Question about Honeywell 50150 Air Purifier
How to change the flter - Honeywell 50150 Air Purifier
  • Honeywell Master
  • 5,187 Answers
Turn off the unit and unplug it. Turn the air purifier on it's side and unscrew the locking mechanism (turn counter-clockwise) on the base of the unit. Remove the base assembly from the unit. Remove the filter assembly and find the seam of the pre-filter. Carefully separate the fastener and then remove the pre-filter from the HEPA filter.
Discard the filter(s) being replaced. Then remove the new filter from the packaging and discard the packaging and plastic. Carefully wrap the pre-filter around the HEPA filter so that the ends meet. Fasten the ends together with the fastener.
Place the filter assembly in the air purifier and reattach the base. Then tighten the locking mechanism. Turn the unit right side up, plug it in and turn it on.
You can find a pdf of the manual here: http://www.honeywellpurifiers.com/product/0-90271-50150-4.html .
I hope this helps.
Posted on Oct 03, 2010
How to change air filter on 2006 Toyota Hiace SLWB diesel automatic?
Hi josephjohn,Here are instructions on How to Change Cabin Air Filter in a Toyota. It is recommended to replace this filter at every oil change.
Jul 29, 2014 | Filter Queen Defender Air Purifier
Red filter light does not change to green when filter is changed
Call the manufacture and tell them it is defective and to please replace it.
Apr 02, 2014 | Holmes Products Air Purifiers
Changed thermostat and resivor tank and still it over heats...Would changing the oil make a difference?...And what could be the problem?
if you changed the thermostat and res. I'd say your heater-core is clogged or the radiator, or your fans are not turning. Could also be your coolant is to diluted with water as in 70 percent water 30 percent collant.
Oct 27, 2012 | CRC 05528 Air Brake Anti Freeze, 1 gal.,...
Change filter light won't go off
The Change Filter indicator light is controlled by a timer, rather than detecting the condition of the filter. After changing the filter, hold down the timer and speed buttons for about 5 seconds. This turns off the indicator light and resets the timer.
Jul 22, 2011 | Vornado AQS35 Air Purifier
Change Filter LIght
take somthing with a small tip, above the light there is a small hole stick it in lol. good luck!!!!!!!!!!!!
Nov 11, 2008 | Honeywell HHT-081 Air Purifier
Hunter 730 carbon pre-filter replacement orange light
Filter lights on your Air Purifier http://www.fastbrowser.net/netpicker/Filter-lights-on-your-Airifie.htm One of the best things about your IQAir Air Purifier is that it has warning lights to tell you when to change the prefilter, gas or hepa filters. Of course how long they last depends on your pattern of usage. For the initial 80% of the filter life the control panel will display a green light next to the corresponding filter on the outline of the unit. When the orange light goes on it does not mean that the filter needs to be replaced immediately but that there is 20% of useful life left. IQAir gives you plenty of time and the machine will tell you how many hours you have left. Once the number of hours gets to within a few hours remaining the orange light will then change to red. It is at this time you should change the filter. If you forget to change it and there are no hours left the hours will go into the negative displaying how many hours you have gone over and the red light will change to a flashing red light.
Just in case you have lost the manual like one of our customers, this is how you reset the filter lights:
1. Press the menu button ( 7 times) until you get to where the display says new filter.
2. Press the enter button and hold it down for 3 seconds and a number 1 will be flashing after the words new filter on the display. This flashing number is so you can enter which filter you have changed. Filter number 1 is the pre-filter, filter number 2 is the V-5 gas filter, and filter number 3 is the Hepa filter.
3. You change the number for the filter by pressing the up arrow button.
4. Once you reach the correct filter number you press the enter button and the control panel will display a question mark after the words new filter on the display. Below this it will say, E = Yes M = Cancel. If you wish to cancel the entry so it does not reset a new filter life, simply press the Menu button.
5. If you want it to reset the filter life for the changed filter, simply press the Enter button. Once this is done, the filter light will change back to the green light, which will show the filter has been changed. If you go to the remaining filter life on the control panel for the filter number you just changed, you will now see the remaining life of the filter in hours has been reset.
  • When most people think of Oreck, an air purifier is usually not the first thing
  • IQAir Dental Series Air Purifier
  • UV air purifiers are very effective at neutralizing airborne pathogens
  • HEPA Air Purifiers
  • REPORT ON THE AIR QUALITY CLEAN UP IN OUR OFFICES
  • Ozone Air Purification
  • Ionic air purifiers come in three different forms
  • WHOLE HOUSE HEPA
  • Dehumidifiers - Ebac Orion
  • Furnace Filters, Electronic, Electrostatic Air Filters - Comparisons, Ratings,
  • Nov 26, 2007 | Hunter 30216 3-SPEED FLOOR MODEL Air...
    Resetting the change filter indicator
    Turn off the unit
    Open the filter cover
    On the top right corner, there is a small hole
    Push a paper clip into this and the change filter light will stop blinking.
    Hope this helps!
    Nov 04, 2007 | Neoair Plus Air Purifier
    Honeywell 50150 Air Purifier Logo
    200 people viewed this question
    Top Honeywell Air Purifiers Experts
    Bill Long
    Jay Finke
    Jay Finke
    Are you a Honeywell Air Purifier Expert? Answer questions, earn points and help others
