Question about AT&T TL92328 - Cordless Phone
AT&T Model TL92328 - After not quite two years, two of the handsets died. The menu blanked out and the phone no longer works. Putting in new batteries only affected one of them and that one would still cut out to yield a blank screen and the battery (on the charger for over 16 hrs when battery first put in) had to be disconnected and reconnected to get the menu to reappear for a while and then blank out. Overall, I'm disappointed with the reliability of this particular model of phone. Now, I find that I'm not able to purchase replacement handsets for this model phone on the AT&T web site. Now faced with the prospect of getting a whole new set of phones and not really considering AT&T if they are only going to last less than two years.
  • 23 Answers
SOURCE: 2355 at&t phone
you will need to call att or manage your phone online at
Posted on Jul 11, 2007
  • 274 Answers
SOURCE: phone loses connection after few minutes
I looked up the battery specs for your phone. They are 3 X 200mah= 600mah battery packs. They should last 8 hrs talk time with the headsets. This style of battery pack in my experience only last about 1 1/2years and sometimes longer and "sometimes" shorter...much shorter. I bet you never had problems when you first got them. Basicly this "battery design arrangment" goes back many years before newer battery technlogy was developed. But designers still insist on using them even today. They are cheap to make. ****Time to replace them with new ones.**** Make sure you follow the mfgs charging instructions: "After battery installation, place the handsets in their base unit or charger and allow to charge for 16 hours before use. You can keep the battery charged by returning the handsets to their base unit or charger after each use. When the battery is fully depleted, a recharge takes about 12 hours. Average talk time on a fully charged battery is about eight hours depending on environmental conditions, standby time is approximately four days." Good luck
Posted on Jul 19, 2007
SOURCE: AT&T Model # 1487 Phone
Go to the above web site. It helped me.
Posted on Mar 24, 2008
SOURCE: AT&T phone model E5634B
SOLUTION to AT&T Cordless Telephone/Answering System 4 phone set Model E5634B - Cannot answer incoming calls nor does caller ID work on phones.
Unplug the base for a few minutes, plug base back in, remove and reinsert the battery on each phone that does not work, then place each handset in the base for few minutes. Worked for me...all 4 phones can be answered and caller ID works!!! Hope this works for you... :o)
Posted on May 13, 2008
SOURCE: phone not charging even with new batteries
Reboot your phone system. I'm not kidding. Unplug base from power and phone line for 1/2 hour and unplug battery from phone.
Posted on May 19, 2009
At&t lg prime gs390 free unlock codes
Please see below instructions in details on how to unlock code for LG phones, (i have included various model of LG for you to try)
Here are some unlock codes for AT&T LG phone available, menawhile , including the methods of entering the Unlock Code on your LG phones attached to them. Hope this is useful. AT&T cell phone Questions&Answetrs
Model : AT&T LG VU CU915 & CU920
1. Put a AT&T or Cingular SIM in the phone; it does not have to be an active SIM 2. Enter *#865625# then the 16 digit unlock code 3. Device should say: Network Lock Deactivated 4. Phone may automatically reboot and is now unlocked !
