Question about Seagate FreeAgent Pro - 500GB, 7200 RPM, USB 2.0, eSATA, External 500 GB Hard Drive
How can I power up my seagate 7200.11 500gb external h/drive to my pc
  • 8,404 Answers
If your OS supports this device ... plug in the power supply to proper voltage ... and connect the end to the device. Use a appropriate USB cable from the back of the Seagate and plug into an available USB connection on your computer.
Posted on Oct 03, 2010
How to recove Seagate external hard drive data?
Probably, the new operating system cannot recognize your Seagate external hard drive. You can connect the Seagate external hard drive to another computer to copy data to another device. If the problem still exists, you might need to perform data recovery. You can free download the data recovery software: http://www.icare-recovery.com/seagate-recovery/seagate-external-cannot-be-recognized.html
May 14, 2014 | Seagate FreeAgent Pro 500GB External USB...
Cannot connecy power supply to unit
You need a USB cable to connect the seagate drive to the PC and you need to plug the seagate's power supply into the seagate drive and the wall.
Jun 17, 2012 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
How to connect
You need a USB cable to connect the seagate drive to the PC and you need to plug the seagate's power supply into the seagate drive and the wall....
Seagate 500GB FREEAGENT DESKTOP 7200RPM EXTERNAL USB 20 HARD DRIVE 16MB it just stoped working in the middle of the movie, complete blackout, tryed conect to another PC nothing came up, what it could be...
Try this:
1. Turn off the power supply to the hard drive.
2. Turn off your PC/laptop.
3. Connect the hard drive to the PC/laptop.
4. Turn on both devices.
It worked with mine.
You could also try installing Seagate Manager which can check for errors on the drive.
Jun 10, 2011 | Seagate 500GB FREEAGENT DESKTOP 7200RPM...
Hi I Have an I O Error On My External Hard (500 GB Seagate) and I can't open or copy my files. Please Help Me. Thank You
  1. Unplug both the power cord and USB cable from the external Seagate hard drive.
  2. Restart your computer
  3. Plug back in both the power cord and USB cable from the external Seagate hard drive.
Comment back if this doesn't fix the issue.
Mar 01, 2011 | Seagate FreeAgent Pro 1TB External USB...
Please i need the power adapter rating for seagate
Have you got the original power adapter?
If so the voltage details are printed on the label on the bottom of the adapter.
If the external USB Seagate hard drive houses a 31/2" drive then it requires an power adapter that provides +12 volts and +5 volts both supplying approx 2000mA of current.
If the Seagate uses a 21/2" (laptop) hard drive then it only requires +5 volts power adapter.
The only problem is the power connector to the external drive, make sure it suits the external hard drive unit and the power pins are correctly wired for the Seagate. If the polarity of the plug is incorrect lt wired (ie reverse polarity) then it could damage the USB hard drive and adapter case.
Nov 20, 2009 | Seagate (ST3500601CB-RK) (ST3400601CBRK)...
Need a power cable
A user on the Seagate forums indicates that his uses a 12V 2A DC power supply. I would suggest, however, that you remove the hard drive from that enclosure and place the drive either inside your PC or inside another enclosure.
If all else fails, contact Seagate: 1-800-SEAGATE
Let me know if this helps!
Apr 05, 2009 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
New Seagate FreeAgentPro USB eSATA 500GB power on light not glows
Thank you for your reply.
I have solved the problem with local help.
Printed installation manual of Seagate 500 GB eSATA external hard drive has not properly mentioned how to use power on/off switch once connected to mains. I could get local help, who has already used the device. On/Off switch to be pressed for few seconds after mains connected, sometimes it comes automatically once power is on and USB cable pluged to the USB port of PC if power supply is ok. There is no indicator for the power supply (before device glows) after connected to the mains. I was in confusion whether power supply is ok or not.
Finally, It was found that the problem was with mains power supply and I have changed the power socket and adapter.
SP Jena
Nov 18, 2008 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
When i connect my seagate via usb nothing comes up on my pc, the light comes on on the external h/d but nothing pops up on the pc? help please i need precious photos on it. thanks
have you try connect your pen drive to the same usb port, is it working?
If Pendrive is working but not the Seagate hardisk. Most propably is your USB power is not enough to support the External Seagate hard disk, you need to supply more power to the Seagate hard disk by using USB Y cable(1 end connect to Seagate hardisk where the other end got 2 USB connector to connect to your PC).
Jul 30, 2008 | Computers & Internet
Seagate FreeAgent Pro - 500GB, 7200 RPM, USB 2.0, eSATA, External 500 GB Hard Drive Logo
131 people viewed this question
Top Seagate Computers & Internet Experts
Computer Links
Steve
terminalcon
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
