Question about Panasonic SC-PT660 Theater System
I have a panasonic PT760, and it has worked great for a year, I moved and put it in a storage box in my room for a motnh, and now there is no power to the system. I think That I might just have to hit a reset, or change a fuse. would you know where they are, or what to try first.
I have the same problem. Le t me know if you find any solution
Posted on Dec 09, 2010
Panasonic sa-pt770 will not power on
When power is applied do you get any LED light or display that shows?
Dec 27, 2014 | Panasonic Sa-pt770 Receiver
Panasonic Home T, sa-pt760, message LOCKED
While the unit is on, press and hold the play button and the power button, display should say unlocked. If this doesn't work, try it using the stop button and power button.
Apr 03, 2013 | Panasonic Audio Players & Recorders
Chgr error on my panasonic pt760 discs will not eject
Lock123 already solved my problem great service no wait time your site is the best one out
Jan 24, 2010 | Panasonic SC-PT960 Theater System with...
I have a Panasonic SC-PT760 that won't turn on!
if it was stored in a damp area it may take awhile for it to turn on until it dries out.most units have a dew protection sensor on them
Jan 17, 2010 | Panasonic SC-PT770 Theater System with...
Cooling does not work either
Get in there with a vacuum and clean up the condenser coils then check the compressor relay. If all those are fine bypass the cold control just long enough to see if the water cooler works. Do not leave it bypassed or damage to the reservoir could occur.
Aug 31, 2009 | Hamilton Beach Water Cooler with Storage...
My Panasonic SC-PT760 system just doesn't sound right. It sounds perfect with every function besides the AUX. Music and DVD's sound how I think a surround sound system should work but my LG HDTV sounds...
it definetly sounds like their is a set-up issue or a grounding issue , refer to your user manual for reference to check your wires ,also bad buzzing sound also comes from cheap rca cables that you might be using for components to your system ,also sometimes the end jacks of the rca get worn out and don,t provide good conductivity , auxillary inputs should be used for playstations or x boxes and not for anything else , hopefully this was helpful, sincerely Glenn
Mar 02, 2009 | Audio Players & Recorders
I just bought a dvd home theater system sc-pt760 and i have a 42 inch LG flat screen and the sound wount work on AUX for the TV
Are you using the HDMI connection on both units, the SC-PT760 does have a HDMI input Yes/NO ? If not then it has HDMI output to the LG for HD Picture. What I would do if no HDMI INPUT to the SC-PT760 is available, run out of the TV with the Digital connection into the SC-PT760 Digital Audio in, assign the input as tv and you shoild get TV audio out of your home theatre, you could also use the analog connection audio out of the tv to the home theatre but this would not yield a dolby digital sound.
Feb 02, 2009 | Panasonic Home Theater System System
Sc-pt760 "chgr err"
For panasonic sc-pt760, if the DVD player is busted, you can't access the option to switch to Digital in. With Digital in, you can still use the unit as a sound system by feeding it through the optical input from your TV.
but, the trick, You can't access the switch menu without an ipod. For some reason, you can switch from an Ipod to your D-in. You can't switch out of AM/FM to d-in as it tries to access the broken DVD first.
Jul 02, 2008 | Panasonic Home Theater System System
Panasonic SC-PT660 Theater System Logo
391 people viewed this question
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