Model :AT&T LG C2000
Insert non-Cingular SIM card Power on the handset - phone will display "phone restricted" Select "Cancel" - phone will display "phone restriction code" Enter the SIM Unlock code. Select "OK" - the handset is now successfully unlocked
Model : LG TU720 - LG CU720 and all LG Shine SERIES
1) Power ON your phone with an accepted SIM card 2) Type *#865625#UNLOCK CODE 3) Press OK 4) Device is now unlocked
Model : LG CE110
1) Put a non AT&T or Cingular SIM in the phone; 2) The phone display: Invalid Smart Chip 3) Power on handset 4) Select "Cancel" - phone displays "phone restriction code" 5) Enter the unlock code (8 digit code*) 6) Select "OK'" - the handset is successfully unlocked
Model : LG CU400
1 - Insert non-Cingular SIM card" 2 - Power on the handset - Phone will display "Invalid SmartChip" 3 - Phone will display "Invalid SmartChip" 4 - Enter 159753#*# 5 - Enter the 8 digit SIM Unlock code 6 - Select "OK" 7 - The handset is now successfully unlocked
Model : LG CU500
1 - Insert non-Cingular SIM card" 2 - Power on the handset - Phone will display "Invalid SmartChip" (IF THE PHONE DOES NOT DISPLAY INVALID SMARTCHIP, PLEASE POWER OFF AND ON AGAIN) 3 - In Idle screen, enter 159753#*#. Phone will display "Enter NCK, Remaining 5 4 - Enter the 8 digit SIM Unlock code 5 - Select "OK" 6 - The handset is now successfully unlocked
How to Unlock LG CU515:
1-Insert non-Cingular SIM card" 2-Power on the handset - Phone will display "Invalid SmartChip". 3-Enter *#865625# then select option 1 and then again select 1 4-Enter the 16 digit SIM Unlock code 5-Device should say: Network Lock Deactivated 6-The handset is unlocked. 7-How to Enter Unlock Codes on CU575 (Trax) How to Enter Unlock Codes on LG F2250:
1-With allowed sim card in the start menu type: 2945#*3311#. 2-Handset shows saved, then return to startup screen 3-Press Menu key, choose Settings > Security > Sim Lock> Network > Deactivate, handset will now show 'Enter NCK' 4-Enter your unlock code and OK. How to Enter Unlock Codes on LG U8110:
1-With a not allowed sim card in your phone enter Pin code then validate, type: 277634#*# 2-Select 'Sim Unlock' menu # 3-Enter NCK code then validate 4-Your phone is now unlocked. How to Enter Unlock Codes on LG U8210:
1-With a not allowed sim card enter Pin code then validate, type: 277634#*# 2-Shows test menu 3-Choose sim test menu and type: 2945#*#, choose Sim Unlock menu 4-Handset shows 'Enter NCK' 5-Enter code, then hit OK. How to Enter Unlock Codes on LG U81xx:
1-To bring up the unlock menu on the phone with a SIM card, type 2945#*88110# 2-Enter the code 3-In case you need to reset the phone without a SIM card first, type 277634#*# or 47328545454#. If your cell phone is not listed, please follow instructions for LG C2000 above
If If instruction above does not help you i would strogly suggest to contact your Service Provider to provide some alternatives.
Thank you for using fixya
Please rate me and give testimonials if ever to continue my assistance
Jun 03, 2011 | LG Cell Phones
The photo slide show is now blank. I have a GE model 27956 DECT6.0 Cordless Handset with Caller ID & Slide Show. I can not view or add new photos to the slideshow. I pushed the reset button, but it...
To fix this issue:
1. Unplug the Unit
2. Unplug the Phone Cord
3. Disconnect the Battery from the Handset
4. Wait 10-15 minutes… and put back together in Reverse Order
5. Connect the Handset Battery
6. Plug-in the Phone Cord
7. Plug-in the Unit
You can do this w/o the phone cord attached.
Dec 30, 2009 | GE Lands Phones
Panasonic Kx th112 sceen is dead answer light blinks red
Try swapping the AC adaptor from one of the handsets with the adaptor from the base unit. That fixed my problem.
Jul 21, 2009 | Lands Phones
Uniden TRU888 5.8 Digital Phone Display no longer lights up
I purchased this model phone as a refurb item and also had display blanking out issues. Mine related to a problem with the battery, which new batteries fixed. Try swapping the batteries between handsets and see if the fault moves to the other handset, which will prove if it is a battery problem. Otherwise, it would seem to be an internal fault in that handset. Try and arrange repair/replacement from the seller.
Jun 21, 2009 | Uniden TRU8888 Corded Phone
Handset(receiver) Lucent Corded Phone Model932 blanks out during phone call
After 10 years of service, and allowing for the fact that Lucent is no longer around, it may be best to simply replace it.
Dec 17, 2017 | Lands Phones
Battery Dies
Part number 23-270 at your local radioshack. Sells for 14.99. Good luck. And make sure you charge the new battery for 8-12 hours.
Sep 14, 2007 | Panasonic KX TG2570 Cordless Phone
Handset wont register
To register the handset:
1. make sure phone is charged
2. hold down the "mute/program button on the phone 10 seconds.
3. you should see a message on the screen that says you need to push the "pager button" on the handset.
4. Push the pager button
Apr 10, 2007 | Uniden Cordless Phone
AT&T TL92328 - Cordless Phone Logo
131 people viewed this question
Top AT&T Lands Phones Experts
Paul C.
Are you an AT&T Lands Phone Expert? Answer questions, earn points and help others
