Question about Smoothfitness Smooth Fitness 9.35HR Treadmill
Treadmill won`t power on - Smoothfitness Smooth Fitness 9.35HR Treadmill
    Genius:
  • 1,416 Answers
check on the power supply from the main source ,if every think look to be okay then put it off for some time then put it on but if the problem remain then carefully unscrew the screw on the main power supply connected treadmill to locate the fuse.
However the problem can be view from two point
1 from the fuse and
2 from the wire connection
After locating the fuse then remove the fuse and then replace it with another fuse to test run the fuse if it has gone bad if the problem still remain the it then mean that the problem is from the wire connection
thanks.
Posted on Oct 03, 2010
Reebok power run treadmill
adjust the REED swtich, see the diagram attached.clean it, and tight the connector very well. God bless you
If the problem persist, tight the ribbon cable inside the control panel, and clean it too. Otherwise you have a control panel faulty8da47572-fa1c-4850-ad85-b0d8c94bdf71.gif
Jul 22, 2013 | Exercise & Fitness
It doesn't turn on
follow this steps and fix it. God bless you
Mar 24, 2013 | Sportsart Fitness TR32 Treadmill
Reebok z8 won't turn on
see the video and fix it. see too the block diagram
God bless you
Jan 19, 2013 | Exercise & Fitness
Bowflex TC5000 won't start! Lights on circuit board show power.
see the video and proceed according and fix it. God bless you
Jan 08, 2013 | Bowflex Tc5000 Climber Treadclimber...
Proform 560 crosstrainer treadmill powers on belt won't turn
LUBE THE deck belt+ rollers bearing too. God bless you
proceed according with the video attached.
Jan 07, 2013 | Proform Exercise & Fitness
The treadmill on my Roger Black Gold Treadmill won't move when the power is on. The board lights up and the incline etc works but the treadmill just won't move. Can anyone help me please?
please see the video and proceed according, LUBE the rollers bearing very IMPORTANT!
However , if the problem persist your must test a) main motor+belt
b) main control motor board see the block diagram attached.
God bless you
Jan 04, 2013 | Exercise & Fitness
Incline won't shut off
Please RUN The software calibration for diagnose, troubleshooting and fix it.
download your inst.manual from www.iconservice.com or www.fitness.manualsonline.com and proceed according
God bless you
Jul 18, 2012 | Icon Proform 560 Crosstrainer Treadmill
I have an Ifit treadmill. I was changing speeds and it turned off and won't restart. It beeps when i turn it on but no lights on console.
Power issues with ProForm treadmills fit into two categories: the power does not turn on or the power shuts off when using the treadmill. If the power will not turn on, make sure that the treadmill is plugged into a working power outlet. In addition, you should use a single-outlet surge protector for the treadmill. Single-outlet surge protectors protect the machine from any voltage changes that may occur in your home.
If the machine is plugged into a working outlet, make sure the safety key is in the keyhole on the console. If the safety key is not plugged into the machine or if it is pulled out during operation, the treadmill will not operate.
Finally, make sure the circuit breaker located on the frame near the power cord is set to "Reset." The circuit breaker is set to "Reset" if the top of the button is pushed in. When the breaker is tripped, push it back to the "Reset" position and wait five minutes before powering on the treadmill.
If the ProForm treadmill shuts off during operation, check the power cord and circuit breaker as described above. You can also try removing and reinserting the safety key.
Increase Engine Horse Power.
Jun 02, 2012 | Proform Exercise & Fitness
Treadmill buttons don't work right. TV won't turn off. Treadbelt won't run.
1) Try to reconnect the plug between console and pcboard very well.
2)Clean the contacts with special contact cleanear( radio schack or computer store) with carefully only the buttons, if you can open the cover better.
3) adjust the Sensor SWITHC.
4) Look for any wire loose, or making bad contact, or break wiring( continuity) test the fuse and breaker.
If after you did those steps, and the problem persist, the console board is faulty.but first change the sensor switch, you must be shure after adjustment.11_18_2011_12_23_17_am.gif
Nov 17, 2011 | Exercise & Fitness
Smoothfitness Smooth Fitness 9.35HR Treadmill Logo
199 people viewed this question
Top Smoothfitness Exercise & Fitness Experts
Electro Med Services...
Howard
Howard
Tom Chichester
Are you a Smoothfitness Exercise and Fitnes Expert? Answer questions, earn points and help others
