Look into the slot and check for bent pins.
Posted on Oct 04, 2010
THE CAMERA BRINGING A NOTICE ON A SCREEN ERROR CF.WHAT IS POSSIBLE THE PROBLEM.
Digital Camera: How to Fix Compact Flash Memory Cards ErrorIt is not very typical for compact flash memory cards to give you an error. If you do receive an error, it most likely means that a pin within your CF card slot is bent, or your CF card has become corrupted. Unfortunately, if your CF card has become corrupted, you will need to reformat the memory card, which means that you may lose any pictures that were located on the card.
Fixing Your Flash Memory Card
You will want to remove your CF card and the batteries. Take a look inside the CF card slot to see if there is a bent pin. If you find a bent pin, you can correct this problem using a very small and skinny flat screwdriver. Moving very slowly, use the screwdriver to bend the pin back into place. You do not want to use enough force to make the pin back in one shot.
The pin does not have to be perfectly straight, but get it as close to straight as possible. Insert your CF card back into the slow very slowly. You should see the in align itself with the card. You can turn your digital camera on to verify that the compact flash memory card is now working.
Mar 11, 2011 | Cameras
Can not turn it on, batteries are charged fully and loaded correctly
Hi, Check whether your batteries are actually making contact with the battery posts, and that these posts are clean. If not, bend the posts up/down a little, and maybe clean them with a little rubbing alcohol on a Q-tip. Or if that doesnt work our for yoiu , if your camera uses Compact Flash, check to make sure all pins are present and aligned in the card slot (if bent, simply unbend/straighten them with a skinny "jewelers" screwdriver, then insert the flash card for final realignment).
Apr 15, 2010 | Canon PowerShot S1 IS Digital Camera
My media card slots are not working any longer. I have a Compaq Presario Model sr1603wm. The drives do not show up under My Computer. Any idea how this could be fixed? These are the card slots not working,...
Have you tried unistall and reinstall the drivers?Go here http://h10025.www1.hp.com/ewfrf/wc/document?docname=bph07165&tmp_track_link=ot_recdoc/c00471056/en_ca/bph07165/loc:2&lc=en&dlc=en&cc=ca&lang=en&product=1118242#N1070
and try to install the drivers again
Jan 12, 2010 | HP Compaq Presario SR1603WM (ED861AA) PC...
Err cf have changed compact flash cards. every
check deep inside the card slot to see if you have any bent pins. They can often be straightened out with a thin screwdriver.
Sep 05, 2009 | Canon Rebel XT / EOS 350D Digital Camera
Olympus E10 pins bent on compact flash slot
That is correct. The camera should default and detect that a smartmedia card is now inserted to the camera and write the images to that card. As I stated earlier, the cards are independent of each other.
Mar 11, 2009 | Olympus Camedia E-10 Digital Camera
Wat is toshiba flash card
"FLASH" generally denotes a compact storage device called
Compact Flash Card. I have an old digital camera that takes compact flash cards.
Newer Toshiba Laptops and Towers have multi card readers installed, my laptop has a SD card reader under my PCMCIA card slot. I also had a (Made for Toshiba) compact flash adapter. That device was nice because it wasn't "Card Bus" it used 8-16 bit technology making it easy to transfer data from a laptop running windows 3.1 to a laptop running Vista
Apr 13, 2008 | Computers & Internet
Acer aspire 7004 flash card slot
Your computer doesn't support compact flash cards. Your SD slot is a 5-in-1 card reader, supporting Secure Digital (SD), MultiMediaCard (MMC), Memory Stick® (MS), Memory Stick PRO? (MS PRO), xD-Picture Card? (xD). The big slot is for PCMCIA devices.
Jul 12, 2007 | Acer Aspire 3000 Notebook
D70 digital camera
could be bent pin in the memory card slot
Jan 03, 2006 | Nikon D70 Digital Camera with 18-50mm Lens
Microdrive compatible?
The microdrive is compatable with anything that supports reading compact flash memory cards, because there is a common method of communication between flash and hard drives that use pcmcia or CF slots.
Sep 13, 2005 | Dell Axim X5 Pocket PC
Canon Rebel XT / EOS 350D Digital Camera Logo
26 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
