Question about Bose (321GS) System
I have a Boise AV28 Media Center and the video flickers when you try to play a DVD I was adjusting sound, and hit a button on the remote which caused the flickerig as I was in the settings menu. Is there a reset button or an adjustment to correct this problem? If not, what are my options?
Inside the settings there is an option for video output, you may have switched it by accident. If you can still see the menu enough go into settings. I would try first: Video > Video Connector > Component/Composite and switch between the two. Otherwise try the NTSC or PAL settings. GOOD LUCK!
Posted on Oct 06, 2010
Dvd stuck bose ls28
Only a Bose repair technician can get the stuck CD out of the DVD ROM.
Jan 26, 2013 | Bose Lifestyle 28 Av28 Media Center With...
Cant get movie to come on.it says to hit play button.cant find any such button.picture comes on but that is it
The Polaroid TDA-03211C has the Play/Pause and Stop/Eject buttons on the TV on the side of the TV near the DVD slot. They are separate from the other control buttons. (They are closer to the back of the TV relative to the DVD slot with the stop button the lower of the two. The play button is just below the media card slot behind the DVD slot.) The original remote also a Play button (center two rows above the channel and volume toggle buttons).
The manual for the TDA-03211C is available as a PDF from HDTV solutions: http://www.hdtvsolutions.com/pdf/tda03211c_ug_en.pdf . See page 12 (page 14 of the pdf) for the controls on the TV and page 14 (page 16 of the pdf) for pictures of the remote.
I hope this helps.
Sep 04, 2011 | Polaroid TDA-03211C 32 in. LCD HDTV
I have the bose av28 media center, life style 28, remote broke, i have a time warner clikr 5 universal remote can this control the bose 28 ?
No, only the Bose remotes will work with it! Bose doesn't let any other remote to work on their systems.
Dec 26, 2010 | Bose Lifestyle 28 System
I have a sony STR-DE897 and my rear speakers dont get sound when plugged into the surround back ports..Is there a certain setting in order for the rear surround spreakers to work? or does that mean the...
There are a few things required for the rear surround channels to operate;
1. The surround back channels must be enabled in the surround setup menu.
2. The media being played through the receiver must have audio encoded for the rear surround
channels. There are only a few exceptions to this but I'll exclude the explanation for simplicity.
3. The audio level of the speaker channels must be set high enough to be audible.
Enter the surround setup menu with your remote. Use the center button on the remote to toggle through the selections, press down on it to enter the selection.
You will navigate to a selection in the surround setup menu that says "surround back" or S/B with a selectable yes or no indication. Press on the center button to enable them.
Media like DVD or Blu-ray that has 6.1 or 7.1 channel audio has separate, or often referred to as "discrete" or "matrixed" audio intended for playback through surround rear speakers, depending on the music or movie. If your media is encoded for 5.1, then there will be no audio sent to these speakers. However, with the different modes of on-board digital processing of this receiver you can still have audio through these speakers.
Last but not least is the actual playing level of these rear surround channels. They may simply be adjusted to quietly. Enter the setup menu with remote, choose "level" and navigate to the rear surround channels. You can adjust the level up or down in 1/2 dB level increments by toggling left or right with the center button. Each surround channel can and should be adjusted independently and equally.
Dec 14, 2010 | Sony STR-DE897 Receiver
How do i turn on the media center buttons?
Yo can create custom shortcut by doing the following : Start > All Programs > Windows Media Center, and right click on it. Select properties. Under "target" you will see "%windir%\ehome\ehshell.exe".
Simply add the switches you wish Media Center to start with and hit OK. For example, if your shortcut looked like the following: %windir%\Ehome\Ehshell.exe /nostartupanimation /noshutdownui /mediamode
Hope this helps.
Here is a list bellow.
/nostartupanimation stops the startup sound and Windows Media Center logo "pebble" going off into the distance /noshutdownui removes the "shutdown" item from the tasks menu /mediamode starts in media only mode (no close/minimize/maximize options in top right corner) /widescreen start in widescreen mode, even on 4:3 display (windowed only) /nochrome display windowed mode Media Center but without the window chrome /playallmusic plays all your music instantly /playfavslideshow plays your favorite slideshows only /playfavslideshowwithmusic plays your favorite slideshow with music /playslideshow plays all slideshows /playslideshowwithmusic plays all slideshows with music /screensaver starts the Media Center screensaver /configuress starts Media Center at the "configure screensaver" screen
Feb 10, 2010 | Gateway M-6866 15.4" Widescreen Laptop...
Bose av28 access menu using control buttons
when this happened to me,,,I found out it meant that the video decoding ASIC was out....I could not get any DVD's to play to the TV, and finally, the "settings" menu would not go on the television screen....this means you need to have the mainboard replaced, and after twice doing this,,,,the Tech on the phone told me that the Video Decoding ASIC is very susceptible to power spikes,,,so I put a big APC filter in front of it....
Jul 06, 2009 | Bose Lifestyle 28 System
Play dvd nothing - play s/d card (video) sound but no picture.
You need to update the dvd softwear. Check the default settings for playback of media,if it is set to windows media it won't work if you hav'nt installed the correct updates. Choose the Toshiba dvd player as the default player and it should work. If you prefer windows media then you can get the updated codecs from ' free-codecs.com ' Easier still,try uninstalling your windows media player and installing windows media 11, this will usually resolve the problem.
Oct 25, 2008 | Toshiba Satellite A100-S8111TD Notebook
TV will turn on, but not respond
Good Day, mistymiles;
Try this before calling a factory authorized service center:
Press " menu 2 > 4 > 7 > 0 > enter", on remote. After settings have been initialized > press the system reset button on the front, once the LED stops blinking > reprogram settings and tuner channels (if not using box). IF NOT fixed call for service (get estimate before repair) and suspect repair of DM PCB (printed circuit board).
Good Luck, big IRISH.
Jul 31, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Lost directions on how to hook up my Bose model AV28 media center
Go to Bose' website and click on "support". See if that helps out...accordianman
Feb 26, 2008 | Bose (321GS) System
Bose (321GS) System Logo
122 people viewed this question
Top Bose Audio Players & Recorders Experts
Invebo
Level 1 Expert
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
