Question about Xerox WorkCentre M20 Black and White Copier
I HAVE A M20 XEROX PRINTER AND I AM GETTING A MESSAGE THAT SAYS OPEN HEATER ERROR WHAT DOES THIS MEAN
  • 33 Answers
The heater rod (quartz lamp) inside the fuser roll is cut/ burned. Unfortunately Xerox will not support it as spare. You should buy a new
fuser.
Replacing it is easy. Just a few screws to take off on the right side plus two electrical plugs.
Posted on Oct 04, 2010
I have Xerox M 20i .When ever I feed papers from ADf. Print is not coming normal.Some time it shrink the text,I checked the roller are fine.
The Xerox is a business machine and has a setting to reduce the size of scans by percentage.
Read the instruction manual to turn it off or play with the buttons.
WorkCentre M20/M20i Documentation - Xerox Support and Drivers
www.support.xerox.com/support/workcentre-m20-m20i/documentation/enus.html
  1. Cached
  2. Similar
Product documentation for WorkCentre M20/M20i. ... WorkCentre M20/M20i Firmware Installation Instructions. Setup and Installation Guides. Description.
[PDF]WorkCentre M20i System Administration Guide - Xerox Support and ...
www.support.xerox.com/support/workcentre-m20i/file-redirect/enus.html?...en... Xerox WorkCentre M20i System Administration Guide. Page i. Table of Contents. 1 Welcome ................................................................................. 1-1. Introduction .
Xerox 20i Google Search
Nov 19, 2016 | Xerox Office Equipment & Supplies
Error message Xerox Phaser 8400 07.010.43.4819
The post was a little confusing. You have an 8400, correct? (not an M20)
The 07,010 error is normally a bad process motor 401-1000-80
You should also change 2 camshafts at the same time 401-1003-80 and 384-1874-80. The whole job is medium difficult and takes 2-3 hours.
Whit
Item, Inc.
May 09, 2010 | Xerox WorkCentre M20i All-In-One Laser...
Open heat error what does it mean and How do I
Turn off your printer, unplug the unit. Then plug it back in and turn it on.
This error message means that the printer needs service. See the following URL for more details: http://www.xerox.com/office/PE120kb/,case=R1018019549
I wish that I could be of more help.
Apr 14, 2010 | Xerox PE120i Laser Printer
I get an error message that says "Printer Error - Contact Service: Report Fault: 15.004.45.1758" Whats does it mean and how can I fix it? Thanks
That means the 2 halogen lamps that serve as the drum heater have gone out. Either one or both have blown.
They simply are 2, ,, 150 watt halogen lamps that you can replace, Takes about an hour to do, I can send you instructions if you want.
E-mail me ,,, rak458@aol.com
Jul 14, 2009 | Xerox Phaser 8200 Laser Printer
Phaser 8400 error code 37,004.40:51402 this happened after moving the printer Thank you
Hi abonk:
This is your problem.
37,004.4x - PEST_FAULT_RESERVOIR0_HEATER_DISCONNECT
PEST - Reservoir0 Disconnect Reservoir0 is not drawing the expected power from the
supply.
1. Run the printhead Reservoir Heater test.
2. Verify printhead wiring.
Your preheater needs to be replaced.
Xerox Preheater Part # 119641980
This part will have to be replaced by a certified Xerox technician.
Hope this helps
Jun 23, 2009 | Xerox Phaser 8400 Laser Printer
Xerox Phaser 8400 error code 37,004.40:27697
The majority of the time that code means the print head has failed.
That is a print head heater error.
You can find some places that sell print heads for about $150 , you would have to google the model number for that.
Xerox would charge $750 for a new print head, uninstalled.
Apr 24, 2009 | Xerox Phaser 8400 Laser Printer
XEROX 8550 DP ERROR
when are you getting this error message?
Oct 28, 2008 | Xerox Phaser 8550DX Laser Printer
Xerox 8550 Error message 19,003.48:121016
19,003.48 Scale and offset voltage error too large. Something is wrong with the Electronics Module or Wave Amplifier.
that is pretty straight forward. More then likely the elsctronics module has failed. Wave amplifier is pretty unlikely.
If you do not have a maintenance agreement or under warranty, that is a very expensive module to replace.
Check @ 1-800-835-6100 to see if you are under warranty or have coverage.
Apr 22, 2008 | Xerox Phaser 8550DX Laser Printer
Error on Xerox C525A ( 004-332 )
Dear Sir,
can you help me out. i've got a Xerox C525A with a error message "010-397". what does this mean? and how can i fix this so i can carry on printing.
Feb 17, 2008 | Dell 3100cn Laser Printer
Xerox WorkCentre M20 Black and White Copier Logo
163 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Xeroxrep
Level 1 Expert
Philip Hughes
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
