Question about Ovens
Opticook Microwave Model Y79. What does error ER:02 mean ? Thank you
Self-clean-mode not working, I get the "door" error message
are you sure it is an auto lock door and not a manual locking type .
Oct 22, 2015 | GE Ovens
Dacor wall oven MORD230 cont'd beeping,disconnecting power to unit did't work,error code 01 appear on display
Hello. The error means there is a shorted key on the keypad. The part number you will need is 701044-02, called "membrane panel assembly, black". The main board, if needed, is 101991, called LED display module. Hope I helped you!
Aug 21, 2015 | Dacor Ovens
What means er 07 at Ariston electric oven FD 87.1 E and how can I fix the problem?
THE E USUALY STANDS FOR ERROR THE O7 IS THE ERROR WHICH COULD BE IN THE OVEN,BROILER, OR BURNERS, OR EVEN A TIMER. LOOK UP ON LINE TYPE IN FD87.1 ELECTRIC OVEN MANUAL TO SEE IF A MANUAL IS AVAILABLE THAT YOU MAY BE ABLE TO FIND THE PROBLEM.
Jan 31, 2015 | Ariston Technologies Ovens
My microwave oven (ms143sce) is displaying this error " - S E - " . None of the buttons want to work, if pressed nothing happens ?!?
It means shorted key panel. You need to replace it. I suggest going to Repair Clinic, enter the microwave's model number. See if they have the replacement touch pad for you.
Thank you for using Fixya and you generous rating will be much appreciated.
Oct 20, 2010 | Ovens
Hi -- I have a double Impinger conveyor pizza oven. The top digital oven display started reading Er:in this morning... why??? PLEASE help! Thank you.
Usually the first error code will indicate that the temp. sensor in the oven has failed. (the long wire-like device) Since it is one of the cheaper parts and generally easiest to procure and install, try replacing it first. Good luck, Dale
Oct 17, 2010 | Ovens
Model ME302ES/02 getting an E218 error code- what does it mean?
that code is detecting a failure with the cooling fan
Jul 10, 2010 | Thermador Ovens
Gas stove with electric starter
regardless of electrical supply to home you can always match light you stovetop incases of power failure, your bake and broil would be compromised by lack of electricity.
Oct 23, 2008 | Ovens
GE Advantium Microwave portion not working
There is a fuse for the Hi voltage transformer and the magnetron tube. You have to take the cover off to access the fuse.
Sep 02, 2017 | GE ZSC2001FSS Advantium Electric Single...
KEMC308KBL01
send me am e mail at b4829@yahoo.com with the model number
May 31, 2008 | KitchenAid Architect Series KEMC308KSS...
Need exact model No for JKP85 Double Oven
unfortunately there are hundereds of ge microwave/oven combs that start with jkp85. do you know what part hes looking for? some parts are more common than others. i have many sources for part number if i know what he needs i can try to give you the number
Nov 25, 2007 | GE JKP85 Electric Double Oven
Ovens Logo
236 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
