Question about Garden
I have a 1045 cub. It tried to start and then nothing. The fuse was blown. I replaced it and when I turned the switch it blow again. I tried it 4 times with new fuses and blew each time. Could the starter have a short. Bill
  • jbsanzone Oct 04, 2010
    I had a repair shop pick up the lawn mower on a trailer. When it got there it was working fine. they are checking further to see if they can find out why.
    Bill
    Genius:
  • 1,478 Answers
You will need to check the stater, there is a wire bridge with the starter, that is why the fuse keep blowing,i will advice you replace the starter to fix the problem.
Take care.
Posted on Oct 03, 2010
Why does the fuse keep blowing on my cub cadet ltx 1050
A fuse blows because the circuit it provide power to has a shorted component or wire.
May 16, 2017 | Cars & Trucks
LT1046 cub cadet blown clutch..what caused this with new Pto switchpto switch froze..replaced it still will not engage blades.what could blow the new clutch
Are you sure it's blown? Run two jumper wires from the battery or power side of the starter solenoid and energize the clutch. If it energizes and clicks, that's eliminated. Did you blow any fuses?
Jun 16, 2016 | Cub Cadet Garden
LT 1045. Why no start, no crank?
you need to replace your battery with a brand new one. because you old battery can not handle anymore the power it needs to crank your engine.
Sep 03, 2015 | Cub Cadet Garden
Keeps blowing fuse
There are several things that can cause the fuse to blow. PTO stands for Power Take Off and most likely this will not be the problem unless it blows the fuse when it is turned on. What you are saying is the fuse is blowing by just turning on the switch will be a short which can be anything from a pinched wire, shorted diode, short in the stator. bad voltage regulator.etc
Apr 17, 2014 | Cub Cadet Lawn Mower Electric PTO Clutch...
I have a cub cadet lt1554, when engage the pto the engine cuts off, fuse blows
near the engine where the wire goes to the clutch there is a plug unplug that connector and try the switch again if the fuse blows the problem is in the wiring if not the short is after the connector i have seen the wire going into the clutch rub on the clutch housing and i have been able to repair it
Jun 02, 2012 | Cub Cadet Garden
I have a cub cadet 2165, it was running great, turned it off-nothing happens when I try to start it, no clicking, nothing- checked battery cables-tight, checked for broken or loose wires-nothing-HELP
Hi
You blew a fuse. The easiest fuse to get to is under the hood and next to the gas tank. Replace it with the same fuse. Make sure the tractor is in neutral, blades are not engaged and the brakes are set. Should start right up. If not, you've blown a different fuse or a switch has gone bad. A reputable repair person is needed then.
May 20, 2010 | Peg Perego Cub Cadet Tractor
Cub Cadet LT 1045 - Not starting, the engine does not turn.
remove the starter...use jumper cables to "run the starter manually...red to big lug, black to body (anywhere is fine) should torque hard at initial run and continue to run smooth...if it buzzes or vibrates, it's bad...replace...
Apr 10, 2010 | Cub Cadet Street Sign- tractor lawn riding...
Cub cadet 2135 wont start
check for a fuse behind the ignition
it might be blown
then i would check the starter solenoid
if you put a screwdriver accross the bolts that hold the wire from the starter and ignition switch and it tries to start there's ur problem.
Jul 30, 2009 | Cub Cadet Street Sign- tractor lawn riding...
Cub cadet dead as a door nail
I have the same mower. The wires do need to be connected. It is a safety feature on the cubs. The engine will not start if the electric PTO is engaged. I just went into the garage, pulled the pto lever out to engage, pushed down brake, tried to start and it would not start. I suggest reattatching the wires and trying it. Hope this helps.
Apr 24, 2009 | Cub Cadet Street Sign- tractor lawn riding...
Garden Logo
20 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
