Question about Pentax Optio S5n Digital Camera
Camera is not getting on - after fell in sea water
Hi my camera accidently fell in the beach.Even though it was inside the cover and inside the sea water just for few sec, it is not getting switched on. I had tried removing the mositure by removing the battery and memory and keeping in sunlight for few hours.Still no luck.
  • 2 more comments
  • Anonymous Jun 06, 2008
    i had the same problem with mine.. it was dropped on a hard surface then worked for 1 month and den suddenly turned off while using it : (
  • angle_baby12 Aug 03, 2008
    W3LL IV HAD TH3 SAM3 3XP3RINC3 CUZ MY DIGITAL KODAK CAM3RA F3LL IN TH3 WAT3R TH3N TH3 N3XT DAY I TRI3D TO TURN IT ON AND IT DID BUT TH3 L3NC3 GOT STUCK AND NOW IT WONT TURN ON =..<
  • arlinpimente Mar 22, 2009
    me to exept mine fell in the sand know it dosnt want to turn on unless i plug to my com....puter
  • Anonymous May 08, 2009
    that happened to me too nit was also it was a kodak cam
    Novelist:
  • 72 Answers
Camera was dropped on a hard deck or into any water solution.
My Answer:
Whether your camera was dropped into any water (or onto a hard deck for that matter) - even for a split second - the damage has already been done. Esp with the "hard deck" drop.
Unless your digital camera is a totally "100% waterproof down to X number of feet" sports digital camera, or quite possibly a "water-resistant" sports digital camera I'm afraid you got water into the "lens barrel" area of the camera and that usually is just as FATAL as getting water into the camera anywhere else as well. Esp if it's SALTWATER!!
Saltwater will destroy any camera (or anything else electronics for that matter) just as bad as leaky batteries will. Once those micro circuit-boards get that acidic saltwater or batt acid on them it's only a matter of time before TOTAL FAILURE.
Sometimes it's immediate, and other times it takes awhile for that saltwater/acid to do it's damage inside. But it will happen - as I know very well from all my years of repairing electronic equipment no matter what it was - Marine environment stuff as well.
See - those saltwater crystals left behind never go away once the water evaporates. Only way to possibly get that saltwater out initially (out of anything electronic dropped in ocean water btw) - with any luck - is to first remove any and all batteries from the damaged electronic item(s).
Next - squirt ALCOHOL (91% or higher rubbing alcohol, or better yet 99% Isopropyl Alcohol) into the openings where you suspect the saltwater got into the camera (or other items) to begin with, and then hold the camera with the lens barrel facing down while shaking the excess Alcohol out. Just letting the excess ALCOHOL drain out by itself won't do, as you need to get out as much as possible thus carrying the saltwater by-chemicals out with it as well.
If you have a compressed air source - no higher then say 20-30 psi, or a LPHV (Low Pressure High Volume) regulated air pressure source - use it instead to forcefully blow out any and all Alcohol as best you can.
Next - take the flushed out camera and open up any access panels, memory card slots, battery port doors, display panels, etc and place the camera in a kitchen oven that uses GAS ONLY, and with ONLY the PILOT LIGHT burning leave the camera in there for no less then a complete week (7 days)! NO LESS then 7 days!
That low PILOT LIGHT ONLY heat temp ( < ~ 110-115F ) will never harm anything electronic (as I use mine all the time to naturally dry things out that have gotten wet for one reason or the other). It will thoroughly dry out the camera insides and hopefully remove all traces of moisture and salt residue! Hopefully!
If you keep using that camera without at least doing the above FIX with Alcohol - after you have exposed it to saltwater - then I'm afraid your camera will have suffered unrecoverable internal damage and will fail totally at some point thereafter.
Saltwater and Electronics DON'T MIX - plain and simple.
Same goes for any camera that has been dropped on the "hard deck".
The guidelines and consequences of a dropped camera are listed below as a general guideline of what NOT to do, what to do afterwords, and what to do to try and prevent a camera drop to begin with.
I'm afraid that "drop", or "small drop", or even that "very big" drop you - or anyone else here posting - spoke/speaks of was more like that of a camera ending life - as related to all digital cameras. No matter how much that ?-year old ???? camera cost when new.
Not all digital cameras are created equal, and if you are an active sports person, or something close to it whereas your camera is subject to or exposed to this kind of rough treatment then you might want to consider doing several things from now on.
Unfortunately it sounds like you dislodged the imagining converting pixel matrix chip and/or the related optical components that convert the optical picture information into digital information that is processed to the memory card for storage.
You may have even possibly dislodged some PC connectors (printed circuit board connectors) inside the camera. Not to mention pulsed servo motor drive components as well.
Each camera is different as to how many individual circuit boards they have inside. Could be 3-4-5 or more. Each is interfaced by a paper thin flat interface type cable and it's possible that particular board cable could be damaged as well. Hard to say. Very very complex inside!
