Question about Panasonic Cameras
Lumix DMC-TZ1 says Please turn camera off and then on again. This does not fix the problem
  • 2 more comments
  • Anonymous Jun 23, 2008
    please turn camera off and then on again
    have tried removing battery and trying to reset
  • Anonymous Mar 13, 2014
    requires turning camera off and on again but simply repeats the error
  • Anonymous Mar 23, 2014
    asas above requires e shutdown restart
I had the same problem. I turned on and off several times with the same message and issue. It appears to be a lens issue. I hit it several times firmly on the bottom with my hand while on and must have jarred something loose because it started to function again. Whew!!!!!!!
Posted on Sep 10, 2008
3 Suggested Answers
  • 11967 Answers
SOURCE: Lumix DMC-TZ1 Memory Card Error
Try formatting the new card in the camera. Also, download any pics from the old card using a card reader and then, format it in the camera.
Posted on Apr 16, 2010
caroldon
  • 17130 Answers
SOURCE: camera screen saying 'Please turn
It is possible that the error is due to failure of the camera's main control system. You can remove battery and card replace battery and while switching on tap the lens hood on your hands so as to disengage any dirt or mechanism being struck.
The fault seems likely that the camera can have a stuck up mechanism or a jammed shutter. Hence unless you are familiar with handling of small devices must the camera be opened. If so check the voltage on the motor drive, check the auto focus and Zoom drives, it must be free with manual movement. If jammed the motor can be removed and realased. If none of these works then you can think of taking consensus with the service centre.
Get estimate before you decide. It will be good to have it checked at the authorised service as you do not have to run around for spares.
Posted on Jul 29, 2011
Hi bi currently have a Problem with my Panasonic Lumix DMC-TZ50 Digital Camera the Flash seems to have stopped working? any clues how i can fix it and will it cost much? Regards Pete
The flash of my Panasonic DMC-TZ1 camera has stopped working normally - it flashes but the image is dummy. Could it be its falshing lamp is reaching its recources after working 3 years? Can it be changed?
Jan 28, 2011 | Panasonic Lumix DMC-TZ1 Digital Camera
Apr 16, 2010 | Panasonic Lumix DMC-TZ1 Digital Camera
Need replacement installation CD (Mac version) for Lumix DMC-TZ1
The easiest way to download your pics to a Mac is to use a card reader. You can transfer the pics to a folder you create on your desktop and view them from there or import them to iphoto.
Jan 31, 2010 | Panasonic Lumix DMC-TZ1 Digital Camera
When i turn my camera on it tells me to turn it off then on again
Lens is jammed. Replace the lens to fix the problem. Parts and repair are available at most online auction houses.
Jan 09, 2009 | Panasonic Lumix DMC-TZ1 Digital Camera
Lumix DMC TZ1
Sarge,
Do you still have the camera? Did you get it fixed? It not is the LCD screen in good condition. Would like to buy if you haven't gotten it fixed.
Jul 03, 2008 | Panasonic Lumix DMC-TZ1 Digital Camera
Please turn camera off and then on again after a couple of seconds
Hello friends,
My Panasonic Lumix dig. camera Screen is showing the message that pl. switch off the cametra and on again. when i did the same again I face the same problem. Pl. help me to solve the problem
Apr 24, 2008 | Panasonic Lumix DMC-TZ1 Digital Camera
Help Please!!! Cannot view some pictures in my Panasonic Lumix DMC-TZ1
some of your picture was currapt ,during the transfer from camera to PC the current was unstable or some connot read by your computer.
Nov 12, 2007 | Panasonic Lumix DMC-TZ1 Digital Camera
Cameras Logo
1,661 people viewed this question
Top Panasonic Cameras Experts
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
