Question about Sony MDS-JB940 Mini Disc Player
Will not eject a disk - Sony MDS-JB940 Mini Disc Player
How to i eject a disk from my mac computer
I'm thinking it is working normally, so you can either:
1) Select the disk (or open a folder inside that disk) and press Command+E and that should EJECT the disk.
2) Drag the disk to the trash
If the computer is not ejecting the disk after that then you have a problem with the hardware. The next step would be trying to eject it while restarting.
Oct 28, 2014 | Apple MacBook Pro Notebook
Tip
DVD player in my home theater system won't eject the disk inside.
When a disk is stuck inside the player , try following the procedure below:
Unplug power cord.
Plug back power.
Turn on the unit and press repeatedly the eject button at the same time. If you successeed in ejecting the disk before the player starts reading TOC(disk initial track), then the disk will eject.
If that does not work, then there is an internal fault, in that case the unit must be disassembled to remove the disk.
on May 04, 2009 | Philips HTS3450 System
How do eject disc from my mac os x
Every Mac that has an optical drive has an eject key on the keyboard. Pressing the eject key will eject a CD or DVD.
The eject key has this icon on it: ?
You can also right-click on the disk icon, then choose "Eject" from the pop-up menu.
You can also click once on the disk icon, then choose "Eject" from the File menu.
You can also drag the icon to the Trash icon in the dock.
The eject key will only eject CDs and DVDs, but all of the other methods described above will also unmount other media types, like a hard drive or flash drive connected via USB, FireWire, or Thunderbolt.
Aug 13, 2014 | Apple Mac OS X Snow Leopard (10.6.8)
Disk will not eject
Unplug the drive. insert a paperclip in the hole in the back of the drive. This will manually eject the disk. You can also open the cover but that's a lot more work than you need to go through when a simple paperclip will move the manual eject lever.
Jan 19, 2014 | Iomega Z100P2 External ZIP Drive
Ejectiing a disc
f you're told you can't eject a disk, try the following suggestions.
f you're trying to eject an external disk:
  • Choose Apple menu > Log Out, and then log in again. Try to eject the disk again.
  • If you still can't eject the disk, choose Apple menu > Shut Down. Disconnect the disk from your computer, and then start up your computer again.
    If you're trying to eject a CD or DVD:
    • Choose Apple menu > Log Out, and then log in again. Try to eject the disc again.
    • If you still can't eject the CD or DVD, choose Apple menu > Restart. While your computer restarts, hold down the mouse button or trackpad button until the disc is ejected.
      If you're trying to eject a network disk:
      Choose Apple menu > Log Out, and then log in again. The network disk should be gone.
Jun 11, 2012 | Apple Air Computers & Internet
Need to eject
If you're told you can't eject a disk, try the following suggestions..
Jun 11, 2012 | Apple Computers & Internet
My wii won't let the disk to come out
wil it eject if you try ejecting it in the disk menu might be a faulty eject button on the front ?
Jul 26, 2009 | Nintendo Wii Console
Zip drive does not eject the disk and will not power up.
To the left of the Eject Button/Activity Light is a Disk Eject Hole. It will be a very small hole big enough for you to straighten out a paperclip and push in to hit the eject the disk
Jul 20, 2009 | IBM Iomega ZIP 750 (22P7099) External ZIP...
I'm having a problem with my CDJ 800. Loading ejecting
Basic DVD, CDrom Troubleshooting
wrong disk ,disk error,
First Clean the lens:
http://www.ehow.com/how_2036275_clean-lens-dvd.html
wont open, wont close, makes clicking/grinding noises etc.
http://www.llamma.com/xbox/Repairs/thompson_dvd_tray.htm
Jan 28, 2008 | Pioneer CDJ-800 Turntable
Hung up - disk won't eject
cd recorder disk will not eject
Dec 08, 2007 | Panasonic VDR-M70 DVD Camcorder
Sony MDS-JB940 Mini Disc Player Logo
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
