Question about Roper RAS8445KQ Top Load Washer
Moved washer to storage and was put upside down for a month...When I put it back right side up about a quart of heavy weight oil came out from under...Can I replace this oil or am I screwed?
How much oildo i need to put in my 89 cbr 600 when i change the oil? and wat weight of oil should i use? and any specific brand or oil? thank you
To check your oil level , locate the large round clutch cover on the right side of the engine. With the motorcycle on the center stand unscrew the dipstick and wipe it off. Put the dipstick back in the fill hole till it stops but do not screw it in. Look at the level of the oil between the two marks. To change your oil you will need 4 quarts of oil, a filter, and a new aluminum drain plug washer. You can reuse the old drain plug washer if it has not been squished out of shape. Your motorcycle comes from Honda usually with 10w-40 mineral base motorcycle oil. You can use any oil that is JASO MA certified motorcycle oil. 10w-40 for cold climate. 20w-50 for warm climate/touring. Car oils use different additives and may cause scoring in certain types of cam bearings. Do not use any oil that says " Energy Conserving " on the label . It will shorten the life of your wet clutch and transmission gears. If you choose Synthetic oils, they will help your bike run cooler and shift easier. Pour in three quarts of oil and add enough from the fourth quart to reach the high mark on the dip stick. You will probably need either 3.2 or 3.4 quarts to hit the high mark. Run the motor for a minute or two to fill the oil filter compartment with oil. Now recheck the oil level and top up as needed.
Jan 17, 2011 | 1989 Honda CBR 600 F(1)K
What kind of oil do you put into a Excell pressure (exh2425) washer pump? Do you use the same as engine oil (30 w)?
Pressure washer oil
I took this picture of my power washer so it's easy to explain the oil.
The oil is different for engine and pump.
The pump oil is 20 or 30 weight non-detergent. SAE20 or SAE30 motor oil. The level of the oil comes up about half way. There is a plastic viewport on side of pump ... oil comes up half way on viewport.
The engine oil is 10W30 motor oil. It comes up about half way or a bit more on dipstick.
To remove oil from pressure washer, do not turn engine on it's side or turn engine upside down or motor oil will run into the carburetor. You might wonder how I know that. Afterward, the carburetor needs to be cleaned out.
To remove oil, you can tip engine to the side but not so much that oil runs up into top part ... to remove the rest of the oil, you can use a plastic hose
Oct 19, 2010 | Garden
What oil is used when changing the old oil
Pressure washer oil
Oct 18, 2010 | Karcher 2500 PSI Pressure Washer
What type of oil is used to fill the a FAIP PV93501 pump and what quanity.
I don't know about that brand of power washer.
We used several types of power washers over the years, and they each called for 20 or 30 weight non-detergent oil in the pump. SAE 20 or SAE 30
The pump oil comes about half way up inside the pump.
Do not turn a power washer on its side or upside down or oil will run into carburetor.
Oct 14, 2010 | FAIP 2100psi 2gpm Faip Power Pressure...
Pacific Hydrostar 95618. pump oil?
Pacific Hydrostar is another pacific rim product that has no website, and no manuals online, and nobody to contact, and no parts available. These machines must be made for the throw-away user.
Pump oil comes about half way up inside pump housing > pump oil is 20 or 30 weight non-detergent oil SAE20 SAE 30
Engine oil comes half way up dip stick > engine oil 10W30
Do not turn power washer on its side or upside down when draining oil, or engine oil will go into carburetor and machine will not start
Oct 13, 2010 | Garden
How many ounces or quarts of oil do you put in the engine and what kind when changing the oil?
Power washer needs oil 2 places.
The pump head has a plastic window on side of pump. Oil should fill to middle of that window. Pump should have 20 or 30 weight NON detergent oil. SAE20 SAE 30 I believe. Auto parts store will know which is NON detergent.
The engine oil is ordinary 10W30. We used to change oil after each painting season by tilting engine to the side. Do not turn engine on it's side or upside down or oil will run into carburetor.
I don't remember exactly how many quarts we put back. Maybe 2? Fill up reservoir until oil is about half-way up dip stick.
Oct 07, 2010 | Simpson PowerShot Commercial-Duty Gas...
Where is the oil filter? Going to change my own oil for the first time since I bought my 2001 BMW 325xi five months ago and didn't have the manual and wanted to find out where the oil filter is and what...
the oil filter is under the back seat, your going to have to unbolt the back seat and is under the left side by the gas tank. the oil weight to use is 10w40. good luck
Feb 04, 2010 | 2001 BMW 325
My oil light came on under heavy breaking. I then
I show the capacity as 6.5 quarts, but owners report that 7.0 quarts with a filter change leave the level right at the top of the dipstick. Hope this helps.
Jan 31, 2010 | 2002 Toyota Highlander
Grease or oil on floor under washer
try putting a new coupler in it its between the motor an the transmission
Mar 22, 2008 | GE WNSE5260D Top Load Washer
Roper RAS8445KQ Top Load Washer Logo
21 people viewed this question
Top Roper Washing Machines Experts
Dan Webster
Dan Webster
Mike
Are you a Roper Washing Machine Expert? Answer questions, earn points and help others
