Question about Raypak Rp2100 Pool & Spa Heater Lonox 407k Btu Natural Gas Polymer Header Digital Rp407aenc
Raypak pool heater - error code is "FAN" - Raypak Rp2100 Pool & Spa Heater Lonox 407k Btu Natural Gas Polymer Header Digital Rp407aenc
  • 310 Answers
In models older than 07-07 it typically indicates a loss of the pilot light.
In models newer than 07-07 it is probably the air switch not being activated, or it has just failed. Check air switch tubing for secure connections.
Posted on Oct 27, 2010
3 Suggested Answers
  • 366 Answers
SOURCE: RayPak 2100 series digital pool heater Code "EOL".
press the mode button until the display reads "off". Remove the four screws holding the control cover on. Swing panel down so that the back of the board is visible. Press the mode button until "RESfl" appear. Press and hold both "up" and "down" buttons for 5-7 seconds until three dashes appear (---). This resets the fault history and clears any stored faults.
Posted on Sep 16, 2009
  • 864 Answers
SOURCE: raypak pool heater piliot light on heat will not turn on
Make sure that gas control knob is set to ON (counterclockwise). Make sure that ON/OFF switch is ON. Check that temperature setting is high enough to call for heat. Make sure pool pump is running and water is flowing to unit.
If not above there is a diagnostic procedure on page 33 of manual at:
http://www.raypak.com/uploads/6000.52AG.pdf
Posted on May 30, 2009
Why does my Raypack 156ENC pool heater have error code Rollout SW open?
Either keep replacing the switch or find out what is causing the switch to fail. The "plumber friend" should know.
Jul 16, 2014 | Raypak 130,000 BTU Natural Gas Pool...
I am getting a ROL code on my raypak 406 gas pool heater. Does anyone know what this means?
roll out senor bad replace but check gas pressure if too low it will overheat once gas is ok then replace fusible link and clean outside of het exchange
May 11, 2012 | RAYPAK R406A DIGITAL MODEL 406 wCUPR0...
Ign error code on a raypak rp2100 pool heater
ignition failure check gas pressure if ok see if ignitor is ok or safety circuit
Apr 22, 2012 | Raypak Rp2100 Pool & Spa Heater Lonox 407k...
Raypak pool heater RP2100 error message CLK
you are in fireman switch mode,which means pool timer is ready to shut down pump. clk shuts down heater approx 15 minutes before pump shuts down. this lets heater cool down before pump shuts off.
Jul 05, 2009 | Raypak 130,000 BTU Propane Gas Pool...
Raypak Rp2100 Pool & Spa Heater Lonox 407k Btu Natural Gas Polymer Header Digital Rp407aenc Logo
1,202 people viewed this question
Top Raypak Pool & Spa Experts
Bill Jordan
paulcarew
Are you a Raypak Pool and Spa Expert? Answer questions, earn points and help others
