Question about Maytag HYE3657A Electric Dryer
Drier noise There is a regular banging noise even when the drier is empty. We wanted to lift the top to see what was loose. How do we get the top up?
    Problem Solver:
  • 4 Answers
Lifting the top should be pretty simple. There is an obvious lip that runs all the way around the dryer where the top hinges down and fits on the other body panels. Look between the lid & the front panel on the front of the dryer. A few inches from either front corner there is a metal clip that interlocks with the front panel (If the lip is squeezed together to tightly to see between, just get a putty knife or another thin-yet-sturdy object & work it between the two pieces until you barely see between them.). Once you locate the two clips, get two thin knives or putty tools & push inward from the front on both of the clips. When you have the clips fully disengaged you should be able to lift the lid by prying upwards very gently. Sometimes it takes a little wiggling to get them disengaged, so do not forcefully pry as this can bend the pieces, causing a poor fit or cosmetic damage.
It will be much easier to locate the noise if you take the front panel off as well. From the top your view is obstructed almost completely by the tub. There are normally only 2 or 4 screws near the top on the inside connecting the front panel. Just remove those screws & lift up on the front. Everything should be much easier to inspect. While you are in there, vacuum all the lint out (there's usually lots). Doing so will help airflow & lower the chances of an accidental fire.
I hope this helps you out. I have a similar model & it did not take me very long to figure it out. Hopefully you'll have the same luck!
Posted on Jun 01, 2008
Why when i push the start button on my dryer and it tries to start spinning the drum but doesnt. sounds like doesnt want to start spinning
There is a belt on the drum that can break or come off the pulleys. You can access it by checking for screws that hold the whole top of the drier down. If there are none, pry up the top with your hands by lifting. You will be able to see the whole inside of the drier. If you are going to be reaching into the machine, unplug it first.
Jul 31, 2014 | Frigidaire FEX831F Top Load Stacked Washer...
Clunking noise
open the door.........hold drum at the top and see if it lifts up a bit................if it does.......the bearing on the drum will be knackerd..............cheers
Apr 15, 2014 | Samsung DV330AE Dryer
Mtd4 mistral
Underneath where the motor is,, there is a locking mechanism, which is operated by a cable connected too the lid, check cable hasn't snapped or come off,, it's adjustable also,, may just need adjusting
Jun 17, 2013 | Creda S202pw Debonair Spin Dryer Drier 9lb...
Make Frigidaire dryer model Gleq2152es1 is making a loud sqealing noise and the clothes getting hung in top of dryer.
mostly the noise your hearing is the drum running on the side of machine .the baering/bearings have collapsed in your drier . Most driers these days have the bearing encased in the outer drum and i mean molded to the outer drum . You cant replace them and the manufacturer doesn`t really want you to . Sorry about that = looks like a new drier for you .
Aug 13, 2011 | Frigidaire GLEQ2152ES Electric Dryer
Zanussi tc470 condenser drier Red light is staying on even after the water container is emptied. switch appears to be faulty
excess water seems to be lodged in the drier and was drained out.There is a drain at the rear of the machine. I am concidering connecting a pipe here and draining permently to the outside.
Dec 28, 2009 | Dryers
Amana electric dryer will heat but only when.../ LEA60AW
It seems there is some wire loose, check on the both side of heating element points.
The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter.
Good Luck!!
Thanks
Jun 22, 2009 | Amana Dryers
Zanussi condenser drier: tank full light on even though empty
its either going to be fluff in the float which you can get at by taken the side panel off .or its fluff in the valve behind the water tank
Jan 11, 2009 | Zanussi TC7114W Electric Dryer
Maytag neptune dc
I have a Maytag Neptune drying center. The top unit is making a very loud banging noise. How can it be repaired, is this a common problem?
Apr 18, 2008 | Maytag Neptune MDE5500AY Electric Dryer
Need a diagram to change heating element and sensors
unplug the drier pull it out from the wall about a foot facing the drier take a small putty knife and insert it about 3" from the edge push the knife in till you feel the spring clip push in on it and lift the top then repeat that on the other side fold the top back till it leans against the wall look in the drier on the front edge of the front door panel there are two 5\16 in screws there remove them and un plug the light switch and the door switch assembly .grasp the front door panel and give it a quick snap forward to disengage the retaining clips and the door from the drum remove the door .Lay on the floor reach in and remove the belt from the idler pulley and blower motor pulley .Then while standing at the side of the drier grasp the belt with one hand and the front of the drier drum with the other and **** up sharply on the belt to release the drier drum from the rear drum bearing then remove the drum out the front on the rear you will see the heating element there will be one sensor on the heater pan that's the safety or high limit thermostat the tiny one on the drier body is the thermal overload the one on the vent at the bottom is the operating thermostat but its rare to have a problem with them if the drier is not heating the first thing i recommend is check your voltage and connections and don't assume just because its running its getting full voltage check it with a meter driers will run on 110 but will not heat without 220
Mar 10, 2008 | Frigidaire GLER341A Electric Dryer
Maytag HYE3657A Electric Dryer Logo
80 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
