Question about Canon Cameras
I have a Canon Power shot S3 . Can I use a Sigma AF-Mf zoom lens 100-300mm to it. If Yes, what type adapter to use.? I also have a 35-80mm canon lens. can this be used ? Thanks.
    Brigadier General:
  • 3,006 Answers
Your camera is a fixed lens compact model. You cannot fit other lenses to it unless they are specifically designed as supplementary lenses which screw onto the existing lens filter thread.
There are no adaptors you can safely use either, the only ones would be lens reversing rings which are used to mount lenses backwards for ultra close-up macrophotography, but the weight of the lenses you propose on the end of your existing lens would break your camera.
If you wish to use interchangeable lenses then you need to obtain an SLR or an interchangeable lens rangefinder camera.
Posted on Oct 04, 2010
My rebel T1i won't take pictures on AF
If you have a specific zoom lens on and it will take shots in MF manual focus but wont in AF auto focus you could have a broken ribbon connector in the lens. Try with another zoom lens if you get the same problem it could be the camera. If it works OK then the ribbon in the affected lens may need replacing.
Jun 16, 2014 | Canon EOS 500D / Digital Rebel T1i Digital...
Does Sigma 70-300mm f/4-5.6 DG Macro Telephoto Zoom Lens fit canon eos rebel
Sigma makes their lenses with a variety of camera mounts. If you get the lens with a Canon mount then yes, it will fit any EOS Rebel camera body. A lens with a Pentax mount, for example, will not fit a Canon camera.
Nov 24, 2012 | Sigma AF 70-300mm f/4.0-5.6 DL Macro Super...
Where can i buy a Sigma 70-300mm f/4-5.6 DL Macro AF Lens mount adapter for a canonEOS 500D
You can't, not as far as I know.
Getting functionally useful adaptors from any other brand to Canon EOS is difficult as the register distance from the sensor to the lens is the deepest of all current lens mounts. Adaptors therefore require expensive optical correction in order to preserve infinity focus ability and given that the adapted lens will still be substantially crippled most owners aren't prepared to pay for such an adaptor. In any case, the additional optical elements will reduce optical quality.
Due to similar electronics, it is possible to physically convert a Sigma mount lens to EOS by fitting an EOS lens bayonet but it's a skilled job requiring fabrication skills and even then there's no guarantee that the lens will communicate correctly with all EOS bodies. In practice, due to the scarcity of Sigma mount lenses the conversion is usually the other way around.
Sep 15, 2010 | Sigma AF 70-300mm f/4.0-5.6 DL Macro Super...
Would this lens work with my digital canon xs?Sigma 70-300mm f/4-5.6 Macro AF zoom lens for Canon EF film cameras
yes ef stands for electric focus which is what your camera mounting should be check your mounting to make sure its EF and if it is go for it. also the mounting type might be in your hand book
Apr 17, 2009 | Canon EOS Digital Rebel XS / 1000D IS...
Matching 2 brands
Simga makes lenses to fit several different makes of camera bodies including Canon and Nikon. I'm assuming your Sigma lens has a Nikon mount, if so there are some adapters, but they may not work like you want - not all functions may work properly thru the adapter. For best results you should return or sell the lens and get one with the Canon mount.
Dec 26, 2008 | Canon Rebel XT / EOS 350D Digital Camera
X 2 converter
  1. with this combination of camera/lens you will not have AF when a x2 converter is applied! that is because in all canon cameras (except 1D series) there is no AF when the Aperture is smaller then F5.6.
  2. if you don't mind using MF, u need the sigma 2x EX DG Tele Converter.
Sep 30, 2008 | Sigma Cameras
Lens lock
When I connect my AF Sigma lens to my Canon DSLR camera, the viewer reads MF while in AF mode.
What's the cause of this?
Jul 15, 2008 | Sigma 28-300mm f/3.5-6.3 Macro for Nikon-D...
Autofocus
Make sure you have the switch on the side of the lens that has the options "MF" and "AF" (or something like that) switched to "AF"
Nov 27, 2007 | Sigma AF 70-300mm f/4.0-5.6 DL Macro Super...
Cameras Logo
64 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
