Question about Pelonis Disc Furnace Heater
The filter in the back of unit, where can i purchase a new one?
Where do I get the new carbon filter at
Google search for filters by make model and size ,Or check with a local company for the items you have .many filters can be purchased at home improvement stores
May 10, 2017 | Filter Heating & Cooling
Kenmore refrigerator water filter bypass
That is a tough one. You can remove the water hoses from the housing but it won't be easy. Unless the housing itself is broken I don't think I would recommend bypassing it. Now if you really do want to go this route, here's how I would do it.
1) Turn off the supply
2) Carefully remove both lines from housing
3) Using the proper fittings, splice enough line so that you can position the new inline filter at the rear of the unit.
4) Attach the proper quick connect fittings to the new lines.
5) Install the new inline filter .(You may wish to secure the new assembly to the back of the unit)
6) Turn supply back on and check for leaks
As far as which filter, there are many to choose from. I would just get an inexpensive, inline filter made for ice makers. just be sure you get the correct quick connect ends for your new installation.
You can also purchase a complete kit which comes with mounting hardware, a filter and everything you need. This won't be inline though. It will be a separate housing which you will just mount remotely.
Good Luck!
Feb 02, 2014 | Refrigerators
LG washer model wm2301hw won't turn on
We had the same problem (washer would not turn on). The problem was a small fuse blown in the power noise filter unit. The unit is a plastic block near the top of the washer on the inside - connected to the power cord. It is a very commonly produced unit and goes in a number appliances. The fuse inside fails frequently (so I hear) and is extremely difficult to replace due to the protective-covering material so it's easier to just replace the whole unit. I purchased a replacement unit for about $30.
Very easy fix:
1. Unplug the washing machine.
2. Take off the top of the washing machine (two screws in the back)
3. Identify the noise filter unit (top of washing machine, hanging on the right with the power cord attached to it).
4. Remove with one screw and unplug the two cables going into the noise filter unit. Slide out the unit.
5. Put in new unit. Screw it in, and plug the two cables into it.
6. Put the top of the washing machine back on (not necessary to test if the new unit works)
7. Plug in washer and run.
https://www.encompassparts.com/item/7814463/LG_Electronics/6201EC1006L/Filter_Assembly
http://www.amazon.com/LGE-ZENITH-FILTER-ASSEMBLY-6201EC1006L/dp/B006E7V7DW
Oct 18, 2012 | LG WM2301HW Front Load Washer
Polaris 380 wheels not turning
see if filter at wall fitting ok then see if water coming out of jet on back
Aug 02, 2017 | Polaris 380 In Ground Pool Cleaner
4 months after purchase, water still tastes bad. Where's filter?
the filter is in the toe kick behind the round piece
i would chngfe the filter first and see how that helps
Oct 23, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Cracked head unit
Yes warranty will cover manufacturer defect.
Sometimes even if it is out of warranty it is worth it to call the company because of a possible design flaw.
hope this helps
Mar 25, 2009 | Home
Will not ignite after replacing air filters
Clearly a problem with the new filter.
Does it have a check valve built in?
Try to get a flow through it without the nozzle attatched - and often there is a small sintered filter attatched behind the nozzle anyway. take off nozzle and try priming (without igniting obviously).
Could be air in there so needs priming. Often heaters shut down if air is present - so need to be bled of air. If you can pre-fill the filter, or bleed air at a joint just after the filter - this usually works.
Please rate at Fixya if this solves the problem. - It is free, and I improve my score if you do.
Thank you.
Feb 04, 2009 | Reddy Heater-30-55,000 BTU Variable
I have the breville Aqua Fountain AF5 and the red light indicator will not turn on. Can you help as to why the red light will not illuminate.
have you changed the filter ? if its still operating, and you have changed the filter, the (LED) might be burned out, if its a new unit, then take it back where you purchased it and have them replace it, if its an older unit and it still works, then you might have to live with no (LED) , hope that helped
Jan 18, 2009 | Heating & Cooling
Bonaire BCM-645
To replace the filter, follow the steps below
1. Turn the unit off and disconnect from the electrical outlet.
2. Remove the reservoir from the housing.
3. Unlock the housing from the base by turning the lock
knob to the unlocked position
4. Lift the housing straight up and place to the side
5. Unlock the wick holder from the base by turning the
lock knob to the unlocked position
6. Remove the wicks from the wick holder
7. Follow the weekly cleaning instructions.
8. Insert new filters into the wick holder and lock the wick
holder back onto the base.
9. Replace the housing onto the base and lock it into
place.
10.Fill the reservoir and place back into housing.
11.Repeat Operating Instructions It will take about 30 minutes
for the humidifier to reach maximum output. You
can purchase replacement filters (model BWF100 filters)
at your local retailer, by calling 1-800-253-2764, filling
out the accessory card, or by visiting
www.bionaire.com. It is recommended that a
replacement filter is purchased for uninterrupted use.
Here is a link for the manual for your humidifier:
http://www.appliancefactoryparts.com/content/pdfs/117223.pdf
Good Luck.
Apr 24, 2008 | Crane Frog EE-3191 1 Gallon Humidifier
Pelonis Disc Furnace Heater Logo
43 people viewed this question
Top Pelonis Heating & Cooling Experts
Paul Carew
Mack Baxter
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Pelonis Heating and Cooling Expert? Answer questions, earn points and help others
