Question about GE Microwave Ovens
How do I get the "surround" panel off ? My JE2160 keeps shorting out when the door latch release is pushed.... wondering if it is a circuit in my garage..... or something wrong with microwave. Would like to remove the microwave from cabinet to take a look at outlet behind it . think the built-in panel needs to be taken off before I can get a grip on microwave.
  • GE Master
  • 8,404 Answers
You have a serioius problem which requires professional intervention. Your oven should Never 'arc' between the door and the cabinet. Evidently, the oven is charging the door (which should not happen) and the charge is not properly leaking to a proper ground.
Thanks for your interest in FixYa.com
Posted on Oct 03, 2010
Open door if latch is broken
And you can't just pull the door open? I know it's easier to push the open door button but both ways should work unless the safety switch bracket moved from it's intended position. I hesitate to offer this solution, but who wants decayed food smelling up the home? Let's assume it's a counter top oven, remove all cover screws and the cover. STAY AWAY FROM ALL WIRING and I should have said first unplug the power from the appliance. Locate the door latch area and lift up on the plastic/metal bar that has a spring attached to it and the door should be released. Pushing the door release button should lead you to the latch. Once you see how it works you may find the reason the latch is malfunctioning. If it's a over the range type you will have to remove a grill at the top of the oven to access the mounting screws that release the oven from the bracket but the latch reference above will apply to this type as well.
Dec 06, 2014 | Microwave Ovens
Viking Microwave door latch
Try pushing in on the door while pressing the door release latch;
Also, try pushing the door latch and reach under the front edge of the door and slightly pull as the latch is depressed.
Third option is use a suction cup, maybe from a GPS device on the glass portion of the door, pulling on it while you depress the door latch....let me know any problems or if I can help anymore.
Jul 27, 2014 | Viking VMOC205 Convection/Microwave Oven
Frigidaire wall bake oven (door opens with hinges on left) won't unlock after cleaning. Turned current off and back on with no results. Fan runs as in cleaning cycle, but door won't open.
If after self cleaning cycle the over door is not getting open.Then in some cases the door latch gets locked and this latch stops functioning so the door does not get open.In this case the front door assembly has to be disassembled and the door latch,it has to be manually triggered/pushed by a screw driver or any such object.So the door latch releases the door to get open.Then refit the parts and check,if the door latch is not functioning as it should be.Then the door latch assembly has to be replaced.After self cleaning,many a times the door latches gets overheated and its connections gets short internally.This is noticed by many other users too.In some cases door latch just gets blocked and triggering it with screw driver,makes it function properly.So disassemble the door and see the condition of door latch.This will help you to decide whether its just locked or got faulty.------------If its got faulty and you require door latch part,then you can get it from the online sites like www.repairclinic.com or from searspartsdirect site.
---------------- This should help.Thanks.Helpmech.
Dec 24, 2010 | Microwave Ovens
My microwave oven stop working. buttons will not work and an error code F3 come up on display. Could you tell me what this could be?
F3 is a shorted key you need a new keypad control panel. For the JE2160 series countertop model this should be the part#WB27X10681
Dec 06, 2010 | GE JE2160 Microwave Oven
When microwave finishes light doesn't come on when door open; display keeps reading "food ready" after food is taken out--have to push the "clear/off" button to make "food ready" display go away; counter...
Shorted switch in the door latch assembly.wihout the full model number I can't tell how to get to it, but usually one needs to remove top grille, remove screw holding the control panel, remove control panel. Good luck.
Nov 26, 2009 | GE Profile Spacemaker II PEM31 Microwave...
Controlpanel flashes f 3
You have a faulty keypad. You could probably special order this part from a local appliance parts supply store for 50-60$ or purchase a new microwave.
Oct 22, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
He's Dead, Jim! Died when door opened, but Usual Suspects clear?
May 13, 2009 | GE JE2160 Microwave Oven
How do I remove the control panel on model JE2160
You need to take the back cover off using a special tork wrench. If you don't have one a thin blade screw driver usually works. after getting the back cover off access is pretty easy to remove the screws from the panel. Make sure to discharge the capacitor before attempting any repairs and unplugged of course.
Jan 12, 2009 | GE JE2160 Microwave Oven
Display panel works but no heat, no fan, turn table doesn't turn
This is usually caused by either a bad door switch or a loose door switch mount, which are pretty simple problems to fix.
Even though a door switch clicks, it may still be bad inside.
Door switch or mount trouble is usually caused by slamming the door or by opening the door while it's cooking without hitting the Stop pad first.
There are plastic mounts inside the microwave which hold the door switches and onto which the door latches lock when you close the door.
The screws on these mounts may be loose. If they get too loose, the switches will not be activated properly.
Sometimes it's a broken tab on the switch holder, allowing the switch to rotate just out of position. This tab can be hard to see, since it is under the bottom edge of the switch.
If you or someone you know decide to look into it, we have critical information on safety, disassembly and door switches at our site, and our link is at our listing here on FixYa:.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
If you only need a switch, you can order a universal type here for $5 postpaid.
If you think the problem is on the control panel, we repair these nationwide by mail for $39.95 postpaid in most cases in about a week or so.
Home Circuit Breaker Pops When Door Is Opened
It does sound odd for it to blow the breaker. It should blow the fuse, not the breaker. But looking at the exploded view diagram, I don't even see a fuse! Makes me wonder if this is some foreign model. *grin* In any event, you will need to replace all the door switches since they all have been stressed by the same overcurrent. Also be sure that all the switch mount and door latch parts are activating properly when you open and close the door. The switches (generic replacements) are widely available from local appliance parts stores. If you need any other parts, you can see an exploded view and parts list here: http://www.geappliances.com/shop/prts/
Dec 16, 2006 | GE JE2160 Microwave Oven
Microwave Ovens Logo
69 people viewed this question
Top GE Microwave Ovens Experts
D. E. Hev
 Larry
Larry
Shekar Avadhani
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
