Question about Husqvarna Garden
I have a Husqvarna 125E edger....primer is priming...replaced rotten fuel line..removed carb..cleaned all ports and was really clean in the first place....will crank and run as long as your in the throttle but after about a minute or less of running it sounds as it is starving of fuel and will die...I have 2 of these and one the motor locked up on so i removed the carb off of it and it is doing the dame thing making me think that it is something other than the carbs...kinda loosing my mind on this one...really ticking me off to be honest bc I can usually fix whatever is broke!!!!!
  • Roy Cagle
    Roy Cagle Oct 03, 2010
    Have you tried taking apart and cleaning the carb? Sometimes (you may know) rotten fuel lines will break up and allow small pieces to enter the fuel system. Check that ole fine filter mesh screen in the fuel pump side of the carburetor. That's the side with the idle-speed screw on it. Post back, I would like to help and find out the problem.
  • David H Apr 01, 2013
    Had the same issue and it really seemed like the carb. Turned out to be a defective spark plag that would run until warm (10-20 seconds) and then stall out like out of fuel. Go with the Bosch plug.
  • 109 Answers
SOURCE: Snapper SS312 weed eater. Cranks when primed but won't run
I am sorry to say this, but the compression for that type of engine should be atleast 120 psi. Remove the muffler and look at the cylinder, it is scarred beyond repair.
Posted on Apr 22, 2009
  • 115 Answers
SOURCE: primer pump rotten need replacement show parts page
The hoses run through a hole into the gas tank, they are fitted with a filter inside the tank. Drain the tank, and manipulate the hose end to where you can grab it throught he filler hole, Remove the filter, run new gas lines into the tank and through the filler hole to replace the filter, reattach to the carburator. The primer bulb should have 4 small screws attaching it to the carburator. Remove the screws, place in new primer bulb, and you should be back to trimming asap.
Posted on Jul 06, 2009
AUTODOC01
  • 216 Answers
SOURCE: Edger #125E stalls after 3-4 second of starting.
sounds as thou the carb plate gaskets are torn these are sandwiched on eithewr side of the carb and they let it pump/**** the fuel a rebuild kit will have theses new gaskets depending on how mech/ inclined you are you may just want to let a shop fix it $75?? thats what i charge
Posted on Aug 26, 2009
  • 150 Answers
SOURCE: runs on starting fluid, not
Try spraying a little gas where you spray starter fluid. If it runs you may have to install diaphram kit. If it has a choke can get around primer not working.
Posted on Oct 01, 2010
  • 640 Answers
SOURCE: Replaced the primer bulb and
Chances are the primer bulb is hooked up backwards, I did that once, made me feel pretty foolish.
Posted on Jul 29, 2011
Trimmer won't prime to start
Look inside the tank. Some units have a stone inside that blocks the fuel line when it is tipped a certain way. Might be what's happening here.
Aug 13, 2016 | Garden
Ryobi 410 mini tiller w/Walbro WT149A primer bulb won't prime. New bulb, new fuel lines, hooked up right, carb cleaned. Been sitting for several years.Runs when fuel is pumped into the fuel inlet.
hello sir, my machine will only start when pumping primmer bulb or squirting fluid in the carburetor than stops. the fuel line has broken off, in most small carburetors this is a ongoing problem.old fuel will crystallize when left in tank for a long time.plugging up ports, fuel lines, small screen in carburetor.fuel lines will dissolve clogging carb.this is why it will run when the choke is on creating a vacuum to where there is fuel forced in the carb to rum,also the gas will evaporate leaving the oil behind clogging up carb.the thing to do is remove carb. and clean out,replacing gaskets or fuel line if necessary.use carb cleaner to clean out carb.make sure to make note where fuel line go.the fuel filter broke off of fuel line letting debris get in carb plugging it up.the muffler is known to clog up a lot on these machines where they want run. the compression should be 60 to 120 lbs any thing below 60 is junk. when adjusting the carb screws turn in all the way than turnout 1 1/4 turns turn in slow until machine runs also you need to check for spark by removing plug and grounding against engine to check spark, ok.a new spark plug would be a good ideal too , if you are going to make these repairs use new fuel line and filter,hope this helps,any comments welcome,thank you, !!