I've had a few destroyed digital cameras apart myself (that people gave me to try and fix) - just to see how they were put together, as I knew they were toast right off the bat in less then 5 mins after looking at them. If it wasn't bad batteries leaking inside and destroying the many smaller circuit boards inside, then it was dislodged and broken parts inside from being dropped.
In any case - each digital camera I had apart WAS NOT worth repairing if taken into an authorized repair dealer or even the main factory repair outlet. Esp if it is/was a SONY!! Sony anything is really not worth the repair charges they want today. Totally ridiculous as they charge you roughly $35-50 today just to even look at whatever is broken of theirs. Then comes the actual repair cost on top of that. I won't buy anything of theirs anymore, as they burned me twice before years ago - and twice was enough....
Not so with Olympus and other digital camera makers! That is why all my cameras today are Olympus because of the GREAT factory warranty or out of warranty service I received past to present. They are the best in my books and I have NO TIES AT ALL to them in nay matter or form!
One thing I should mention here regarding digital cameras in general, as with all 35mm film cameras as well is this.
With digital cameras that cost less then $200 (esp those under $100), and those that are say 3 to 5 years old already - if they break internally for whatever reason (ie: batts leaking - worn out drive motors - dropped camera - water damage - etc) they are considered THROW AWAY CAMERAS and NOT WORTH FIXING. Plain and simple - all sentimental attachment aside btw. Always remove and keep the Memory Cards before throwing out any damaged "beyond repair" camera though. The cards can always (possibly?) be reused on your next digital camera purchase.
With any new camera purchase over $200 it's always an added decision whether to buy the 2 or 3 year EXTENDED WARRANTY - as related to the added cost. I know I would have, and I have done so on my $400+ higher ended Olympus 35mm film camera not only because Olympus builds the best and are renown for their lens QUALITY worldwide, but because I wanted the extra PEACE OF MIND knowing an act of God or Mother Nature could occur at any time. It just made sense to me at that time!
Continued below:
Posted on Aug 29, 2008
  • Frank JR
    Frank JR Aug 29, 2008
    Continuing:
    As an example - I actually had 2 normal use problems with that 35mm
    film camera that were totally covered by that Xtended warranty and one
    involved an R&R of the film drive motor assy due to whatever
    lubrication related reason it decided to bind up and act sticky as
    opposed to normal smooth lens barrel operation, which btw I know would
    have been very expensive had it not been covered for FREE!
    SO - for those reasons above (and a few others) you really only
    have 2 choices here - not knowing what you paid for your digital
    camera brand new, but knowing it's over 3 years old and only you know
    how much use you have on it as well.
    In either case scenario above - your digital camera would have to be
    taken
    in to a Factory Repair Center if you choose to take that
    route. If it were me I would first call the factory direct and see if
    they offer a Blanket Repair Cost option - worst case scenario (dropped
    camera). Then take that quoted option and base it against the actual
    cost of that camera when you bought it brand new.
    If it's even very near, or way over then say 50% of the cost you first
    paid for that now broken camera to begin with - I would pass on even a
    factory repair and just buy another brand new digital camera. Whether
    the same exact model or a newer upgraded model - the latter option
    being better from a compatible software viewpoint!
    I would also ask the Factory Service Center if they had some
    kind of an upgrade option should you decide to take it into their
    facility and then they themselves find out it's really unrepairable
    cost wise? Sometimes they'll offer you this - sometimes they don't -
    doesn't hurt to ask!
    If they want to charge you anything just to look at it - pass on that
    unless they are going to credit you that towards a final repair quote!
    In either case GET a quote before any work is started on it. SONY
    refuses to do this because they are purely MONEY DRIVEN!! Worst CS Dept
    I have ever been to in my life.
    If your camera truly is a total loss then count your losses - lost
    - at this point, and go out and just buy
    another good quality camera of your choice. Prices have dropped a lot
    in the past 4 years. Still buy another camera that uses your same
    original camera memory cards if you can (whatever they are), or else
    upgrade to an XD memory card camera if
    you have to buy all new storage media cards. XD cards are surely
    the best I feel - as far as durability & size goes - no doubt about
    that part!
    If you do decide to go with another new camera this time around - buy a
    good
    quality PADDED case for your camera, and get a good quality " WIDE NECK
    STRAP" not only for the camera's safety, but also for support and
    comfort when actually using the camera. The price of that better
    quality NECK STRAP pays for itself and prevents your camera from
    hitting the deck like it did this time around. It's PRICELESS in my
    book and the best INVESTMENT anyone could ever make!
    Those ridiculous flimsy wrist straps are a big
    NO NO if you really value any camera of yours. I treat my Olympus C-740
    like it was my baby! Literally! Anything you wouldn't do with a real
    life human baby - then you wouldn't do with your camera as well. Goes
    hand in hand!!
    My SAMSONITE brand padded nylon camera case that I found at either
    TARGET or else FRYS Electronic store cost me less then $12, and it
    works just GREAT! Best one I ever found! Holds all my XD memory cards -
    up to (6) total - in the original factory plastic snap cases they come in
    - all in a separate leather zip up case - plus 2 full sets (8 total) of
    Ni-MH rechargeable batts.
