Question about Dopod C730
Where can i buy new battery for my dopod phone model c370. how much the battey and original charger? i brought in pawnshop no accessories. can u send me a picture of your mobile phones.. thankz and more power...
5 Suggested Answers
SOURCE: manual default for dopod 577w
Sorry for you. I guess your display driver is gone. That's why you only see blank white screen.
Posted on Sep 14, 2007
SOURCE: I have a problem with my cell phone Dopod 818 pro [HTC] that it has lost its English Language
sumsung j700
Posted on Jul 18, 2008
SOURCE: Driver for Dopod 838?
yesssss
Posted on Apr 09, 2010
anandg27
  • 1272 Answers
SOURCE: Dopod 838 Pro Window Mobile 6.5 user manual.
Please download the dopod 838 manual from the below link:
http://www.htc.com/sea/userguide.aspx?p_id=37
Hope this helps.
Regards
Anand
Posted on May 02, 2010
Input 120v 60hz 25w output 3VDC 1500 mA I need a new transformer for an Acuvibe plug in class 2 Model D3-15A
Buy a generic multi voltage charger or any cell phone charger (they run on 3 volts) from a local electronics store or cell phone accessory shop, then solder and shrink tube your charging adapter onto the leak on the charger. You most likely can't buy the original charger. When you install the old charger end on the new charger end that plugs into your device make sure you pay attention to the polarity, one lead is market with a white stripe, one with none.
Sep 13, 2016 | Brookstone Mini USB Personal Massager
Tip
Phone is always low on power
If your phone appears to have problems retaining power, the problem may be with the phone, the battery, or the charger.
  • Check that you are using an original Nokia battery and charger compatible with your phone model. You can check compatible models from the Accessories section. If your battery features a hologram label, you can authenticate that the battery is an original Nokia product with our Check Your Battery service.
  • If you have access to another battery and charger of the same type as yours, try substituting them to determine if the issue is with the phone, the battery, or the charger.
  • Even high-quality batteries like Nokia's will eventually lose power retention capacity. If it is time to replace your battery with a new one, be sure to purchase an original Nokia battery from an authorized Nokia dealer.
If you are unable to test your phone, charger, or battery or need further assistance, please bring them to a Nokia Care point for inspection.
on Sep 13, 2010 | Cell Phones
Samsung galaxy Battery problem.
Most phone repair shops have batteries. Be sure you buy an original one. But before you think the battery is bad, check if you don't have too many apps opened. Try to close all apps you allowed to poll for data or location. There must be lots of other things that can be wrong. It would be disappointing if when placed a new battery, you have the same time to use it, because of what I said.
Success.
Please next time place it in the category phones and not between digital cameras
Jan 04, 2014 | Cameras
Normally when you plug the charger in something appears on the screen to show its charging. Well nothing is coming up on the screen. On the side a red light flashes sometimes. Can you please tell me whats...
There are three possible solutions to your problem.
1) The battery needs to be replaced; or
2) The charger needs to be replaced. (If you have a car charger, you can use it to rule out if the problem is your wall charger.) or
3) Your mobile phone needs to be returned for repair.
If you found this information helpful, please give me a big thumbs up when you rate my answer. Thank you.
Feb 02, 2010 | Sony Ericsson Cyber-shot C905 Cell Phone
Hi, I have a motorizr Z3 phone whose charger failed. I have run out of warranty and hence I went to a store and the guy gave me another Motorola Charger that is of 6.5 Volts. My original charger was of 5.0...
hi, you need to get the same charger if the output is to high then the phone wont put the charge into the battery as it could cause it to over heat, the best place to buy one from would be the well known online auction site you should get one from their for next to nothing and this will then solve the problem.
You know the battery is not at fault as it charges from your computer via the usb lead however the charger you have brought should still charger the battery but may cause it to over heat so to me it seems like their is a fault with the new charger. Its always best to buy the exact type of charger you had in the first place as this ensures the battery is charged properly.
What phone makers do is keep the same charge connector across most of their range of phone but as phones and technology changes they start using different batteries in their phone so they have to change the charging power to match the phones battery, so the charger you have brought is probably for a newer phone with a higher voltage battery, so you need to get the correct type of charger and this will then solve your problem.
Or if you have a car you could buy a car charger as these charge the phone alot quicker as they run off 12volt so put out more amps to the phone but keeping the volts at the correct type.
Let me know how you get on or if you need further assistance ok
Jan 27, 2010 | Motorola Mobility MOTORIZR Z3 Cellular...
Invalid battery..
There is too much going on here. For starters, you should only be using Motorola accessories IE batteries, chargers, screen protectors. Now that you have done this, you have actually confused the phone, it is a "smart phone" and because of this, it is able to identify the different battery/charger. You have to send this to Motorola of for a quick fix or buy a new phone.
Oct 11, 2009 | Motorola Mobility MOTOROKR E6
Not charging 1100 nokia phone
The problem of your phone is the charger or the battery, if your battery is the original one which with your phone as you purchased, it then for sure the problem is your p[hone charger...troubleshoot? I'm sorry but no available troubleshoot for that for now, what you need for your problem is to buy a new charger and make sure it is a nokia 1100 charger or it is compatible for your phone.
Another thing is it should be high quality cause it is impossible for now to buy an original battery except if you buy it with a new phone....I hope I have help you with this,and by the way...kindly rate this solution according to the benefits obtain. It will be much appreciated, Thank you!
Oct 02, 2008 | Cell Phones
PDA replacement
does your company have a website? Im intrested in a qtek 1010 screen.
Apr 05, 2008 | Apple iPhone Smartphone
Dopod C730 Logo
32 people viewed this question
Top Dopod Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Dopod Computer and Internet Expert? Answer questions, earn points and help others
