Question about Lisle 91000 LISLE DRILL GRINDER U.S.A
Whats the price of a lisle 91000 drill grinder
Mkbl1830.blogspot.com
There are battery shops around the specialise in replacing the batteries in the battery packs. Normally around 1/2 price with much better quality batteries than original. Remember when buying a portable unit then most of the price is in the battery pack so the cheaper the item the lower quality of the batteries used. That is why you are offered 2 packs sometimes as they are of low quality but you consider it a bargain
Jun 25, 2013 | Drills
Brushes for drillmaster grinder
looking for carbon brushes for a drill master model#69079
Jun 09, 2012 | Master Heaters Drill Master 412" Angle...
I want to use flap disc's on my grinder with out the threaded portion attached. What do I have to do to install them on the grinder.
flap discs can be used on a grinder the same as grinding disc and cut off wheels . You may need a centre adaptor as some flap discs are larger in the centre hole
Aug 31, 2011 | Dewalt D28402 412" (115mm) Small Angle...
Beans do not feed anymore. I have to shake the grinder to get them to feed.
- it is happening from time to time at all brands, you need to:
  1. remove upper burr holder
  2. unscrew lower burr holder bolt
  3. go with bolt in some metal workshop and ask for one peace of drill above bolt to be attached
  4. explain the way of rotation of burrs to metal workshop master so he wont mistake to do the drill in opposite way
  5. come with drill attached bolt at home , clean good the grinder, assemble the drill attached bolt.
  6. assemble upper holder and the plastic bean container (inspect does the drill touch the tongue for closing the beans at bean container)
Feb 12, 2011 | La Pavoni Coffee Makers & Espresso...
Need parts for the lisle 91000 grinder
I need the drill bit holding assy. And a dressing tool assy.
Sep 15, 2010 | Lisle 91000 LISLE DRILL GRINDER U.S.A
To sharpen tools
The angle things on the grinder are usually set up for drill bits and never moved again. If you need to sharpen your shovel, I would get a 4 1/2 grinder with 80 grit disc in there and grind away from the edge, Not into it, it cuts 10 times faster, cleaner, straighter, than the grinder, use fit or the lawn mower blades too, and the machete, use the grinder for your drill bits and other precision type stuff, don't let the wheels get rounded off or uneven, use a wheel dresser if they do. I have a couple grinders set up in my shop, one wheel for finer stuff, then a wire wheel, then a green wheel for carbide, and then another wire wheel. I use a 1 inch belt for knives and finer stuff, and a 10 disc for serious stuff along with the 48 inch belt. So you can see, I use them a lot. But if you need to use the grinder for your shovel, I would not use the angle stops, I would do it freehand and you can only cut the outside edge, and it will be hard to get it around there. You might have to take the angle stops off. Hope this helps.
Jul 29, 2010 | Delta ShopMaster 8in Grinder with Light...
I need to find a manual for the makita 18v lxt angle grinder. my problem being that when i put the battery on the lights flash up red and during use the lights do not work at all. please help.
Hi, Don't stress, its working fine. The grinder has a sort of self test when you put the battery in, it blinks. What you don't want is the light to come on when you are using it. That means that you are bogging it down and if on for 30 seconds ( if I remember right) it will shut the grinder off until you reset it by turning it off and then on again. So no worries!
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
Mar 26, 2009 | Makita 18V LXT Lithium Ion Cordless 3/8...
Bench Grinders Objects
our bench grinder can be used to keep your chisels, knives, gouges and other similar cutting tools sharp, which every woodworker knows is vitally important. Also, bench grinders are handy for sharpening lawn mower blades, drill bits, gardening shears and more. Additionally, a bench grinder can be used for honing and shaping metal objects when modifications are needed. For instance, perhaps you need to modify a door hinge to make it fit in a certain application. No tool is better for this task than a bench grinder.
Aug 27, 2008 | Dewalt 6" 5/8 Hp Heavy Duty Bench Grinder
Lisle 91000 LISLE DRILL GRINDER U.S.A Logo
254 people viewed this question
Top Lisle Saws Experts
Tom Chichester
ray gallant
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Lisle Saw Expert? Answer questions, earn points and help others
