Question about Whirlpool Duet GHW9150P Front Load Washer
What is an F 02 that flashes on the display?
  • 905 Answers
Try having a look here for what the codes mean, as well as some ways to mediate them.
Posted on Oct 03, 2010
F 02 flashing on control panel
F/02..
Long Drain
If the drain time exceeds 8 minutes, the water valves are turned off and "F/02" is flashed.
NOTE: After 4 minutes the "Sud" error will be displayed, then 4 minutes later the F02 error code will be displayed.
Press PAUSE/CANCEL twice to clear the display.
  • Check the drain hose and make sure it is not plugged or kinked.
  • Check the electrical connections at the pump and make sure the pump is running.
  • Check the drain pump filter for foreign objects.
  • If the above does not correct the problem, replace the pump.
Oct 21, 2012 | Kenmore HE3T Washer
Won't finish the wash cycle and flashes the code F 02
This code means that the machine is not evacuating its water.
F/02 Long Drain
Jun 09, 2011 | Kenmore Washing Machines
Washing machine stop and start flashing o2f
Long Drain
Press PAUSE/CANCEL twice to clear the display. NOTE: After 4 minutes the "Sud" error will be displayed, then 4 minutes later
the F/02 error code will be displayed.
Potential Causes • Check the drain hose and make sure it is not plugged or kinked • Check the electrical connections at the pump and make sure the pump is
running. • Check the drain pump filter for foreign objects • If the above does not correct the problem replace the pump
Feb 08, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Washer is flashing a signal of 02 F and beeping
F02:
Long Drain
Feb 03, 2011 | Whirlpool Duet GHW9150P Front Load Washer
What is f o2 flashing mean
F/02 = Long Drain
Press PAUSE/CANCEL twice to clear the display. globul1a.gif Check the drain hose and make sure it is not plugged or kinked. globul1a.gif Check the electrical connections at the pump and make sure the pump is running. globul1a.gif Check the drain pump filter for foreign objects. globul1a.gif If the above does not correct the problem, replace the pump.
Dec 27, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Hoover ultima code F-02 flashing
If the drain time exceeds eight minutes, the water valves are turned off and "F02" is flashed.
Press PAUSE/CANCEL two times to clear the display.
NOTE: After four minutes the "Sud" error will be displayed, then four minutes later the "F02" error code will be displayed..
Possible Causes / Procedure
1. Check the drain hose and make sure it is not plugged or kinked.
2. Unplug washer or disconnect power.
3. Check the electrical connections at the pump and make sure the pump is running.
4. Check the drain pump filter for foreign objects.
5. Plug in washer or reconnect power.
6. If the above does not correct the problem, go to step 7.
7. Unplug washer or disconnect power.
8. Replace the pump.
Jul 17, 2009 | Washing Machines
F flashing followed by a 2
F/02 Long Drain
Feb 09, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Drain
This should solve the f/02 problem.
If the drain time exceeds 8 minutes, the water valves are turned off and "F/02" is flashed. After 4 minutes the "Sud" error should be displayed, then 4 minutes later the F02 error code. Press PAUSE/CANCEL twice to clear the display.
Then
Sep 15, 2008 | Whirlpool Duet GHW9150P Front Load Washer
FT02 is displaying
When mine said FT-02 it wasn't flashing or anything, but I pressed the cancel button and after it said "initializing" for a sec it went back to normal. FT-02 is some kinda test mode for the manufacturer, I think.
Mar 30, 2008 | Panasonic DVD-RV32 DVD Player
F02 code
F 02 means Long Drain. If the drain time exceeds 8 minutes, the water valves are turned off and “F/02” is flashed.
NOTE: After 4 minutes the “Sud” error will be displayed, then 4 minutes later the F/02 error code will be displayed. Potential Causes
Jan 03, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
35 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
