Question about Home
I BOOKED TICKETS IN TRAIN 2724 KALINDRI EXPRESS FARRUKHABAD TO DELHI ON 3.10.2010 SOME HAS PLACED BIG "TAKHAT" BETWEEN S1 AND S2 BLOCKING TOILETS AND PASSAGE TO0 OTHER COACHES. T.C. COULD NOT HELP. I Have tickets no. 42 -44 in s1 and 33 in s2 passage ansd in s4 also. Passage to co passangers of one family is blocked. ladies tickets is also among these coaches.
  • 321 Answers
SOURCE: Blocked Passage on ERG System,
Very common on Ford engines with EGR codes is the tube inside the intake manifold that takes unburned exhaust gasses and recirculates them back into the engine for reburning,the tube becomes restricted from hydrocarbons and just plugs up.The intake manifold and tube has to be removed and thoroughly cleaned.
Posted on Jul 26, 2008
SOURCE: I got the code p0400 1.
first take the egr valve off then get some carb cleaner spray it into the egr valve ports let sit 30-60min then take a small flat head clean any carbon left over in it. then check the vaccume lines to it they to might be plugged you can take a small wire or push pin and stick it in the ports to unplug it.
Posted on Sep 06, 2008
  • 50 Answers
SOURCE: Oil Passage
oil on any car goes from oil pan to folter before entering engine,dhat will protect engine to get any depozit back in
Posted on Mar 13, 2009
  • 6 Answers
SOURCE: fn key and s1,s2 too not working
well in that case u need to open ur laptop keypad and see if there are not any loose connections
Posted on Jul 05, 2009
  • 13 Answers
SOURCE: How do I remove the doorknob from a weiser passage
Door knobs have an escutcheon plate (The round part that touches the door ) that covers the screws attaching the knob together.
To get the knob off first look along the shaft of the knob ( The straight part between where you grab the knob and the escutcheon) there should either be a allen head screw or just a metal button. If its a button push in on it while you pull the knob away from the door or if its a screw just unscrew it either way the knob will come off.
Now look at the edge of the escutcheon where it touches the door. On some models there's a little detent or hole where you can put a small flat head screwdriver in to pop the escutcheon loose from the plate. If there is no detent or hole then it may be screwed on. Just grab the escutcheon and turn to the left.
Once you get the escutcheon off you'll be able to see the screws that attach the door hardware together. Just make sure to pay attention to how you took it apart so it goes back the same way.
Hope that helps !
Posted on Dec 29, 2009
Raileurope has not received 2 payments of $199.00 each. They have cancelled my train tickets so I have now booked for 3rd time. I hesitate to pay again before train is booked out. Eli-May Tholo
First thing I would do is contact the bank. The next thing I would do is call RailEurope and try it direct with them. If the card is still getting declined then you need to contact your card processor and find out why they are blocking the purchase.
Apr 06, 2016 | Computers & Internet
How can i test marine gyrocompass out put synchro and stepper
SYNCHRO MOTOR HAS THREE WINDINGS LIKE A STAR SOMETHING LIKE A THREE PHASE SAY S1,S2,S3 AND ANOTHER TWO WINDINGS CALLED R1ANDR2 , WHEN YOU SUPPLY EG 110VAC ACROSS R1 AND R2 IT GIVES A SECONDARY VOLTAGE ON THE S1,S2,S3 , SO YOU CAN CHECK IN THE MULTIMETER AC RANGE ACROSS S1-S2,S2-S3 AND S3-S1 , YOU SHOULD GET SAME VOLTAGE ACROSS ALL THESE POINTS .....hope that clears the question
Nov 22, 2014 | Boating
Skmei 0817 black digital watch-user manual
WATCH KEYS: Top RIGHT=S1 Bottom RIGHT=S2 Bottom LEFT=S3 Top LEFT=S4
SKMEI WATCH User Manual Model 0817
