Kenmore elite sm 9711034a As clearly as I can discern, it rinses, spins for the final cycle but agitator and initial water filling and wash cycle wont work.
  • dan_huddart Oct 03, 2010
    actually i found the knob on the front panel that controls the water temp for the wash cycle was disconnected and once I plugged that in, it began agitating for the wash cycle and filling up.
  • 2,272 Answers
Its a very common issue. The washer will go through the rinsing process and tries to spin further for the final cycle to be completed and then just suddenly stops. This happens when a timer goes faulty. To solve the problem the timer(timer module or mechanical timer unit) needs to be replaced.
Thanks. Keep updated for any more query. You can rate this solution and show your appreciation.
Posted on Oct 03, 2010
  • raj somaiya
    raj somaiya Oct 03, 2010
    great. kindly rate the solution positively.thanks for your appreciation.
Kenmore Washer Doesn't Agitate
Don't be too sure the drive coupler hasn't failed or is failing
Jun 15, 2013 | Kenmore 24032\24036 Top Load Washer
Please describe a typical washing cycle to me on the RTW4440XQ Roper 3.1 Cu. Ft. Top-Load Washer, please.
The typical cycle is;
fills to selected water level
agitates wash cycle
drains wash water
spins wash cycle
fills to selected water level on rinse cycle
agitates on rinse cycle
drains rinse water
spins final time
end of cycle
Aug 08, 2011 | Roper Washing Machines
Our Kenmore Model 110 - 82980120, Stock 29801, 118 G is giving a problem with the Automatic Process. It does not move by itself. It stays at the same place it is kept. If Kept at Wash it stays there, if...
The cycle doesn't advance When the cycle doesn't advance, it's probably the timer or a cold-water supply problem: It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer. It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
Jan 21, 2010 | Kenmore Washing Machines
Machine doesnot agitate or drain once filled with water
it sounds like a bad lid switch if it will not drain or spin,the switch controls that-mike
Apr 24, 2009 | Washing Machines
Kenmore Model 110.26712693 stuck on agitator cycle
Your air pressure hose going to the water level switch is pinched.
Open the top control panel to access the clear plastic tube and relieve the pinched area.
Apr 12, 2009 | Kenmore 22422 Top Load Washer
As washer was on final spin cycle it sounded like a belt came....
  • It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer.
  • It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
Apr 01, 2009 | Kenmore Washing Machines
Kenmore front-load washer stops at rinse cycle
When the washer initially fills for the wash, is it only hot water entering the drum? Try switching the water temperature between hot and cold as it fills. If any of them show little or no water getting through, it sounds too easy but check to make sure water supply taps are on, and that the cold/hot fill hoses aren't reversed. Remove the fill hoses and check any of the screen filters for blockage (in the hoses and in the inlet water valve). When the machine stops and waits to fill but all you hear is a hum, it sounds like there is power going to the valve but water is not able to get through it.
Mar 03, 2009 | Kenmore 43142 Front Load Washer
Will not move to the next cycle.
  • Jan 07, 2009 | Kenmore 24032\24036 Top Load Washer
    I have a kenmore elite washing machine and the spin cycle will not work.it both fills up and drains water but it wont spin.
    I have a kenmore elite washer. whwn on spin cycle it does not spin and als o will no agitate. There is a loud noise wen on spin cycle. Please help
    Dec 20, 2008 | Kenmore 24032\24036 Top Load Washer
    Washing Machines Logo
    134 people viewed this question
    Top Washing Machines Experts
