Cars & Trucks Logo
Posted on Oct 03, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Lost keys for chevey truck 2000 utility truck 350 chevey truck need to know how to disable factory alarm system to start the truck
Johnny Brown
Level 3:
  • Chevrolet Master 5,763 Answers
  • Posted on Oct 03, 2010
Johnny    Brown
Chevrolet Master
Level 3:
Answers
5763
Questions
0
Helped
3164101
Points
20432
This is close to imposible, you would need a scan tool to reprogram a need chip code into the computer, now if theres no chip the power locks or the door lock should deactivte the alarm system, if you dont have a door key then you would need to remove the door panel and manualy turn linkake on the lock as if it were the key, but i think the 2000 had a key chip.
Lost key and alarm dodge caravan
to reprogram new key first you need to use 2 factory program keys.place first factory key in the ignition first turn ignition on for 3 seconds. then turn off ignition then install second factory in the ignition on position for 10 seconds.when immobilizer warning lamp begins to flash a acoustic signal is emitted.within 60 seconds. switch ignition off and remove key.then insert new key and switch on for 10 seconds a acoustic signal is emitted and immobilizer warning lamp remain illuminated for 3 seconds indicating programming completed.if all fails dealership has to reprogram new keys.
1helpful
Disabling alarm system on 2000 mitsubishi mirage
this is a long shot, put the key in the driver door, turn to unlock then try to start the car, some systems disarm when the key is used to unlock the car.
2helpful
2000 TOYOTA TUNDRA HOW TO DISALARM ITS SECURITY ALARM
Insert the key in the ignition.
Turn the key quickly from the "Run" position to the "Off" position five times.
Turn the key to the "Start" position and start the car. This will disable the alarm and allow you to start the car again.
Read more: http://www.ehow.com/how_7440586_disable-factory-toyota-alarm.html#ixzz2cKir9i5LWorked for me.
3helpful
2answers
My jimmy starts and runs when it wants to then sercruity light comes on and shuts it off
Yes the truck came with a stock antitheft system. That IS what the security light is about. Check out this link. Everything you need to know is there.
http://vatspasslockpasskeysecurityhelp.yolasite.com/
2answers
Lost remote to disable alarm on 2000 mercury villager how can i disable it and start my van
If you have the factory alarm system, you can put your key into either door and lock and unlock the door, that signals the computer to deativate the alarm. If you have an aftermarket alarm system installed, it will have to be removed and the wiring that the alarm ties into must be restored to factory design.
1helpful
97 toyota 4runner factory alarm not allowing to start
lock your doors and close it wait till alarm resets and then unlock door with key and this should take care of you problem
1helpful
Need to un-hook alarm.
If it is a factory alarm, you can have your anti theft disabled at the dealership.
1helpful
How do I reset factory alarm on a 2000 Subaru
you HAVE to get a remote and unlock the car.the dealer may be able to turn it off with the obd2 system,you have to call subaru.
Disable factory alarm for 2000 explorer
I would try replacing your key. If its worn down that will happen.
Alarm goin off when trying to jump
for a factory alarm the only way is to lock/unlock doors(with key) unless some one knows how to disable the alarm altogether. if alarm is not factory just find the box and remove alarm system (you may need to reconnect some wires if it has starter disable as a feature)
Top Chevrolet Experts
ZJ Limited
ZJ Limited
john h
Thomas Perkins
Thomas Perkins
Are you a Chevrolet Expert? Answer questions, earn points and help others