Operating instructions:
In normal mode modelDisplay: Week-Minutes-SecondsPress S1 show Month and DatePress S2 button to show Alarm Hours and MinutesModes Covert: Press S3Modes of watch:
In normal display mode: Press S3> chronograph mode (stop watch)>time setting mode>>>(then back to beginning)
Chronograph function:
In normal display mode: Tap S3>enter chronograph mode>
tap S1 to start>
tap S2 to lap time>tap S2 read time>tap S1 to stop>tap S3 to exit tap S1 to stop
tap S2 to reset>tap S1 to start ...then begin againChime of every hour ON/OFF:
In normal mode hold S2 and then tap S3, if all icon of week on means Chime ON, otherwise means off.Alarm Setting:
In normal time Mode, tap S3 twice enter into Alarm setting mode, and the Hours flashing Tap S1 to adjust correct hour of your alarm. Pay attention to AM/PM (Military 24 hour display)Tap S2 the Minutes will flash. Tap S1 to adjust correct minute of your alarmTap S3 to save/exitTime & Date Setting:
In normal time Mode, tap S3 three times to enter Time & Date setting mode and Seconds flashing.Tap S2 and the Minutes will flash. Tap S1 to adjust minutes ("H" is 24 hour format)Tap S2 and the Hours will flash. Tap S1 to adjust the correct hoursTap S2 and the Date will flash. Tap S1 to adjust the correct monthTap S2 and the Weekdays will flash. Tap S1 to adjust the correct days (M=Monday, T=Tuesday...)Tap S3 to save/exit.Back-light setting:
Hold S4 will show all kinds of colors (blue, green, red, cyan, purple, yellow, orange) Just stop hold the button, last color lit will be memorized to set as current back light. 9b7a554e-43c1-4abb-a52d-3caf02dd616f.jpg
Jan 14, 2012 | Watches
Bought a generic clip watch from walmart with no manufacture's name on it. The back says MSP74582W batery CR1616 and then A126. Looking to find instructions on how to set alarm, date, and figure out...
Just got one, and haven't lost the instructions yet. First, the 4 buttons are:
S1 - at 4 - Lap/Rst
S2 - at 2 - St/Stp
S3 - at 8 - Mode
Light - at 10
Watch Control
Normal Display: Hour, Minute, Second
Push S1: Alarm time in Hours and Minutes
Push S2: Month, Date
S3: Change function
Alarm and Chime
In Normal Time Hold S1 and the alarm time will be displayed.
Press S2 once and Hourly chime will be on.
Press S2 twice and Alarm will be on.
Press S2 three times and Chime will be off.
Press S2 four times and Alarm will be off.
Press S1 and display will change to normal time immediately.
Setting Alarm Time
In normal time, hold S3 for about 3 seconds, the hour digit will flash and is advanced by pressing the S1 button. Then push the S2 button to change to minutes and change those by pressing the S1 button as above. Push S3 to return to normal time.
To silence the alarm, press S1.
May 15, 2011 | Watches
How to replace the oxygen sensor
Removal & Installation Upstream HO2 S1 To Remove:
NOTE: If the engine temperature is lower than 120 °F (48 °C), the HO2 S1 sensor may be difficult to remove. Excessive force could possibly damage the threads in the exhaust manifold.
  1. If necessary remove the fuel injector cover.
  2. Disconnect the HO2 S1 sensor electrical connector.
  3. Using an oxygen sensor removal tool carefully remove the heated oxygen sensor.
To Install:
  1. Coat the threads of the oxygen sensor with anti-seize compound
  2. Install the HO2 S1 sensor. Tighten the HO2 S1 sensor to 30 ft lb (41 Nm).
  3. Connect the HO2 S1 sensor connector.
  4. If removed, install the fuel injector cover.
Downstream HO2 S2 To Remove:
NOTE: If the engine temperature is lower than 120 °F (48 °C), the H02 S2 sensor may be difficult to remove. Excessive force could possibly damage the threads in the exhaust pipe.
