Question about Kenmore HE2 Plus Front Load Washer
Rl error message - Kenmore HE2 Plus Front Load Washer
Asdf asdf asdf
Posted on Oct 04, 2010
I have a 2004 acura rl and my radio is showing CODE error... What do I do
try disconnecting the battery so the connection to the radio is broken then reconnect and enter code
should work as long as the unit does not lock up if too many failures are registered
Jul 17, 2015 | 2004 Acura 3.5RL
What does an rL error mean?
The rl code is displayed when the control detects a load of clothes in the washer during the clean washer cycle.
This code should only come up when you're trying to run a clean cycle.
There can be two causes for this message if there are no clothes in the washer while you're running the clean washer cycle.
The most serious cause of the problem would be the spin bearing. Try and turn the basket by hand and see if you fill any restrictions. The basket can drab because of the bearing or because there are clothes between the spin basket and outer tub. Turn the basket by hand and see if you notice anything.
You can also try to remove the belt and run the clean cycle and see if the problem repeats. If the code doesn't repeat with the belt off and there is nothing between the tub and spin basket most likely the spin bearing will have to be replaced. The bearing is part of the rear half of the tub and will require a complete tear down to change.
If the message rl repeats with the belt off then the most likely cause of this problem is the machine control board.
Mar 10, 2014 | Kenmore HE2 Plus Front Load Washer
Got an error code rl. Took the clothes out, now know re-start procedures
Hello, the rl error code means that at the start of the cycle a load is detected inside the drum, and what you have to do is to remove the cloth from the drum and start the cycle again.
Thanks
Jun 10, 2010 | Maytag Neptune MAH5500B Front Load Washer
How do I reset the maintenance required message on
With ignition off, press and hold "SELECT" and "RESET" buttons on dash and turn ignition to the "ON" position. Continue to hold until lamp resets.
Dec 15, 2009 | 2005 Acura RL
Error message 6A00 comes up following boot up.
Following his speech on e-book security, Dmitry Sklyarov, a 27-year-old Russian ... stub is simply a built-in executable provided to display an error message (e.g. ...informit.com/guides/content.aspx?g=security&seqNum=18&rl=1
Dec 03, 2009 | Canon PIXMA MP830 All-In-One InkJet...
My kenmore HE2plus washer gives an error code (rL) when we try to do the cleaning cycle.
The rL error code during the clean cycle is likely caused by friction on the spin basket shaft since you indicate that you hear squeaking when the washer is spinning.
The squeaking is normally caused by a bad bearing in the rear tub shell.
I recommend that you have the washer diagnosed and repaired by a Sears service technician.
This type of problem will normally require an extensive tear down of the washer to repair.
It is not a problem that you can normally repair yourself.
Open the door & slowly rotate the spin basket to see if you can feel any kind of drag on the bearings.
If the bearings check good, the control board is sensing a load & will need to be replaced.
http://media.fotki.com/1_p,sqfgswqgwssgwfwxgtqsskgwtqkq,vi/ssfqsqssrxkbbdrggfw/1/1303472/5961857/image34400img-or.jpg
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Oct 19, 2009 | Kenmore HE2 Plus Front Load Washer
My empty washer keeps giving me an rl error while trying to run cleaning cycle
Sep 26, 2009 | Kenmore Elite HE5t Washer
2005 Acura RL maintenance required message
with the ignition switch off, press and hold the select/reset buttons. while holding the buttons turn the ignition to on, keep holding buttons untill the light shuts off.
Jun 15, 2009 | 1998 Acura RL
Soltek sl-k8trpro939, error message BIOS not Loaded,
To clear cmos you'll need to remove the cmos battery from the motherboard for about 5-10 seconds then replace. You need your motherboard disk in order to load the bios. If you do not have this disk then you will need to go to the board manufacturer's website & download the bios. Follow the directions they have at the site to make a bootable disk & then boot from this disk. Hope this helps & please remember to rate my answer. Thanks.
Jan 25, 2009 | Soltek SL-KT600-RL Motherboard
We get an rl error code when attempting to clean washer. Why and what does it mean?
Is there some thing in the washer ?
rl error
If at the start of the CLEANING WASHER cycle a load is
detected inside the drum.
NOTE: Detects by weight.
Possible Causes/Procedure
Remove clothes from drum and start the cycle again.
Aug 15, 2008 | Washing Machines
Kenmore HE2 Plus Front Load Washer Logo
Sal DeAngelo
fordexpert
Ed Mac
