Question about Cooper Wiring Devices COOPER WIRING 2G SWITCH & DUPLEX RECEPTACLE WALL PLATE
Need a Wirinig diagram for wiring a Cooper Duplex Receptacle.
  • 8,404 Answers
Note: this instruction will apply if you are in North America. White wire goes to the silver colored screw; Black wire goes to the brass colored screw; Green wire (bare wire) goes to the green colored screw. If you are using a metal box, you must have a ground wire attached to the bottom of the box that attaches to the ground wire that comes into the box as well as have it connected to all devices in the box (switch and/or outlet). This is best accomplished with a pig tail connected with a wire nut, i.e.: ground comes into the box, make two or more shorter wires to connect one each to the box and each device in the box.
Said differently, looking at the face of the outlet, with the ground opening at the bottom ... the white wire attaches to the wide slot or the slot on the left (silver screw), the black wire (narrow slot) attaches to the brass screw on the right and the green will be at the top or bottom of the device, normally. I think there is more to your question but that is the answer to the question I see.
If there is a switch on the top of a outlet that looks like a outlet, you can control the outlet with the switch or you can control something else with the switch. If there are two switches that look like a outlet ... normally you will power the switch with a common black wire and the switch legs will be independently connected to the other side ... the white wires will be all connected together. If there is a indicator light in the switch, you will need a white wire attached to that silver screw that powers the light.
There should be a wiring diagram in or printed on the box that your switch came in though in my experience they are so small as to not be much help.
If you have a switch that you want to control an adjacent outlet with ... p;owre into the switch (black wire). Make a jumper from the other switch terminal to the brass colored screw on outlet. The whire wire will go to the white or silver screw on the outlet. This arrangement will allow you to turn the outlet on or off at your will.
I hope this answers your question.
Thanks for your interest in FixYa.com
Posted on Oct 03, 2010
Cooper tr274v wiring diagram
Are you installing a combination switch-outlet?
What are you replacing? A switch? Is switch single pole or 3-way?
Or are you replacing outlet.
Do you have the Cooper TR274V?
Which device do you have?
http://waterheatertimer.org/How-to-Replace-outlet-with-combo-switch.html
http://waterheatertimer.org/How-to-wire-combination-switch-outlet.html
http://waterheatertimer.org/How-to-wire-switches.html#5245
Gene
hh
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Oct 02, 2013 | Electrical Supplies
I need a wallplate with the duplex on the left and toggle (for garbage disposal) on the right. I can only find the opposite configuration. Does this combination exist somewhere?
Rotate the plate 180 degrees so top is now the bottom, and bottom is top..
Then duplex will be on opposite side of switch.
I think that will fix the problem. Add a comment.
Gene
Aug 05, 2013 | Cooper Industries Cooper Wiring 2158V 3...
Cooper 274W Combination Device. Can the device be wired so that the sitch controls the recepticle?
Yes. For each half of the device there will be two terminals, plus one ground terminal. (total 5) For the receptacle, one terminal will be brass and the other will be silver. These two terminals will be on opposite sides of the receptacle, but both will be nearest the receptacle end. The other two terminals are for the switch, and their color is not important. You must place a jumper wire from the brass terminal of the receptacle to the nearest terminal of the switch. There might already be a tab connecting these two terminals together - if so, then you don't need the jumper, just tighten down these two screws. You will wire your incoming black wire to the other switch terminal. Your white wire goes to the remaining terminal which is for the receptacle and will be silver. Your ground wire goes to the green ground terminal. Good luck, Al K
Jul 06, 2011 | Cooper Wiring Devices Combination Switch &...
I"m installing a Cooper Devices
Wiring is suspect.
Black hot wire connects to dark screws.
Break off tab should be intact.
White neutral wire connects to silver screw.
Wire going to switch load connects to brass screw.
Jun 18, 2011 | Cooper Industries Cooper Wiring 274W...
How to replace a switch combination receptable to a middle of the run duplex receptable. the switch combination have 3 screws on rt side ( brass on top , black screw , tab, black screw. left side grd...
Don't hardwire the disposal. That's against plumbing and electrical code. House will not pass inspection.
That being said.
Electricians don't guess, they test.
Note which wires were connected on same screw.
Do not untwist any wires..
Separate individual wires for testing.
Turn power ON.
Test each wire to bare ground wire.
Tester lights up on Hot wire. Hot connects to Brass screw on ordinary receptacle.
Hot is identified.
Test Hot to each other wire, except bare ground.
Tester lights up on Neutral. Neutral connects to Silver screw on ordinary receptacle.
Load wire goes to disposal.
To put power to Load, then Load wire also connects to brass screw along with Hot wire.
Feb 19, 2011 | Cooper Wiring Devices Combination Switch &...
Want to build a Surge Supressor for 240V Home use. Either whole house or duplex box by duplex box use. Normal voltage here is 240 VAC
Square D makes "whole house" model It installs in your main breaker panel. Hubbel makes a surge supressor receptacle for individual duplex receptacle usage.
May 19, 2010 | Electrical Supplies
ShockSentry GFCI duplex receptacle child safety
Those GFCI's will stop functioning (as they are supposed too) if the electronics is bad. Nearby lightning strikes and power surges can knock out the electronics. Some GFCI's come from the factory bad out of the box. Also if wired incorrectly (make sure the incoming 120 volt wires are connected to the LINE side of the receptacle) The only other thing to check is if there is power to the GFCI. Test for 120 volts at the receptacle box. (testing from hot to neutral will rule out a bad neutral connection). Should read 120 volts. Otherwise, you'll have to replace the outlet :-(
Jun 07, 2009 | Cooper Industries Cooper Wiring 274W...
3 LIGHTS TO 3-GANG SWITCH
Feb 21, 2009 | Cooper Industries Cooper Wiring 2158V 3...
Cooper Wiring Devices COOPER WIRING 2G SWITCH & DUPLEX RECEPTACLE WALL PLATE Logo
273 people viewed this question
Top Cooper Wiring Devices Electrical Supplies Experts
Steve
Dennis Boxerman
Are you a Cooper Wiring Devices Electrical Supply Expert? Answer questions, earn points and help others