Feb 21, 2012 | Garden
Craftman blower/ changed the fuel lines/ cleaned the filters/ still no fuel in to the primer
Clean your carb and make sure your needle and seat are also clean and the screen inside carb at inlet of fuel, also the primer has a check valve inside it that gums up, try to spray carb clean or sea foams deep creep I like it seems to loosen up the check valve and remember normally fuel line with filter goes on nipple at pump side of carb and other nipple goes to suction side of primer and other nipple goes to tank as a return line ...so as you prime it, this causes fuel to be sucked thru carb and back to tank 2StrokeJim
May 18, 2011 | Craftsman 25cc Gas Line Trimmer
31cc Poulan Pro Weedeater
Sounds as though the fuel filter may be plugged. The filter is in the tank. Take a look, see if it is visible. Remove and replace. Good luck...Lee
Jul 26, 2010 | Poulan 25cc 2-Cycle Gas Powered String...
Fuel starvation on Husqvarna 322l trimmer. Has run great for 10 years this year but now starts great but then rps drop and it shuts off. Pump the primer a few times it will only run on the fuel from the...
Gunner, you may want to;
inspect the lines for pinches or cracks,
clean or replace the fuel filter
replace the carburetor fuel pump diphragms/gaskets, and inlet needle
remove any adjustment needle for cleaning with a spray carb cleaner
Nov 08, 2009 | Husqvarna Garden
Primer bulb does not fill or prime when pushed.
the carb is probabbbly clogged alsocheck the fuel filter in the bottom of the tank fish it out with a peice of wire and clean it blowit out with are might be clogeed ? if not take offcab carefully and remove side covers and get you a can of carb claener with a straw and blow out the ports ? good luck
Aug 26, 2009 | Craftsman 25cc Gas Line Trimmer
Replacing fuel tank on craftsman edger and other fuel lines.......do not understand where to hook fuel lines back up?  any diagrams?
ok If you have a Walbro WT series carb "without" a built on primer bulb here it is. First off if the fuel lines disintegrated you MUST disassemble it and clean it out. The MOST infintesimle speck of gas line trapped, can allow good prime and bad operation. OK? Don't be lazy on this. Just be delicate removing the flaps gasket and diaphram. ZAMA GND-12 Is the replacement Gasket and diaphram kit fot that carb. Use a cleaner, compressed air or blow good thru it. OK Now...Primer bulb, Carb, and Fuel tank, re connects: Smaller Diameter line comes from Gas tank (Connect filter screen to this in tank) to the short Straight brass carb connector. Primer bulb suction goes to the bent carb brass connector. If small line brings fuel "in" this other line sucks it back "Thru the primer bulb" and the blow side of the primer bulb sends it back to the fuel tank! So...Small Line brings fuel "TO/IN" carb thru short brass connect on carb. Other carb connect goes to bulb suction "IN", Then primer bulb "Pressure OUT" goes thru the larger tube "back to fuel tank". Trust me I know how frustrating a simple diagram is to find online fo this set up. And if you have a carb problem on top of the hook up uncertainty you got frustration. Not only was online help hard to find (Mfg...etc NFG at all!) My local repairshop in BBrook NJ could not tell me how!!! and thats no lie! Walbro has a "generic" carb diagram but no "hook up info" specifically. Poulan don't list it either. And these things routinly fall to pcs. all 3 of mine crumpled together on yr. 3 of use.
Jun 15, 2009 | Poulan 25cc 2-Cycle Gas Powered String...
Troy Bilt TB 465SS Pony 4 cycle weed trimmer won't start
Sounds like you need to take the carb. apart and clean it. I like to use a Den Tek Brush, (used for cleaning teeth), to clean the small ports in carb. they work great for this job. Make sure to either clean or replace the small screen in thcarb. as well.
Jim
May 24, 2009 | Troy Bilt Tb70ss Gas Trimmer
Craftsman trimmer won't prime
A new carburetor would be simplest solution. You could try disassembling the carb, cleaning and replacing diaphrams, but just replacing the carb would be my choice. What is the model # on the trimmer and I can tell you the part # of the carb you need.
May 24, 2009 | Craftsman 25cc Gas Line Trimmer
Garden Logo
366 people viewed this question
Top Husqvarna Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
