Question about Dell Latitude D610 Notebook
My dell latitude d610 is not charging, when connected with ac adaptor the laptop works fine even without batter but putting up the battery shows-charging is nil ! -updated my bios with a06 version from dell.com also but the problem still remains there.pl suggest some alternative as I am not interested in going for motherboard repaires etc which are firstly very costly and time consuming and more over never last long unless one completely replaces it. Thanx ,My name is Vikram Diwakar I am writing this mail from Jabalpur-MP India and my mob.no is +91 98 930 85060.
  • 903 Answers
Hi, you might just have a faulty battery and need to replace it. One thing you can try is to stick the battery in your freezer for a day or so, and then put it back in your computer and see if it will charge. If not, try a new battery and you should be okay.
Posted on Oct 05, 2010
My dell latitude d610 ac power is work is properly but battrey is not charging plz tell me soulition.
If the D610 works when attached to the AC Power Cord, it is likely that your battery is not capable of taking a charge and needs to be replaced. I have 2 D610 Dell Latitudes and they are very good laptops.
Please vote if my information is helpful or not. Recommend me. Thanks UAW 974
Jun 26, 2011 | Dell Latitude D610 Notebook
Th ebattery light flashes contiuosley from green to orange even when the ac adaptor is plugged in the mains .do i have faulty battery as well as a faulty aadaptor ?
Joanne, remove the battery and unplug the power adapter. Now replug the power adapter and start the laptop without the battery. If all is well then you've determined the fault is the battery. Which is very common on those laptops. -Ravi Shanghavi
Aug 19, 2010 | Dell Latitude D610 Notebook
Dell Latitute D610 is no longer working under AC Power
Please check the AC adapter with another system and confirm if it is working fine. Else get it replaced.
Thank you for using Fixya
Oct 08, 2009 | Dell Latitude D610 Notebook
My Dell latitude d610 charging circuit not working on board
What needs to be done is the jack that your adaptor plugs into has solder points underneath it. All the solder points need to be resoldered to make sure that there are no cracks in the solder that are preventing the jack from charging your battery.
After this is done if the laptop still isn't charging then if you know for sure your using the correct ac adaptor with your laptop then at that point the moterboard would have to be replaced.
Jul 31, 2009 | Dell Latitude D610 Notebook
Battery light blinking red even when charging
Looks like you need a new battery. Same thing happened with a DELL XPS, once the new battery was in place, all was fine.
Jun 03, 2009 | Dell Latitude D610 Notebook
Dell latitude D600 battery charge light flashing
it means your battery is damaged. avoid using battery while using charger in your house. remove battery to be safe. battery is for outside or for travel only.
May 29, 2009 | Dell Latitude D600 Notebook
BATTERY PROBLEMS?
Hi
Latitude D620 battery module has a battery charge tester. First remove the battery or turn the laptop over and press the battery icon and the note the battery LED indication.
If there is no LEDs lite, shut down the laptop, connected the power Adaptor, install the battery and check if the battery charge LED lites up.
If it doesn't double check the power Adaptor. Latitude D620 is rated to use a 90W Adaptor. There is a 60W Adaptor (looks very similar to) but this is for other Latitudes and AMD Vostro systems.
If the Adaptor has the correct rating, then check below for more info;
1) [Very Likely] The battery may be faulty or end-of-life and needs replacing. Check the battery connector on the Latitude and battery itself for any broken or bent pins or bits.
2) [Possible] You have the wrong power Adaptor or the Adaptor is faulty. This however would not explain why the battery is undetected.
Start up the Latitude into System BIOS (F2). Under System > Battery information check the battery and AC Adaptor status
If the Latitude D620 has warranty you may open a warranty claim with Dell Support.
Mike
Apr 02, 2008 | Dell Latitude D620 Notebook
my suggestion is that you allow the batteries to fully recharge(which only happens when the computer is fully off, when the battery is deep discharged.
that will take around 6 to 10 hours each..
Mar 10, 2008 | Dell Inspiron E1505 Notebook
Charging Problem
go back to old bios if u can
Jan 21, 2008 | Dell Latitude D600 Notebook
Dell Latitude D610 Notebook Logo
119 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
