Question about Zenith R49W36 49" Rear Projection HDTV
Zenith R49w36 problem
I believe the 3d convergence is out on this tv. I have the classic bows on top and bottom of the screen. Where can i get the ICs STK numbers? and is this something that someone should try to fix at home?
  • 34 Answers
Had the same problem with my Zenith TV. Convergence was all out of whack. I purchased a repair Kit from www.TvRepairKits.com The kit had all the parts and simple step by step photos of the repair. At first the repair did not work so I emailed them and within an hour they told me to check two other items. Sure enough they were right! The set is now working perfectly. You guys rock!
I will spread the word.
Louis
Posted on Dec 13, 2009
  • Chris Sep 19, 2011
    What were the other two items? I did the same thing and mine is also not working, what wlse should i check?
  • Zenith Master
  • 8,617 Answers
Most of the zenith R series TVs use the STK392-120 Convergence ICs there are two of them. You can get new replacement ICs at the following link and they include free instalation instructions with pictures so you can do the repair yourself. heres the link.
http://servicemanuals.vstore.ca/
Posted on May 27, 2008
I have a Zenith 54"
You have Bad Convergence ICs they are Big Black ICs and will have the part number on them ,example STK392-570 Mats Electronics has ICs 1-800-628-1118
Jul 03, 2011 | Zenith R49W36 49" Rear Projection HDTV
My rear projection television is showing a double picture with the blue out of allignment. It also shows a bow on the top and a bow on the bottom.
The tv have a problems known as a convergence problems,tv convergence board it is dead.Tv have R,G,B colors lines mis alignments,have colors pictures shadows or 3D pictures look alike?Yes.The tv convergence board it is dead.Must require replacing 2 STK convergence ICS and some or all of it resistors too.To fixed the tv convergence board to solved the tv picture convergence problems.The tv shop,will cost u like $300-350 for parts and labors.
Apr 24, 2011 | Zenith IQC50H95W 50" Rear Projection...
Top and bottom of picture in center of screen dips like a bow tie
The tv have a problems known as a convergence problems,it dead.Tv have colors lines R,G,B mis alignments,have colors shadows pictures or 3D pictures look alike?The tv convergence board is dead.The tv convergence board reqiured changes it 2 STK convergence ICS and some or all of it resistors too.To fixed the tv convergence board problems to solved the tv picture convergence picture problems.The shop,will cost like $300-350 for parts and labors.
Feb 01, 2011 | Mitsubishi WS-65908 TV
Double VIsion on Zenith R49W36
Your TV most likely has a convergence failure. ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
0667c5f.pngSOLUTION
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses. Its a fairly easy DIY job or you can call in a pro. If you want to do the repair yourself check the site www.TvRepairKits.com. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, thermal paste, email/phone support, etc.
Jun 18, 2009 | Zenith R49W36 49" Rear Projection HDTV
I have the Zenith R56W36 56 in. Rear Projection Television, and im getting a 3d affect is there a way to solve this problem?
yes the convergence needs to be repaired. You can get a kit for your model which includes both convergence ICs and all the feed resistors . the kit also includes free instructions so you can do the repair yourself. Heres the link to the proper repair kit for your model.
http://servicemanuals.vstore.ca/product_info.php/pName/r49w36-r56w36-convergence-repair-kit/cName/convergence-repair-kits
Jan 24, 2009 | Zenith R56W36 56" Rear Projection...
Zenith R49W36 Rear Projection TV Convergence IC problem
Had the same problem with my Zenith TV. Convergence was all out of whack. I purchased a repair Kit from www.TvRepairKits.com. The kit had all the parts and simple step by step photos of the repair. I cant thank them enough for making this possible . At first the repair did not work so I emailed them and within an hour they told me to check two other items. Sure enough they were right! The set is now working perfectly.
Thanks Guys, I will spread the word.
Louis
Jul 27, 2008 | Zenith R49W36 49" Rear Projection HDTV
My TV Zenith R49W36
my zenith tv model number r49w36 will come on with sound but no picture can someone please help
Apr 17, 2008 | Zenith R49W36 49" Rear Projection HDTV
Picture is bowed and color is way off
i Would look for a loose connection around the convergence area.
Jan 21, 2008 | Zenith R49W36 49" Rear Projection HDTV
My Zenith rear projection tv. is displaying a 3d image.
Is picture bowed at top and bottom? sounds like convergance problem. Usually the IC's IC2701 and IC2702 along with 1 ohm resistor R2095 and check C2702
Nov 19, 2007 | Zenith R49W36 49" Rear Projection HDTV
Zenith R49W36 49" Rear Projection HDTV Logo
233 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
