Question about Maytag 22.7 Cu. Ft. Side-by-Side Refrigerator with Thru-the-Door Ice and Water - Black
Freezer runs constantly, refrigerator not cold freezer ices up, does not defrost
  • Maytag Master
  • 43,501 Answers
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Posted on Dec 27, 2010
Why is it that my refrigerator does not get cold and my freezer is not making ice
SOUNDS LIKE YOU EVAPORATOR FAN HAS EITHER SEIZED----REPLACE; OR WAS BANGING ON ICE AND FINALLY STOPPED ---DEFROST
May 15, 2014 | Refrigerators
Tip
Simple thing you can do if the ref is not getting cold enough.
1. Defrost the freezer if you see ice on the inside wall.
This is a very common problem. Before you call a technician do this.
Defrost the freezer completely, and when you put the items back, make sure that the vent are not being blocked. The fan needs to circulate the air inside the freezer to keep it from having frost. Ice build up causes circulation problem which causes the ref and even the freezer to not get cold enough. Since the thermostat senses that it is not getting cold enough the refrigerator runs constantly and producing even more frost. Then the owner turns the refrigerator to coldest setting which actually do not help, or maybe make the problem even worse, all the while running up the electric bill as well. So there you go.
on Feb 18, 2010 | Refrigerators
Freezer not freezing properly
You have a manual defrost freezer . Ice build up of over 1/2" can act like insulation on wires . If you have no frost build up , and runs constantly , then compressor or refrigerant leak is the problem . Advise to replace freezer . Only 2 parts on manual defrost freezer...compressor and cold control . Compressor will not run if bad cold control . If you have a leak , very expensive to have repaired .
Jul 10, 2009 | Whirlpool GD2SHGX Refrigerator
The coils behind the stainless back panel are caked with ice. I have defrosted them...now what.Fridge won't stay cold and ice keeps building up.Unit is 17 yrs. old. traulsen freezer/glass door fridge ERS...
may be you have problem with the Evaporator fan motor not running, defrost heater, defrost timer, open gap on door gasket and bad thermostat (cold control), it may kept the compressor constantly running. Good luck.
Jun 27, 2009 | Traulsen Refrigerators
Kenmore elite 596 73503201 no cooling in top compartment
if the freezer is getting cold the problem is due to the cold air from the freezer not getting into the refrigerator. There are several things that can cause this problem. The coils in the freezer icing up and not defrosting properly is one of the things that can cause the refrigerator not to get cold enough. Another problem is the fan that blows the cold air from the freezer compartment into the refrigerator, not working. When the compressor is running open the refrigerator's door and push the switch that makes the light go out. You should hear the fan blowing the cold air from the freezer into the refrigerator, when this switch is pushed in. If the fan is working then you will need to find what is blocking the air flow. Iced up coils are a common problem. The icing problem can be due to a defective defrost timer or something defective in the defrost circuit. Click here for more information. Check for these problems and let me know what you have found.
REFRIGERATOR TROUBLESHOOTING
#1 Refrigerator side getting warm Freezer still cold
Evaporator fan motor not running.
Defective defrost timer. See Defrost Diagnosis Procedure
Defrost heater defective. See Defrost Diagnosis Procedure
Defrost thermostat defective. See Defrost Diagnosis Procedure
Airflow blocked from freezer compartment.
Freezer control turned to "coldest" setting blocking air flow to refrigerator side. On most refrigerator/freezers, the freezer control closes a baffle when turned to coldest setting, and this blocks off the air flow to the fresh food compartment.
Fan blade broken.
Defective door switch on older models.
Light staying on with door closed.
2 Refrigerator & freezer compartments both are getting warm
Make sure refrigerator is plugged in and has power.
Condenser fan motor on bottom under refrigerator not running.
Condenser coil clogged.
Defective defrost heater. See Defrost Diagnosis Procedure
Defective defrost thermostat. See Defrost Diagnosis Procedure
Cold control defective.
Compressor overload defective.
Compressor relay defective.
Compressor defective.
Low on refrigerant. #3 Freezer compartment getting hot.
Defrost timer stuck in defrost cycle.(replace)
Defrost thermostat stuck.(replace)
Ice maker stuck in harvest cycle
Light staying on with door closed. 4 Ice maker not making ice
Defective inlet water valve.
Freezer temperature not cold enough. (see problem # 2 & 3 above)
Defective thermostat in ice maker.
Defective drive motor.
Water inlet tube clogged with ice.
Defective module in newer style icemaker. 5 Refrigerator sweating around door edges
Door gaskets leaking air.
Defective case heaters.
Energy saver switch not set to reduce exterior moisture
also if require more help click the link http://www.applianceaid.com/refrigerator.html please do rate the solution .thanks in advance.thank you for using fixya.
Mar 27, 2009 | Refrigerators
New Frigidaire side by side running constantly and still warm
If the frost build up is on the back panel of the freezer then it has a defrost problem which causes a no cool situation. Let me know more about this frost buildup and what you have done.
Oct 07, 2007 | Frigidaire FRS3R5EMB Side by Side...
Maytag 22.7 Cu. Ft. Side-by-Side Refrigerator with Thru-the-Door Ice and Water - Black Logo
103 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
isaac johny
isaac johny
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