    Even though my $300 C-740 camera only cost me ~$155 with tax - after a
    50% store rebate at Office Depot in June of 2005 - I cherish it dearly,
    as I waited a long time for the price to drop on it.
    Just can't be too careful with digital cameras these days.
    Hope this repair/fix feedback has helped you to make a solid decision
    on the next step, as that choice will be yours alone. Sorry - I can't
    help you further.
    Best regards,
    Frank
    Problem Solver:
FE-115 keeps shutting down within 5sec. to black screen
Posted on Oct 17, 2009
My camera fell into the water
What kind of water? If it is sea water it is probably gone as sea water is highly corrosive. Did you immediately remove the battery and leave it out? If not, then the water, which conducts electricity, could have sent over 300 volts from the flash circuit into the rest of the camera and fried a number of circuits. Without seeing the camera it is impossible for me to give any other suggestions
May 13, 2013 | Canon 600D EF-S 18-55 mm IS II DVD EOS...
How to fix the camera is exposed to seawater
Electronic devices do not like salt water, it causes corrosion and electrical short between components especially if the device was turned on.
I would consider your camers a write off.
Apr 25, 2012 | Sony Cameras
My Sony Camera fell in the sea water, can it still be fix? How?
Salt water damage is very bad for electronic devices, especially if the device was switched on at the time when it was dropped into salt water.
The cost of repair if you can get someone to repair it would most like be very expensive.
I would recommend you purchase a new camers, it most likely be a later and better model.
Dec 19, 2011 | Sony Cameras
I dropped my camera in the sea and it wont turn on. is it fixable?
No, sorry. Seawater is every bit as bad as crushing or fire to any unprotected electronic devices.
Your camera is a total loss. The only faint chance of saving it would have been to immediately remove the battery and memory card and to immerse it in a large bucket of de-ionised fresh water (as used in car batteries and steam irons)... not exactly the sort of thing most folks have access to at sea or on the beach. Even then the chances of saving it would have been almost zero.
Sep 02, 2010 | Samsung Cameras
Dsc-s2100
You might want to send your camera to your Sony Authourized Dealer for some technical repair. Since it accidentally fell, there might be a part from your camera that is affected by the sudden hit causing your lense to jammed.
Thank you.
Aug 01, 2010 | Sony Cyber-shot DSC-W50 Digital Camera
L18nikon coolpix got drenched by sea water (a wave).now the screen is blank when started even though it worked well immediately afterwards.it is8.0megapixels 1600antishake AE3.0inch LCD -amritsar
Turning on a wet camera almost certainly will fry the circuits. Salt water will continue to corrode the electronics inside the camera. Start shopping and be careful next time.
Jul 27, 2010 | Nikon COOLPIX L18 Digital Camera
I have dropped the camera in sea water.from then not working.
If you ever do this again then you must immediately rinse the camera in freshwater, remove the battery and get it to a repair outlet immediately. Even then your camera will likely be unrepairable if it shows any symptoms after the accident.
Sea water is about the worst thing you can subject a camera to as it's electrically conductive. When the camera dries out, salt crystals form inside and cause physical damage and chemically attack the camera to corrode it.
Sorry, but in my experienced opinion your camera is a total write off and I don't know any professional repairers who would even attempt to fix this as it would almost certainly have to be returned to them for additional work as more faults show up afterwards.
Oct 23, 2009 | Canon IXUS 860 IS Digital Camera
It fell in sea water puddle and now LCD screen won't work
If you tried turning it on before the water finally evaporated (a week or more), you might have shorted out the screen. Also, after the water evaporates, there is the problem of the salt residue left behind inside the camera. Get a repair estimate to help you decide if it's worth the repair.
Aug 13, 2009 | Sony Cyber-Shot DSC-T1 Digital Camera
My camera fell into water in the beach and it's not coming on
no wonder! he battery would have shorted out first. Beaches are camera destroyers. I would be considering a new camera now as this one will be corroded within a fornight.
You may be able to claim it under home insurance policy as an accident. They will usually allow replacements on personal goods and accidents like this. Definitely worth a try.
Please rate our help to keep the FREE service online++++Thanks for using FIXYA
Aug 09, 2009 | Samsung S760 Digital Camera
As long as the xD card was not formatted it is possible to recover the images that were accidently erased or unable to be downloaded to computer. You can go to the following website link and download an image recovery software program that is free of charge.
http://www.z-a-recovery.com/
You want to download a program called Zero Assumption Recovery. It is a very simple program to use and people have had much success in recovering lost images.
Feb 11, 2009 | Olympus FE-230 Digital Camera
Pentax Optio S5n Digital Camera Logo
3,718 people viewed this question
Top Pentax Cameras Experts
Greg Cann
Greg Cann
Are you a Pentax Camera Expert? Answer questions, earn points and help others