  1. Raise and safely support the vehicle.
  2. Disconnect the H02 S2 electrical connector.
  3. Using an oxygen sensor tool carefully remove the H02 S2.
To Install:
  1. Coat the threads of the H02 S2 with anti-seize compound.
  2. Using an oxygen sensor tool install the H02 S2. Tighten the sensor to 30 ft lb (41 Nm).
  3. Connect the H02 S2 sensor electrical connector.
  4. Lower the vehicle.
Oct 07, 2010 | 2001 Buick Regal
Sir i have booked 3 tickets from air inida express through online in that i have entered my passport number wrong whethere it may cause any problem for me on travel can u help me
Yes it could do, if this website you ordered your tickets from has a support link, such as contact us, click on it and look for a phone number or email address and contact them, hope this helps
Feb 06, 2010 | Zebex ZBA AIRLINE TICKETS MAGNETIC SWIPE...
Can't set time on aqualite watch-field ranger
I have an aqualite field ranger watch too. I lost the information but I found another notice for another watch and I was able to set the TIME as well as the alarm. I am not despairing as to one day set the date correctly! ;-)
The instructions I found are for "LIFELONG Chrono Alarm Sport watch" from Hanig & Company. The watch this particular instructions comes from has a rectangle LCD display that only takes the center of the dial, and only 3 buttons for the functions.
Aqualite has 4 buttons, but one of them is only for lighting the dial only, therefore if we use the 3 other buttons the same way they are described in this manual, it will work.
Aqualite has 4 buttons:
1) top right (we will call it S1 like this manual does)
2) bottom right (this will be S2)
3) bottom left (this will be S3)
As I said the number 4) (top left) is only for light and we will forget it since it is not needed to set our watch.
Setting the minutes, hour, date month and day:
Press S3 3 times, or until the following are flashing in the display : TU and seconds
Set the minute: press S2 once and advance by pressing S1
Set the hour: press S2 and advance by pressing S1
Choose from AM (A), PM (P) or military time (H)
Set the date: Press S2 and advance by pressing S1
Set the month: Press S2 and advance by pressing S1
Set the day Press S2 and advance by pressing S1
Press S3 to bring you to the time display
Setting the chronograph:
The chronograph feature will store and add to the last recorded time interval up to 23 hours, 59 minutes and 59 seconds in the time display.
1. Press S3 (flashing in the display: SU, FR, SA)
2. Press S1 to begin. Press S1 to stop.
3. press S3 to return to the time display.
Setting the lap time:
The lap feature will record from 1/100th of a second up to 23 hours, 59 minutes and 59 seconds.
In the time display.
1. Press S3 (flashing in the display: SU, FR. SA)
2. Press S2 to clear setting
3. Press S1 to begin. Press S2 to stop.
4. Press S1 once and S2 twice to reset.
5. Press S3 to return to the time display.
Setting the alarm and snooze:
The time alarm features with a convenient snooze function which will sound 5 minutes after the first alarm in the time display.
1. Press S3 twice for the alarm mode (hour will be flashing): advance by pressing S1
2. Press S2 once (minute will be flashing)
3. Press S3 to set alarm and return to time display
3. Press S1 to deactivate alarm
5. After 5 minutes, snooze alarm will ring. Pres S2 to deactivate.
6. Press S1 and S2 at the same time to deactivate the alarm at any time.
To test alarm
In the time display
1. press S1 and S2 simultaneously for alarm test.
Hourly chime
Your chrono alarm sport watch ha the option of an hourly chime in the time display.
1 Press S2 and then press S3 to activate hourly chime
2. Repeat process to deactivate
Jul 23, 2009 | Watches
Hi, i got a toshiba S1 PT831C with 1500Mhz cpu. Now my S2 died, so i placed the memory from the S2 in the S1, that worked, but now also the proc, even if its 100Mhz faster than the old one (its the same...
Its the same type of processor but the thing is their different speeds and one cold be hit by the mobo processor limiter and thats whats casuing it to not show up right, since you flashed the bios it nothing more to do. its onlya prob if you start having issues its nothing to worry aout other than that.
Jun 16, 2009 | Toshiba Tecra S1 Notebook
Watch Problems
PROVIDE US HERE THE WATCH MODEL..
AND ALSO PROVIDE A DETAILED PICTURE IF POSSIBLE...
Sep 17, 2008 | Watches
Home Logo
133 people viewed this question
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
