Question about Maytag Legacy Series Top Load Washer
Our machine is leaking, spilling water, which comes out the bottom of the machine?
  • 905 Answers
Hi
You likely have a drain line that has come loose between the tub and the pump, or the small hose for the level detection has come off.
Pull the washer out, remove access panel, and you should be able to see where it is leaking from, even if you have to tilt it forward.
Posted on Oct 03, 2010
Leaks water from bottom
Is it really from the BOTTOM, or is it spilling out the overflow holes in the back, then running down to the counter? If it's just spilling out the overflow holes, don't put quite so much water into it.
If it's really leaking from the bottom, and it happens even if you put only one or two cups of water into it, then the little hose running from the heating element inside up to the top filter has cracked or come off. You can fix that by opening the bottom of the coffeemaker (UNPLUGGED FROM THE WALL). You'll see where the rubber hose connects to the heating element and runs up along the rear tank. Check the connection where it attaches to the heating element.
Jul 31, 2014 | Gevalia CM-500 12 Cup Coffee Maker
Water won't come into the dishwasher
The anti flood system could have been triggered due to a water leak or spill at the bottom of the washer, This device (polysireene float and micro switch) when triggered shuts off the inlet water and puts the washer in pump out mode only. Use a torch and check if a small amout of water is causing the float to trigger the microswitch attached to the float. If a small amount of water leak / spill is causing this you need to first fix the spill / leak. before you try again.
Apr 21, 2010 | Crosley 24 in. CDU600 Built-in Dishwasher
Water leaking out of bottom of machine
either tub has leak or bottom seal is bad. you may have to go in from behind washer. View here for more info and don't hesistate to ask more questions:
http://www.howstuffworks.com/search.php?terms=washer+repair
Oct 01, 2009 | Hotpoint Ultima WD72 Front Load...
Water leak from bottom
then you may be leaking from the water pump. maybe is worn out, only way to find it is to remove the cabinet an do a load test an see if it comes from there, if the hoses are fine then check the pump.
May 13, 2009 | Maytag LAT3600A Top Load Washer
Bosch WFCM 3200 Front load washer leaking from bottom of machine
I would try pulling the machine away from the wall and taking the back panel off. Get yourself a torch and then settle down on the floor while the machine runs a short cycle and wait to find out for certain where the water is coming from and at what stage of the cycle the leak happens.
Safety notes: Turn the power off while removing or refitting the back panel. Keep your hands away from wires and terminals when the power is on, and keep your hands and hair well away from the drive belt while the machine is on!
Once you know where the water is coming from and when, it'll be a lot easier to know what to do about it.
A.
May 27, 2008 | Bosch WFMC 3200 Front Load Washer
Kenmore front loader 44832
1)right wont be a water surge if the water is coming from underneath washer when it is switched of could be that you have a leak and what it is doing is water is collect around the bottom and then spilling over so tip washer back fill it up and see were its coming from, 2)your hot water valve could be sticking on which in that case needs replacing take your lid off and when washer is off try and listen for water flowing through pipe
Aug 13, 2007 | Kenmore 44102 Front Load Washer
Coffee machine is leaking from bottom
the rubber seal for your coffee machine need to be replace.
Mar 29, 2007 | DeLonghi DC60T Coffee Maker
Washing Machines Logo
561 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
